DELTA Pro Ultra X Smart Extra Battery | EcoFlow US
EcoFlow DELTA Pro Ultra Series Smart Extra Battery EcoFlow DELTA Pro Ultra Series Smart Extra Battery EcoFlow DELTA Pro Ultra Series Smart Extra Battery EcoFlow DELTA Pro Ultra Series Smart Extra Battery EcoFlow DELTA Pro Ultra Series Smart Extra Battery
USD $2,199.00
Starting at 0% APR with Pay
Compatible with DELTA Pro Ultra and DELTA Pro Ultra X Inverters.
  • Expandable capacity - Increase the capacity of DELTA Pro Ultra X with an extra 6144Wh.
  • Plug-and-play without setup. And use the EcoFlow app to monitor and control.
  • The Highest Safety Standards: EV-grade LFP cells, dual BMS, and 3-level safety architecture.
  • 5-Year Full Warranty
Learn more
Recommended
Compare
Selection Summary
EcoFlow DPUX ACC 1 x DELTA Pro Ultra X Smart Extra Battery EcoFlow DELTA Pro Ultra X Smart Extra Battery
1 x DELTA Pro Ultra Series Smart Extra Battery
USD $2,199 $2,299
USD $2,199 $2,299 -$100
Ways To Pay
Comparison
DELTA Pro Ultra X
DELTA Pro Ultra
DELTA Pro 3
12kW, 120/240V, 60HzUp to 36kW in 3 parallel units
Discharging: Pure sine, 7,200W total, 120V/240V~ 60HzBypass: 100-120V~30A total, 50Hz/60Hz
12kWh
102.4V⎓60A, 6,144Wh
4kWh
12kWh
102.4V⎓60A, 6,144Wh
4kWh
240v/50A
240v/30A
120v/20A
240v/50A
240v/30A
120v/20A
AC Charging Input:100-120V 50/60Hz 1800W 15A120/240V 50/60Hz 7200W 30A120/240V 50/60Hz 12000W 50ABypass Mode: 100-120V 50/60Hz 1800W 15A120/240V 50/60Hz 7200W 30A120/240V 50/60Hz 12000W 50ASolar Charging Input:80-500V, 15A RMS*2
AC Input"Charging: 100-120V~15A; 200-240V~12.5A, 50/60HzBypass: 100-120V~15A, 50/60Hz (duration < 3hrs when the current exceeds 12A)"Solar Charging Input"Total 5600W, 2 portsHigh-PV Input: 80-450V/15A, 4000W MaxLow-PV Input: 30-150V/15A, 1600W Max"
NEMA 5-20 (x2) 120V 20A NEMA L14-30 (x1) 120/240V 30A NEMA 14-50 (x1) 120/240V 50A
120V AC Output Socket (Backup UPS): 2 x 20A Max per port120V AC Output Socket (Online UPS): 2 x 20A Max per port120V AC Output Socket (Online UPS): 1 x 30A Max120V/240V AC Output Socket (Backup UPS): 1 x 30A Max
Total: 74 x NEMA 5-20R, 120V/20A1 x TT-30, 120V/30A1 x L14-30, 120V/240V/16.7A1 x NEMA 6-20R, 240V/16.7A
<10ms standalone, <20ms with Smart Home Panel 3
10ms
10ms
Up to 180kWh, 36kW
Up to 90kWh, 21.6kW
Up to 36kWh, 12kW
Up to 180kWh, 36kW
Up to 90kWh, 21.6kW
Up to 36kWh, 12kW
YES Auto switchover <20ms when paired with EcoFlow Smart Home Panel 3
YES Auto switchover <20ms when paired with EcoFlow Smart Home Panel 2
Customized WidgetDashboardThird-party Devices IntegrationFuture Electricity Price AnalysisSelf-PoweredTOU ModeScheduled TasksAPIAI Assistant
Customized WidgetDashboardThird-party Devices IntegrationFuture Electricity Price AnalysisGenerator Auto Start/StopSelf-PoweredTOU ModeScheduled TasksAPI
DashboardThird-party Devices IntegrationGenerator Auto Start/StopScheduled TasksAPI
Inverter: 34.5±0.2kg(70.06±0.44 lb)Battery: 50.5±0.2kg(111.3±0.44 lb)
Inverter: 31.7 kg (70 lb) Battery: 50.7 kg (111.8 lb)
Approx. 51.5 kg
Approx. 51.5 kg
Whole-Home Power. Unbound.
12–36kW Output
High Power. High IQ.
DELTA Pro Ultra X scales from 12 to 36kW. With a new Adaptive Start algorithm, it intelligently identifies connected appliances and tailors startup for each, seamlessly handling surges up to 45kW and high-demand appliances like a 5-ton AC.
Get Through Any Outage
12–180kWh Capacity—Power That Lasts
Plug your generator into DELTA Pro Ultra X for seamless backup²
10kW Solar Surge³
10kW Solar Surge³
10kW Solar Surge³
Start with 12kWh. Scale instantly to 180kWh
with up to 30 plug-in expansion batteries—no tools, no hassle. Power grows with your needs.
Plug your generator into DELTA Pro Ultra X for seamless backup.
With the EcoFlow FlowMaster Generator Rectifier, you can charge while delivering up to 12kW output—no downtime, no compromise. Compatible with all major portable generators.
Take in 10kW solar input—enough to recharge 12kWh to 80% in just around 1 hour.
Even during storm season, enjoy a full daily recharge and steady, unshakeable energy.
Compatible with Existing Rooftop Solar
No Wasted Watts
With the EcoFlow Current Sense Transformer, every extra watt is redirected to your DELTA Pro Ultra X Smart Extra battery—never wasted or sold back to the grid for pennies.
The Highest Safety
Standards
The first EV-grade full-tab cells deliver higher capacity with lower resistance, less heat, and longer-lasting performance. 25% More Efficient power flow (thanks to lower resistance: 1.5 mΩ vs. 2 mΩ) 25% Less Self-Heating
Perfectly matched cells ensure identical capacity, voltage, and resistance, minimizing wear and maximizing battery life. 24/7 Self-Maintenance: Automatic SOC balancing maximizes efficiency across the battery’s entire lifespan.
Local BMS – X-Guard® System: 44+ safeguards and comprehensive monitoring ensures all-around safety. Safeguards: overcharge/discharge, extreme temperatures, short circuits, component failures, and more Cloud BMS – Big Data Protection: 100+ anomaly detectors run 24/7, with instant alerts, local service response, and remote emergency support.
Power Protection: 1.2M circuit samples/sec, millisecond-level anomaly detection for inverter and battery. Connection Monitoring: Intelligent cable and interface safeguards track heat, recognize faults, and allow instant shutdown for total electrical security. Load Isolation: Continuous voltage/current monitoring with triple-layer isolation. Faulty devices are cut off automatically while critical loads stay powered.
Heats batteries in extreme cold for safe charging and longer runtime, while high-temp protection allows charging even at up to 45°C (113°F).
Durable battery pack
Dual BMS Protection
Dual BMS Protection
3-Level System Safety Architecture
Smart Extreme-Weather Protection
Dual BMS Protection
What's in the box?
