EcoFlow WAVE 2 Portable Air Conditioner with Heater EcoFlow WAVE 2 Portable Air Conditioner with Heater EcoFlow WAVE 2 Portable Air Conditioner with Heater EcoFlow WAVE 2 Portable Air Conditioner with Heater EcoFlow WAVE 2 Portable Air Conditioner with Heater
USD $599.00
Regular price USD $599.00
Sale price USD $599.00 Regular price
-$-599
*For optimal use, a compatible battery may be required and should be purchased separately.
WAVE 2
• 5-minute warmth in any compact space.
• Fastest Cooling and Heating
• Installation-free! Fits Anywhere
• 8 Long Hours of Comfort (With Add-on Battery)
• 44dB: Perfect For Quiet Sleep
• Using R290: A Greener Way to Beat the Heat
• 4 Ways to Charge
Please note that WAVE 2 does not have a built-in battery and requires battery (Add-on Battery or DELTA series) or AC power connected to operate in its optimal performance.
USD $599
The most powerful and compact portable AC that can be used anywhere, anytime
Right Temp. Right Now.
RVs
Trucks
Off-grid houses
Outdoors
Tents
Boats
Fastest Cooling & Heating
The world's first wireless portable AC with heater. EcoFlow's tailor-made compressor enables WAVE 2 to provide 5100 BTUs of cooling and 6100 BTUs of heating. Get ready for the ultimate comfort with WAVE 2!
* Drop 18°F from 86°F for 10m³ in 5 min with 5100 BTUs of cooling,and raise 18°F from 68°F in 5 minutes for 10m³ with 6100 BTUs of heating in optimal running performance.
From Chilly to Cozy in Just 5 Minutes
Warm up your space from 68°F to 86°F with 6,100 BTU of heating power.
Installation-free! Fits anywhere
The perfect air conditioner for any compact space! It is extremely simple to use, requiring no installation or drainage*. There are air duct adapters to fit any space. Enjoy the convenience of cooling and heating without any fuss.
* No drainage is needed in cooling mode when humidity is below 70%, but it is still needed in heating mode.
Peaceful snooze, quiet & long
With EcoFlow's advanced software algorithm, the WAVE 2 offers multiple modes and app control. It runs quietly (44 dB) in Sleep Mode and up to 8 hours in Eco Mode. Experience longer-lasting comfort in your tent, RV, or home with its powerful and portable design.
Eco Mode (8 hours of runtime)
Sleep Mode (As quiet as 44dB)
R290: A greener way to beat the heat
At EcoFlow, eco-friendliness meets ultimate comfort. WAVE 2 uses R290, a natural refrigerant that's clean, green, and perfect for a relaxing cooling experience. With lower global warming potential and no ozone emissions, it's the ideal way to stay cool and comfortable compared to traditional refrigerants while reducing your carbon footprint.
Charge fast, at home or on the go
WAVE 2—the ultimate air conditioner and heater that comes with a swappable battery! Charge it fast with AC, solar, a car, or power stations. Enjoy cool or warm air anytime, anywhere, with the flexibility of multiple charging options.
AC
Power Station
Solar
Car
Part of an ever-growing ecosystem
WAVE 2 is just the start. Pair with an EcoFlow DELTA 2 / DELTA Max or their extra batteries and get an astonishing 7-14hr run time in Eco Mode. Compared to using other portable power stations, it's 28% more efficient. You can also use any portable power station with a 820W input to charge your WAVE 2.
Powerful portability, according to your needs
It’s the most powerful air conditioner of its size by a long shot. Carry it anywhere and attach ducts for directed, efficient cooling. Ideal for tents, RV windows, or placing your unit at a distance.
Air outlet duct (single)
Exhaust air ducts (dual)
Exhaust air ducts (dual) with window vent board
Or accessory-free anywhere
EcoFlow WAVE 2
EcoFlow WAVE 2
Exhaust ducts E
Exhaust ducts E
Exhaust ducts D
Exhaust ducts D
Exhaust duct adapter covers A
Exhaust duct adapter covers B
Exhaust duct adapter covers C
Window vent board
Window vent board
Winder and drain pipe
Safety Instructions, Quick Start Guide, and Warranty Card
AC Input
100/240V, 50/60Hz, 820W Max
Solar Charging Input
11-60V, 13A, 400W Max
Car Charging Input
96W/192W (12/24V, 8A Max)
Add-on Battery Power
700W Max
Approximately 14.5 kg (32.0 lbs)
518 × 297 × 336 mm (20.4 × 11.7 × 13.2 in)
Bluetooth
Wi-Fi
This product supports 2.4G Wi-Fi only
Noise Level
44-56dB
Refrigerant/Amount
R290/130 g
No-Drain Function
Supported (in cooling state)
Cooling Area
≤ 10 ㎡ / 107.6 ft²
IP Rating
IPX4
Rated Cooling Input Power (AC/DC)
550W/495W
Cooling Capacity
1500W/5100BTU
600W/540W
Heating Capacity
1800W / 6100BTU
Operating Temperature
5°C-50°C (41°F-122°F)
Charge Temperature
0°C-45°C (32°F-113°F)
Discharge Temperature
–20°C-50°C (–4°F-122°F)
Ambient Temperature for Storage
–10°C-60°C (14°F-140°F)
Temperature Setting Range
16°C-30°C (60°F-86°F)
