IMPORTANT RECALL INFORMATION and Firmware Update
Already have an account? Sign In
Ā The portable home battery:Ā DELTA Pro supportsĀ a 3.6kWh capacity that can be expanded all the way to 25kWh. The kicker? You can integrate it directly with your home circuits via the Smart Home Panel. Ideal for home backup.
Power pretty much anything:Ā DELTA Pro leads the industry when it comes to AC output. With 3600W youāve got a portable generator that can power heavy-duty appliances such as dryers, AC units & more. Need even more power? Pair two units together to hit a massive 7200W.Ā Learn more aboutĀ DELTA ProĀ >>
Expandable capacityĀ This add-on battery connects with a DELTA Pro to double total capacity to 7200Wh. Connect two of them to DELTA Pro for a staggering 10.8kWh to use off-grid.
Convenient rechargingĀ Recharging from solar panels, AC outlets, EV charging stations, or our Smart Generator is easy. Plug the Extra Battery into DELTA Pro and they will recharge and discharge in tandem.Ā Learn more aboutĀ DELTA Pro Smart Extra BatteryĀ >>
Adding product to your cart
Please note the difference in voltage between the US and EU. If you are a Ukraine user we will redirect your to the EU site to continue shopping.
Since each region has specific voltage and plug requirements, we'll redirect you to your location.
Youāll be redirected to our Canadian site for a better shopping experience. Hereās a special welcome gift ā use code WELCOMETOCA at checkout!
Your shopping cart is empty
Thank you for subscribing!
