EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station
USD $414.00
Hot
Hot
Regular price USD $399.00
Sale price USD $399.00 Regular price $1,049.00
-$650
Early Black Friday Deals Are Live!
Free 45W Panel ($500+)
Free 2 x 220W Panels! ($3,000+)
Ends in:
During the Promotion Period (Nov 3-Nov 19, PST), customers who purchase from us.ecoflow.com will receive a free gift based on their order value:
1. Spend $500 or more in a single order (calculated before tax) to receive an EcoFlow 45W Portable Solar Panel (valued at $99 USD).
2. Spend $3,000 or more in a single order (calculated before tax) to receive an EcoFlow 2 x 220W Bifacial Portable Solar Panel (valued at $1,298 USD).
* This promotion does not apply to flash sale items, recommended accessories, Power Kits, gift cards, app-only products, member-priced items, DELTA Pro Series, New DELTA Pro Ultra X, Smart Home Panel 3, Smart Gateway, Automatic Transfer Switch.
* Each order is eligible for one free gift only.
Reliable portable power stations with expandable capacity, fast charging, and long-lasting performance for home backup, outdoor adventures, and off-grid power.
• 1-3kWh expandable capacity with DELTA 2 Smart Extra Battery.
• Huge AC output (2200W with X-Boost Technology)
• 7 x Faster AC charging
• Built to last 6 x longer
• Control from anywhere
• 5-year warranty
USD $409 USD $799
USD $289 USD $599
USD $289 USD $599
USD $289 USD $599
USD $289 USD $599
USD $289 USD $599
USD $289 USD $599
USD $399 USD $649
25% Conversion Rate | IP68
USD $409 USD $799
USD $289 USD $599
USD $199 USD $389
USD $199 USD $389
USD $199 USD $389
USD $414 $1,049 -$635
♻️You’ll get instant credit to purchase a brand-new EcoFlow DELTA 2. Learn more
EcoFlow DELTA 2
Power pretty much anything
A 1800W AC output means you can power more than 90% of yoour home appliances. That's your microwave, fridge, or even coffee maker covered in a blackxout. Or, try plugging in up to 15 devices at once for when you're around the table with the farmily. Unlike other brands, DELTA 2 can preventoverloading from devices up to 2200W thanks to X-Boost technology.
Ourdoor
Home backup
Diy
Power 15 Devices at Once
1800W AC Output from 6 Outlets
With a capacity of 1kWh to start with, you've got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA 2 Max Extra Battery to hit 3072Wh. Great for home backup or everyday appliances. Use an extra battery to expand capacity. Great for extended power outages, long camping trips, or your RV.
4 Ways to Charge Up - Ready in Just 50 Mins
Pair with solar panels and charge in as fast as 3-6 hours with 1x400W, 2x220W portable solar panels. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency. That means a more efficient charge than other brands. Pick from a range of solar panels to get the speed you need you need (110W, 160W, 220W, 400W). With that, you've got access to free energy anywhere.
AC Charging
DC Charging
Car Charging
Ready for emergencies.
Control from anywhere.
A simple power outage solution to power your essential home appliances with 1800W AC output by directly connecting the DELTA 2 with your home's power inlet box* with a generator cord for partial home backup. With a plug-and-play design, it's easier than ever to prepare for blackouts. *including transfer switch which has a male L14-30 twist-lock connection that can accept a L14-30 extension cord.
What's in the box?
1024 Wh
Extra Battery
6 outlets, 1800W total (Surge 2700W)
2200W
2 ports, 5V, 2.4A, 12W Max
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A, 38W Max
AC Charging
X-stream Fast Charge 1200W max
AC Input Voltage
100~120V (50Hz/60Hz)
11-60V, 15A, 500W max
Car Charging
Support 12V/24V battery, 8A
DC Charging
1100W
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
27lbs
Net Weight (kg)
12kg
Stay in the Loop & Save More!
Price Drop Alerts
Cost Savings
Whole-Home Backup
Intelligence Solutions
Thank you for subscribing!
