EcoFlow DELTA Solar Generator (PV 220W)
EcoFlow DELTA Solar Generator (PV 220W) EcoFlow DELTA Solar Generator (PV 220W) EcoFlow DELTA Solar Generator (PV 220W) EcoFlow DELTA Solar Generator (PV 220W)
USD $1,299.00
Regular price USD $1,299.00
Sale price USD $1,299.00 Regular price $1,748.00
-$449
The new standard of battery-powered generators: Compatible with a wide range of devices, you can stay powered for hours whenever and wherever.
Charge from 0%-80% within 1 hour:  EcoFlow patent X-Stream Technology empowers EcoFlow DELTA to recharge at 10 times the speed of most battery powered stations in the market.
6x AC Outlets (Total 1800W) & 1260Wh capacity: The large inverter load makes DELTA a power station for home appliances and heavy-duty DIY tools under 1800W (3300W Surge, Pure Sine Wave) with 1260Wh capacity. Learn more about DELTA >>
Two in one EcoFlow’s 220W Bifacial Portable Solar Panel is two in one. With a 220W primary side, and a 175W side on the back for ambient light, you can capture up to 25% more solar energy and charge your portable power station even faster.
Model
EcoFlow App control not supported
Number of Solar Panel
USD $1,299 $1,748 -$449
What is the warranty policy for the Delta 3 Max Plus EB?
3-year basic warranty + 2-year extended warranty upon app registration
Which host devices and ecosystem products is the Delta 3 Max Plus EB compatible with?
The Delta 3 Max Plus Power Pack is compatible with the following hosts and ecosystem products. Select the required capacity for purchase:
Hosts:
Delta 3 & Delta 3 Plus (requires subsequent firmware release for compatibility)
Delta 3 Max Plus
Delta 3 Ultra Plus
Ecosystem Products:
WAVE 2/3 (requires future firmware release for compatibility)
Smart Generator 4000 (Dual Fuel) (requires future firmware release for compatibility)
800W Alternator Charger (requires future firmware release for compatibility)
TIPS: Relevant firmware is anticipated for release after January next year.
How many extra batteries can I connect to DELTA 3 Max Plus (2048Wh)?
DELTA 3 Max Plus (2048Wh) has one Extra Battery Port. You can connect a maximum of two extra batteries via EcoFlow Smart Extra Battery Expansion Adapter.
Can the Delta 3 Max Plus EB be used without connecting to a portable power station?
No, the Delta 3 Max Plus EB features only one Extra Battery Port and can only be used when connected to the main unit.
Stay in the Loop & Save More!
Price Drop Alerts
Cost Savings
Whole-Home Backup
Intelligence Solutions
Thank you for subscribing!
