Power Every Step of the Trip.
From packing up to winding down, RIVER 520 Gen4 keeps your plans moving.
Tiny. Surprisingly Long-Lasting.
The Smallest & Lightest to Pack.¹
Just 4.6 kg, with a front profile about the size of a small tablet. RIVER Gen4 makes the most of every inch—without compromising power, runtime, or everyday usability.
54% Smaller
than Comparable Models¹
Holds at 99%. Powers at 0%.
99% SOC Retained After 1 Year⁹
Carefully selected cells minimize self-discharge, helping preserve charge during storage.
Power, Even at 0%
Industry-First¹¹ Emergency Power Mode™ safely provides 10-20% extra charge for the iPhone 17 pro even when the power station is at 0%.
The Fastest AC Charging.
4 Ways to Recharge Anywhere.
Recharge quickly via AC, with USB-C, solar, and car charging to keep you ready wherever you go.
* Solar panels without a USB-C output require an additional adapter cable (sold separately)
Power More. All at Once.
Plug In. Juggle Less.
For quick getaways or longer outdoor stays, RIVER Gen4 keeps your gear running so you can stay comfortable and connected.
Useful at Home.
Weekend Ready.
Everyday Backup. Reliable and Quiet.
Move RIVER Gen4 wherever you need power at home—from your home office to your bedside—and keep your devices running longer.
Safe in Storage. Built for the Road.
Designed to preserve power between trips and handle the demands of outdoor adventures.
6,000 Cycles. 15-Year Lifespan.
Enjoy 15 years of power with EV-grade LiFePO₄ cells rated for 6,000 cycles, built for frequent use at home and outdoors.15
24/7 Smart Protection
A smart BMS monitors voltage, current, and temperature in real time, with 40+ built-in protections against overcharging, over-discharging, short circuits, overloads, and overheating.16
Tested for Tough Conditions.
Tested against salt mist, drops, shocks, and vibration, with UN38.3 certification, 0.9 m drop resistance, and a load-bearing capacity of up to 100 kg.16
512Wh
LFP (LiFePO₄)
Approx. 4.6 kg (10.1 lb)
139 × 177 × 229 mm (5.47 × 6.97 × 9.02 in.)
2 ports, 120V~, 60Hz; 500W Total(surge 1000W, X-Boost 1000W)
5–12V ⎓ 3A, 36W Max
USB-C1 Output
5/9/12/15V ⎓ 3A, 20V ⎓ 3.25A, 65W Max, HID
USB-C2 Output
5/9/12/15V ⎓ 3A, 20V ⎓ 5A, 100W Max
USB-C3 Output
5/9/12/15V ⎓ 3A, 20/28V ⎓ 5A, 140W Max
Car Output
12.6V ⎓ 10A, 126W Max
(Via EcoFlow USB-C to 12V Car Outlet Adapter, Optional)
Total Output
740W Max
AC Input
100–120V~, 50/60Hz, 10A Max, 550W Max
USB-C3 Input
Solar/DC Input
11–28V ⎓ 5A (140W Max, DC; 110w Max, Solar)(EcoFlow XT60 to Type-C Charging Cable, Optional, USB-C3 Only)
UPS
<10ms
Years of Warranty
3 years**Includes 2-year standard warranty and 1-year extended warranty available upon EcoFlow App or Official website registration.
Waterproof
IP20
Noise
30 dB, 0.5m/25°C/200W
App
Bluetooth
EMC
Class B
Charging Temperature
0°C–45°C (32°F–113°F)
Discharging/Storage Temperature
−10°C–45°C (14°F–113°F)
Operating Altitude
≤2000 m
• Lower standby power consumption: RIVER Gen4 consumes approximately 1W while powered on, with AC/DC outputs off and no devices connected.
• Better energy retention during storage: When fully charged and stored while powered off, RIVER Gen4 retains approximately 99% SOC after one year. Actual results depend on storage conditions and battery condition.
• Fridge Runtime Boost™: Compatible refrigerators run approximately 15% longer with this mode enabled than with it disabled.
• Emergency Power Mode™: Even when the display shows 0%, RIVER Gen4 can use a small energy reserve to provide emergency phone charging.
• RIVER 520 Gen4: Offers greater capacity and longer runtime, making it better suited to overnight camping, powering multiple devices, or longer emergency backup.
This mode does not add battery capacity and must be enabled in the EcoFlow app before first use. After use, recharge the unit to at least 30% as soon as possible.
Refrigerator compressors can draw 3–8 times their rated power at startup. We therefore recommend AC refrigerators within the following rated power limits:
• RIVER 260 Gen4 (600W surge): Up to 80W.
• RIVER 520 Gen4 (1000W surge): Up to 150W.
Compatible compact refrigerated cabinets and beverage coolers are also supported. Compatibility depends on actual operating conditions.
• Maximum total output: 505W for RIVER 260 Gen4 and 740W for RIVER 520 Gen4, combining simultaneous AC and USB-C output.
• X-Boost: Enables RIVER Gen4 to power compatible appliances above its rated AC output. You can turn X-Boost on or off in the EcoFlow app.
• RIVER 260 Gen4: Up to 505W = 300W AC + 140W USB-C + 65W USB-C.
• RIVER 520 Gen4: Up to 740W = 500W AC + 140W USB-C + 100W USB-C.
The 140W USB-C port uses a dedicated power channel. The other 2× USB-C + 1× USB-A ports share a power module. When two or more devices are connected to this shared group, their combined output is limited to 25W.
For maximum total output, connect high-power USB-C devices to the 140W USB-C port and another high-power USB-C port separately.
The 5W threshold helps distinguish between no connected load and low-power devices that are still running, reducing unintended shutoffs for devices such as Wi-Fi routers and night lights.
Actual charging power depends on solar panel characteristics, sunlight, temperature, and panel angle.
• Compatible USB-C solar panels: Connect to USB-C3 using a USB-C cable that meets the required specifications.
• Non-USB-C solar panels: Connect to USB-C3 using the EcoFlow XT60 to Type-C Charging Cable, sold separately.
Only USB-C3 supports solar input. Input voltage must be within 11–28V, and the panel’s open-circuit voltage must not exceed 28V.
• AC only: Approximately 42 minutes for RIVER 260 Gen4 and 50 minutes for RIVER 520 Gen4.
• AC + solar: Based on theoretical calculations, approximately 40 minutes for RIVER 260 Gen4 and 41 minutes for RIVER 520 Gen4.
Actual charging times depend on input power, ambient temperature, battery condition, and product settings.
For compatible computers, routers, NAS devices, and other equipment, this helps minimize interruptions and reduce the risk of sudden shutdowns and data loss. Devices have different switching-time requirements, so we recommend testing compatibility beforehand.
disclaimer:
1 “Smallest,” “Lightest,” and related “in its class” claims are based on EcoFlow internal analysis of selected commercially available portable power stations with comparable AC outlet configurations, available globally and in selected markets as of Oct. 2026. For RIVER 260 Gen4, comparisons cover models with 245–293Wh capacity and 300–600W rated AC output; for RIVER 520 Gen4, comparisons cover models with 512–518Wh capacity and 500W rated AC output. “Smallest” refers to product volume, calculated from external dimensions (L × W × H), and “lightest” refers to product weight. RIVER product weight and volume data are based on EcoFlow internal laboratory measurements; comparison data are based on publicly available product specifications and EcoFlow internal research conducted in Oct. 2026. Actual product dimensions and weight may vary slightly by model, region, product configuration, and manufacturing tolerances.
2 Charging times and performance are based on EcoFlow internal laboratory testing under controlled conditions. Solar panels without a USB-C output require a compatible adapter cable, which is sold separately unless included in the purchased bundle. USB-C car charging requires a compatible car charging adapter, which may be sold separately. Actual charging speed and performance may vary depending on ambient temperature, battery level, input power, sunlight conditions, solar panel angle, cable, adapter, firmware version, product settings, and usage environment.
3 The “Industry-First Fridge Runtime Boost” claim is based on EcoFlow internal review of comparable portable power stations available in selected markets and their publicly available product features as of Oct. 8, 2026, together with EcoFlow internal testing under standard refrigerator conditions. Actual runtime varies by refrigerator model, food load, ambient temperature, and door openings. EcoFlow disclaims liability for any food spoilage during outages.
4 The 10 ms UPS switchover time is based on EcoFlow internal laboratory testing. This product is not intended for use with medical devices, life-support equipment, or other devices where a power interruption may result in personal injury or property damage. It does not support 0 ms professional UPS applications; please test device compatibility before use.
5 The “54% Smaller” claim is based on EcoFlow’s internal analysis comparing RIVER 520 Gen4 with selected comparable portable power stations. Product volume is calculated from external dimensions (L × W × H). The “33% Smaller Power Board Footprint” and “20% Smaller Battery Pack Volume” claims compare RIVER 260 Gen4 with RIVER 3 within a similar battery capacity range. Actual internal space utilization may vary depending on product model, component configuration, and manufacturing tolerances.
6 Output, port, and total output ratings are based on EcoFlow internal testing. Actual performance may vary depending on connected devices, usage conditions, temperature, battery level, and product settings. X-Boost supports selected devices above the rated AC output by adjusting output voltage. Compatibility varies by device. X-Boost is not recommended for voltage-sensitive equipment or devices with strict voltage requirements.
7 Idle drain data are based on EcoFlow internal laboratory testing under controlled conditions. The “Up to 34% Less Idle Drain” claim is calculated against selected comparable portable power stations tested or analyzed under similar conditions. Actual results may vary depending on AC/DC output status, screen status, connected devices, firmware version, ambient temperature, and product settings.
8 Storage retention data are based on EcoFlow internal laboratory testing under controlled storage conditions. Actual remaining battery level may vary depending on storage temperature, storage duration, initial state of charge, battery condition, firmware version, and product settings.
9 The “10% Longer Runtime” claim is based on EcoFlow internal testing comparing RIVER 520 Gen4 (512Wh) with selected comparable portable power stations with capacities of 512–518Wh under controlled laboratory conditions. The approximately 10% improvement represents the average across the tested low-power AC essentials (≤20W), rather than the improvement at each load. Actual runtime and improvements may vary depending on the connected device and usage conditions.
10 In EcoFlow internal testing under controlled conditions, RIVER 520 Gen4 provided an iPhone 17 Pro with approximately 10–20% additional battery charge after the power station’s displayed battery level reached 0%. Actual results may vary by phone model, battery condition, cable, temperature, and usage during charging. Do not rely solely on Emergency Power Mode for emergency communications, contacting emergency services, or life-safety, medical, rescue, or other critical applications. Maintain independent backup power and communication methods.
11 The “Industry-First Emergency Power Mode” claim is based on EcoFlow’s internal review of comparable portable power stations available in the U.S. and their publicly listed product features as of Oct. 2026. In EcoFlow internal testing under controlled conditions, RIVER 520 Gen4 provided an iPhone 17 Pro with approximately 10–20% additional battery charge after the power station’s displayed battery level reached 0%. Actual results may vary by phone model, battery condition, cable, temperature, and usage during charging. Do not rely solely on Emergency Power Mode for emergency communications, contacting emergency services, or life-safety, medical, rescue, or other critical applications. Maintain independent backup power and communication methods.
12 Runtime figures are based on EcoFlow internal calculations with one device connected at a time. Actual runtime may vary depending on device model, usage behaviour, battery condition, ambient temperature, and product settings.
13 The “Up to 2 h Longer Fridge Runtime” claim is based on EcoFlow’s internal testing under controlled laboratory conditions, comparing the runtime of a refrigerator powered by the RIVER 520 Gen4 with Fridge Runtime Boost enabled versus disabled. Testing was conducted using a DOMETIC 36L refrigerator (model CFX335) with its temperature set to −5°C. Actual runtime improvement may vary depending on the refrigerator model, ambient temperature, frequency of door openings, and battery level.
14 Noise level is based on EcoFlow internal laboratory testing. Measurements were taken at 0.5 m while powering loads below 200W. Actual noise levels may vary depending on load, temperature, fan speed, placement, and ambient conditions.
15 Based on laboratory testing under specified charge and discharge conditions, the battery cell retains 70% of its initial capacity after 6,000 cycles. A theoretical service life of over 15 years is calculated based on one charge cycle per day. Actual results may vary depending on usage and operating conditions.
16 Protection features and durability claims are based on EcoFlow internal testing under controlled laboratory conditions, product design specifications, and applicable certifications. Testing includes salt mist, drop, shock, vibration, and 0.9 m drop resistance. Such testing does not guarantee durability under all real-world conditions or against intentional damage. Actual performance may vary depending on usage conditions, charging behavior, storage environment, temperature, humidity, and maintenance.
