EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station
USD $684.00
Hot
Hot
Regular price USD $684.00
Sale price USD $684.00 Regular price $1,648.00
-$964
Reliable portable power stations with expandable capacity, fast charging, and long-lasting performance for home backup, outdoor adventures, and off-grid power.
• 1-3kWh expandable capacity with DELTA 2 Smart Extra Battery.
• Huge 1800W AC output (2200W with X-Boost Technology)
• 7 x Faster AC charging
• Built to last 6 x longer
• Control from anywhere
• 5-year warranty
USD $269 USD $599
USD $269 USD $599
USD $269 USD $599
USD $369 USD $799
USD $269 USD $599
USD $269 USD $599
USD $269 USD $599
USD $269 USD $599
USD $299 USD $649
25% Conversion Rate | IP68
USD $369 USD $799
USD $269 USD $599
USD $199 USD $389
USD $199 USD $389
USD $199 USD $389
USD $269 USD $599
USD $684 $1,648 -$964
♻️You’ll get instant credit to purchase a brand-new EcoFlow DELTA 2. Learn more
DELTA 3 Series
AC Charging
Car Charging
Generator Charging
Multi-Charging
Solar Input with 1000W MPPT, Full Charge in 70 Minutes²
EcoFlow DELTA 3 Plus with 500W MPPT × 2 charges fully in 70 minutes, even with limited sunlight. Outdoors, it recharges during lunchtime.
With 1500W max input, it takes 56 minutes to fully charge. During daily use, plug in both AC and solar to charge DELTA 3 Plus, prioritizing solar to save money.
EcoFlow DELTA 3 Series supports 99% of household devices, including refrigerators, TVs, and computers. Plus, with X-Boost, continuously power appliances over 2600W, such as ovens (2150W), hair dryers (1800-2500W), and kettles (1200-2600W). Perfect for home backup, RV, and outdoor usage, this powerhouse ensures you're never left in the dark.
Home backup
Outdoors
RV
Professional work
30 dB Ultra-quiet Operation.
An intelligent energy management system powered by EcoFlow Oasis.
*EcoFlow DELTA 3 Series power stations are compatible with the following Extra Battery models via an Alternator Charger XT150 Output Cable: DELTA 3 Extra Battery, DELTA 2 Extra Battery, DELTA 2 Max Extra Battery, and DELTA Pro 3 Extra Battery.
Smaller Size, Same Power
1 Extra Battery, 5x the Power
LFP Battery
IP65 Battery Pack
BMS
IP65-rated for resistance against water splashes and dust,ensuring durability in various environments. Protects against harsh conditions, providing long-lasting performance.
13 Outputs
Compact and lightweight
Approx. 398x202x283.6mm(16x8.0x11 in)
Approx. 12.5kg(27.6 lb)
1024 Wh
Extra Battery
Supports the following Extra Battery models via an Alternator Charger XT150 Output Cable: DELTA 3 Extra Battery, DELTA 2 Extra Battery, DELTA 2 Max Extra Battery, and DELTA Pro 3 Extra Battery.
Total Output Ports
13
2200W
USB-A Output (Fast Charge)
2 ports, 36W Max
2 ports, 140W Max
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A Max
AC Charging
1500W
2 ports, DC Charge Input, 11V-60V 500W Max*2
1500W
Car Charging
800W, in 1.3 Hour
LFP (LiFePO4 battery)
4000 cycles to 80+% capacity
Connectivity
IP65
UPS
<10ms
Noise
600W<30db;1200W<40db
5 years
Footnotes
* Download the EcoFlow PowerManager App to activate the NAS support function on your computer, then install the NUT Server software on your NAS system, connect your DELTA 3 Plus, and activate HID support. The formal launch version will come later in December.
Thanks for sharing!
