Buy EcoFlow RIVER Portable Power Station | RIVER Portable Power Station
Regular price USD $349.00
Sale price USD $349.00 Regular price
-$-349
We have suspended the production and sales of this product. Thank you for your interest. We recommend checking out our latest products from the RIVER series.
• 3 x 600W AC OUTLETS AND 288Wh CAPACITY
• RECHARGE FROM 0% TO 80% WITHIN 1 HOUR
• COMPATIBLE WITH 80% HOME APPLIANCES
• FIT YOUR NEEDS, NOW AND LATER
Hit the outdoors with RIVER and keep all your devices powered on at once. With a 288Wh capacity that charges to full in a record-breaking 96 minutes flat, you’ll have ease of mind to focus on your adventures.
X-Stream Fast Charging
Power Multiple Devices
Expandable Battery
Portable
The world’s fastest charging power stations
EcoFlow have the world's fastest charging power stations. RIVER charges from 0-80% in under an hour, or to full in 96 minutes flat.
The centerpiece of your adventure
Power up to 10 devices at once with all the ports you’ll need. Sporting a 288Wh capacity, you’ll have enough juice to charge your phone 21 times, triple your drone’s charge, or make 12 cups of coffee with a coffee maker. Just don’t drink them all at once.
More power to you
EcoFlow’s proprietary X-Boost technology is a game-changer. Switch it on to power high-wattage appliances up to a whopping 1800W. That’s enough to power a hairdryer, a vacuum cleaner, or even a lawnmower
Grab and go
With a sturdy handle on the top of the unit, RIVER is made for when you’re on-the-go.
Take power with you wherever you go
Solar charging
Harness the power of the sun by linking up to two 110W solar panels. You’ll be fully charged in under 3 hours.
Car charging
Heading on a road trip? Charge to full in just 3.5 hours by plugging right into your car with the car adapter.
Wall outlet
Plug into any standard AC wall outlet to fast charge from 0-80% in under 1 hour with X-Stream charging.
Compare The Models
RIVER
Capacity:288Wh
Life Cycles: 500+ Cycle
Output: 600W (Surge 1200W)
AC Input: 250W Max
Solar Input: 200W
$349
RIVER Max
Capacity:576Wh
AC Input: 500W Max
Solar Input: 200W
$599
RIVER Pro
Capacity:720Wh
Life Cycles: 800+ Cycle
AC Input: 660W Max
Solar Input: 200W
$649
Each of the RIVER Series has its advantages. RIVER is ideal for lightweight, grab-and-go power, which you can expand with the extra battery. RIVER Max includes the extra battery by default, which you can remove to go lightweight. RIVER Pro is made for those that need even more capacity for off-grid, long haul adventures.
Yes. RIVER can power devices up to 1800W with our proprietary technology, X-Boost. *X-Boost can run devices that require up to 1800W, however, it’s best to test before use. Some 600W-1800W appliances with strict voltage requirements may not function (eg. air compressors).
Yes. You can control RIVER using your phone. Just link to it in the EcoFlow app to control it from afar.
Yes. You can connect up to 2 sets of 110W solar panels to sustainably charge your RIVER in under 3 hours.
It can be an emergency power source (EPS), which will have the same result as UPS for most electronics. Here's the difference.When your RIVER is plugged into the wall, anything plugged into it gets power from the grid, not its battery. If power from the grid stops, RIVER automatically switches to its battery supply mode within 30 milliseconds. That means anything connected will not have power for 30 milliseconds, which may mean sensitive electronics like desktop computers and data servers turn off. Test your devices individually to see if they need UPS to stay powered.
*11 lbs (5kg)
Dimension
*11.3 x 7.3 x 7.7 in (28.8 x 18.5 x 19.4 cm)
Charge Temperature
32-113°F +/- 5°F (0-45°C +/- 3°C)±
Discharge Temperature
-4-113°F +/- 5°F (-20-45°C +/- 3°C)
Color
Black
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel
Full Recharge Time
1.6 Hours (AC) 3 Hours (12V Car Adaptor) 1.6-3 Hours (Using 2x110W Solar Panels simultaneously with full sun) 2.4-5 Hours (Using 1x160W Solar Panel with full sun)
288Wh - 576Wh (With MAX extra battery)
Cell Chemistry
Lithium-ion
500 Cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
AC Charge Input Power
X-STREAM Charge 250W max/500W Max (With Extra Battery)
AC Charge Input Voltage
100-120Vac(50Hz/60Hz)
Solar Charge Input
200W 10-25V DC 12A max
Car Charger
12V DC 8A max
AC Output (x3)
600W (Surge 1200W) total,120Vac( 50Hz/60Hz)
USB-A Output (x2)
5V DC,2.4A,12W Max, per port
USB-A Fast Charge (x1)
5V/2.4A,9V/2A,12V/1.5A 18W Max
USB-C Output (x1)
5V DC,9V DC,12V DC,15V DC,20V DC,5A,100W Max
Car Power Output (x1)
136W, 13.6V DC, 10A Max
DC5521 Output (x2)
13.6V DC, 3A Max, per port
