EcoFlow STREAM Ultra EcoFlow STREAM Ultra EcoFlow STREAM Ultra EcoFlow STREAM Ultra
Regular price USD $1,599.00
Sale price USD $1,599.00 Regular price $1,599.00
-$0
Note:
Plug-in Solar installation of this product is currently permitted in Utah,Maryland,Connecticut and Colorado.More states are legalizing plug-in solar — check your local regulations before purchasing.
- Plug-and-play Installation
- 4 MPPT, Max. 2000W Solar Input
- Max.1200W On-Grid AC Output¹
- All-in-One Design with a built-in grid-tied microinverter
- 10-Year Warranty
- NEMA 4 Water-resistant Rating
- LFP Battery,6000 Cycles to 70%
- AI-Powered Smart Energy System
- 10-year warranty
Option Name
USD $1,599
How does it work to utilize solar energy?
As the morning sun rises, EcoFlow STREAM Ultra, equipped with a built-in grid-tied microinverter, immediately captures solar energy for your home and automatically stores any surplus. The stored power runs your appliances at night or during short-term power outages. Generating up to 6424kWh² annually, it meets up to 50% of household needs³ while cutting electricity bills by up to $1027⁴.
Dual-Mode 3,200W Solar Input – Capture More Sunlight for Savings
EcoFlow STREAM Ultra's 4-MPPT design supports 2,000W of solar input, plus an additional 1,200W via the EcoFlow STREAM Microinverter connected to the solar battery—maximizing power generation from every sunlit area.
Max. 1,200W Grid-Tied AC Output⁵ – Power More of Your Home with Solar
EcoFlow STREAM Ultra combines a hybrid inverter and battery into a compact unit that plugs directly into AC sockets (NEMA 5-15/NEMA 5-20) to deliver solar power. Dual AC outlets can power two appliances simultaneously, automatically boosting output to 1,200W for essential household devices.
When the grid is active and STREAM Ultra is connected to your home, your AC circuits run smoothly by fully optimizing solar energy. In an outage, backup power is reserved solely for essential appliances.
Zero Solar Energy Waste – 1.92–11.52kWh Scalable Capacity
EcoFlow STREAM Ultra supports flexible solar storage expansion from 1.92kWh up to 11.52kWh. You can effortlessly expand the storage capacity by simply plugging multiple Ultra units into an AC wall outlet ( NEMA 5-15/NEMA 5-20) in your home. This straightforward DIY expansion method allows you to store surplus solar power for both daytime and nighttime household use. With the EcoFlow STREAM Ultra, you have the flexibility to customize your solar storage system according to your energy needs.
Plug & Play⁶: Start Generating Power in Minutes
No Drilling Required
A flexible, drill-free setup makes it easy to place and move—ideal for renters.
Easy DIY Setup
Quick plug-and-play installation—no electrician needed.
SmartLoad Guardian: Built-In Safety Tech
Our AI-driven system monitors loads in real time, dynamically adjusting power flow to ensure all devices operate safely within certified limits.
All-in-One Engineering Excellence
Compact Solar Design: Save Space with a Smaller Footprint
Engineered with a 50% smaller footprint than conventional systems, our ultra-sleek unit blends seamlessly into your living space with concealed cable routing and flush-mount architecture. Tuck it behind curtains, nestle it beside planters, or wall-mount it as functional art—the anodized aluminium finish complements any décor.
LFP Battery
Retain 70% of capacity after 6,000 deep cycles—lasting three times longer than conventional batteries.
It's running with whisper-quiet
STREAM Series batteries feature a fanless thermal design. Heat generated during operation is efficiently dissipated through the integrated heat dissipation module, ensuring whisper-quiet operation below 30 dB.
Reliable winter performance
The intelligent temperature management system automatically activates heating when the battery drops below 0°C, operates smoothly even at -20°C.
NEMA 4 Water-Resistant Rating
With NEMA 4 rating, the energy storage unit is resistant to rain and dust—ideal for outdoor use.
EcoFlow App – Now Smarter with Eco-AI
Manage energy more efficiently and cut your electricity bills.
AI-TOU (Dynamic Electricity Tariff)
24/7 AI Energy Assistant
The app cross-references electricity tariffs with your usage patterns and hourly weather forecasts to create the optimal bill-saving strategy. It automatically charges your battery during low-rate periods and switches to stored power during peak times. Manual tariff input is also supported⁷.
The app simplifies complex energy data into clear, actionable advice—offering an energy overview and detailed report with a single tap. Control devices using natural commands and get instant support whenever issues arise.
One-Step Portal for Total Control
Status Overview
Monitor all energy data in real time.
Savings Calendar
Track your daily and weekly savings.
Remote Control
Manage connected devices anytime, anywhere.
Solar Energy Indoors
EcoFlow STREAM Ultra uses AC coupling technology, allowing flexible indoor placement. Simply plug in to store solar energy in any room—directly powering appliances like fridges, washing machines, or coffee makers without the mess of extension cables.
Achieve Nearly 50% Solar-Powered Living² – Minimize Energy Bills with AI
Multiple EcoFlow STREAM Ultra units form an AI-powered home energy network. Surplus solar energy automatically transfers between batteries across different rooms, maximizing solar utilization, boosting self-sufficiency, and reducing electricity costs.
DIY Solar System
4-MPPT Design
Flexible panel installation anywhere.
Compatible with EcoFlow STREAM Microinverter
Unlike typical DC systems, EcoFlow STREAM Ultra is an AC-coupled solution that works seamlessly with the EcoFlow STREAM Microinverter—just plug in and save.
One-Step Plug-and-Play Home Solar System
Set up easily in backyards, gardens, rooftops, and more—transform any space into a solar power station.
STREAM Ultra Specs
1.92kWh
Rated Voltage
19.2V⎓
Max.Charging Power
1050W
Max.Discharging Power
1200W
Cell Chemistry & Cycle Life¹
LFP, 6000 cycles to 70% capacity
MPPT(PV Input Power & Voltage)
4 MPPT
2000W (500W × 4)
15V-60V⎓
Max. Input Voltage
60V⎓
Max. Input Current
4 × 14A
Max. Input Short Circuit Current
4 × 20A
Rated AC Output Power (Grid Terminal)
800W
Rated Voltage and Frequency (Grid Terminal)
120V~, 60Hz
Rated Output Current (Grid Terminal)
6.67A
Max. Input (Grid Terminal)
1200W(10A)
Battery Self-Heating
700Low-Temperature Charging Activation (≤5°C)
Ingress Protection Rating
NEMA 4
Operating Temperature²
–20℃ to 55℃
255 × 284 × 458 mm / 10.0 × 11.2 × 18.0 in
Communication
Wi-Fi, Bluetooth
10-Year
Acoustic Noise
<30 dB
Discharge Temperature
–20°C-50°C (–4°F-122°F)
Net. Weight
23.1±0.5kg
Build in Feature
Output Overcurrent Protection, Output Overvoltage Protection, Anti-islanding Protection
Q&A
Are there any electricity billing requirements for grid-connected use of STREAM Ultra? If the requirements are not met, what should I do?
1. Before purchasing or using this product, please confirm whether your household electricity billing supports net metering.2. If net metering is not supported, you need to use the STREAM system with Shelly Pro 3EM configured for single-phase monitorin. Make sure all STREAM Ultra units are installed on the same phase as the Shelly Pro 3EM (with L2 as an example in the figure) to ensure optimal energy management. After installation is complete, open the Feed-in Control in the app's System Settings. Then go to Energy Delivery Strategy, select Smart Meter Monitoring Mode, and link the Shelly Pro 3EM to begin operation.
How can I confirm whether my household electricity billing supports net metering?
Please contact the utility company to confirm whether net metering is supported for your house.
Is STREAM Ultra waterproof and dustproof?
The STREAM Ultra is rated NEMA 4, suitable for indoor/outdoor use. Install in a shaded, ventilated location out of direct sunlight.
Can I extend the EcoFlow STREAM Ultra AC Cable?
No, not supported.
Can the EcoFlow STREAM Ultra AC Cable be plugged into a power strip?
This is not recommended, as malfunctioning devices on the power strip could damage the STREAM Ultra.
Can I install the STREAM Ultra by myself?
The STREAM Ultra can be installed and maintained by users themselves (only available in Utah, USA now).
*Please refer to the Power Connection Requirements section under the Installation Preparation chapter in the Installation Guide to choose the installation method that suits your household situation.
*Each time you change the installation location, please refer to the above information again.
Can the STREAM Microinverter connect to the STREAM Ultra, and what about other (third-party) Microinverters?
Yes, and it supports connecting STREAM Ultra to third-party microinverterson the market through the AC outlets (NEMA 5-15).
Can the product connect to 5GHz Wi-Fi?
Currently, it only supports 2.4GHz Wi-Fi.
Each MPPT of the STREAM Ultra has a maximum power of 500W. Can I connect solar panels with more than 500W to each port?
Yes, as long as the solar panel meets the conditions of operating voltage (15-60V) and operating current (≤14A). This can optimize solar utilization during low sunlight conditions.
How many STREAM Microinverters can the STREAM Ultra support?
Due to regulatory limits, it is recommended to connect no more than one.
Can third-party solar panels be used with the STREAM Ultra?
How does the system continue to supply power during a blackout?
For safety and compliance reasons, the STREAM system will automatically detect a grid anomaly and stop feeding current into the grid during a power outage. You can then plug in your appliances directly into the AC outlets to use internal battery or solar power.
Can the STREAM Ultra be laid flat or inverted?
For better heat dissipation and device longevity, it must be placed upright.
How can I monitor the power generation and consumption of the STREAM Ultra product in real-time?
You can view real-time energy generation statistics on the EcoFlow app.
Does STREAM Ultra need to be connected to Wi-Fi and the EcoFlow app?
STREAM Ultra requires connection to both the EcoFlow app and Wi-Fi to enable full features. Bluetooth or LAN-only access limits functionality such as app automations.
What is required to enable energy balancing between multiple STREAM Ultra units?
The system prioritizes solar energy. When solar generation falls short of the power demand, the battery automatically steps in to make up the difference. If there’s still a shortfall, the grid supplies the remaining power.
When solar output exceeds consumption, the excess energy is first stored in the battery. Any additional surplus can be exported to the grid, depending on your settings and in compliance with local regulations.
Footnote:
1. When using 1 × EcoFlow STREAM Ultra + 1 × EcoFlow STREAM Microinverter together, the system provides a max. 1200W on-grid AC output. When combining 2–6 × EcoFlow STREAM Ultra (with or without 1 × EcoFlow STREAM Microinverter), the system also delivers a max. 1200W on-grid AC output. A single EcoFlow STREAM Ultra (standalone) has a max. 800W On-Grid AC output.
2. Projected power generation values are based on the use of 1 × EcoFlow STREAM Ultra and 1 × EcoFlow STREAM Microinverter under simulated conditions. Calculations assume 5.5 hours of sunlight per day, using the U.S. as an example, factoring in weather variables such as rain throughout the year.
3. The self-consumption rate is calculated using generation estimates from 1 × EcoFlow STREAM Ultra and 1 × EcoFlow STREAM Microinverter, aligned with average annual U.S. household electricity usage. Actual results may vary based on location, climate, and system setup.
4. The estimated savings are based on projected generation from 1 × EcoFlow STREAM Ultra and 1 × EcoFlow STREAM Microinverter, combined with average U.S. electricity rates. Actual savings may differ due to utility pricing, user habits, and environmental conditions.
5. To ensure electricity stability and safety, please familiarize yourself with your local legal requirements for installation, usage, and electrical grid connection of the Product, and consult with local authorities, utilities, and qualified electrical professionals.
6. Due to restrictions under the H.B. 340 Solar Power Amendments, this product is only available for plug-and-play installation within the state of Utah.
7. Currently, only manual input of electricity prices is supported for U.S. specifications. Certain AI features in the EcoFlow app require a premium subscription. Please refer to the EcoFlow app for details on subscription plans and feature availability.
8. Certain AI features in the EcoFlow app require a premium subscription. Please refer to the EcoFlow app for details on subscription plans and feature availability.
9. Due to restrictions under the H.B. 340 Solar Power Amendments, this product is only available for sale and plug-and-play installation in Utah. Please note that you are solely responsible for ensuring your installation and use of the product strictly comply with applicable laws and regulations regarding where the product is intended to be installed/used.
10. Visuals in some materials may differ from the actual U.S.-specification product design and are for illustrative purposes only. For accurate details, refer to the official product specifications or contact EcoFlow Support.
