EcoFlow RIVER 3 Plus Portable Power Station | EcoFlow US | RIVER 3 Max (RIVER 3 Plus + Extra Battery 300)
USD $499.00
Regular price USD $499.00
Sale price USD $499.00 Regular price
-$-499
- Compact and lightweight
- 1-hr fast charging, no battery damage
- Up to 220W fast solar charging
- <30 dB whisper quiet for 24/7 use
EcoFlow RIVER 3 Plus Tool Pegboard
USD $39
USD $499
Top-performing home backup power with a pro-grade UPS solution
Ultimate Portable Solar Charging Solution
Power up the RIVER 3 Plus in as fast as 1.5 hours with a 220W solar input. Go even more portable with our 45W Portable Solar Panel (Type-C), which folds down to the size of a laptop and can not only charge the RIVER 3 Plus but also charge electronics directly.
Your reliable companion through outages or in the wild.
Up to 600W output
RIVER 3 Plus is a beast in the small power station game, cranking out up to 600W of rated power. Its X-Boost technology can continuously handle 1200W heating devices without breaking a sweat, keeping 90% of home appliances running smoothly. With an additional built-in light, you'll never get left in the dark.
<10 ms pro-grade auto-switch
Seamless home office and gaming experience
The RIVER 3 Plus provides premium protection with a <10 ms switchover, safeguarding sensitive equipment for home office and gaming experiences against sudden power loss
Comprehensive UPS solution
Safeguard for work and play
Equipped with a 286Wh capacity and 600W output, RIVER 3 Plus can power a 3W Wi-Fi router for up to 35 hours. Plus, it can run pretty much any office appliance, including 600W computers for at least 21 minutes, allowing a safe shutdown and completion of ongoing tasks.
Smart outage alert
Stay alert during power outages with the RIVER 3 Plus, equipped with an LED, app, and software alerts. Its PC and NAS-compatible data interface, along with the EcoFlow software, notifies you and automatically saves data for you when the battery is low.
UPS-friendly design
With two rear AC outlets, conceal your device cables. Plus, monitor UPS in real time on the upgraded screen.
RIVER 3 Plus vs traditional UPS
Up to 2× light and network runtime
Easily handle power outages and extend outdoor stays
With groundbreaking X-GaNPower technology, the RIVER 3 Plus revolutionizes the industry with compact, quiet batteries designed for extended runtimes in small electronics. Leveraging GaN's superior energy efficiency, the RIVER 3 Plus delivers up to twice the operating time for light-wattage appliances, redefining portable power performance.
Extremely compact and lightweight
Handy, convenient on-the-go power
RIVER 3 Plus minimizes heat loss, requires less cooling space, and supports a compact design. It easily fits into small spaces like closets, a minivan, or a bag for easy storage and portability.
< 30 db whisper quiet for 24/7 backup
Quiet backup for peace day and night
With X-GanPower technology, from enhanced heat dissipation, RIVER 3 Plus operates on a library-like silence level, with a volume of less than 30 dB at a distance of 1.5 ft.² You'll have peace day and night guaranteed, even when it's running nonstop.
Expandable up to 858Wh with a wire-free connection
Level up your power with RIVER 3 Plus with an Extra Battery. RIVER 3 Plus can handle either the EB300 (286Wh) or the EB600 (572Wh), Just stack them to get up to 858Wh of pure energy.
Quickly prepare for power outages and outdoor trips
AC charging
Car charging
Generator charging
RIVER 3 Plus fast-charges in 1 hour with X-Stream, no battery damage with vehicle-grade cells and trickle charge technology.
Power up RIVER 3 Plus in only 1.5 hours with 220W solar input. Go even more portable with our 45W Portable Solar Panel (Type-C) and charge electronics directly.
Charge RIVER 3 Plus using your car battery while you drive, making it an ideal choice for on-the-go.
Recharge in just 1 hour with a gas generator for a full day of quiet, safe, and efficient power.
Industry-leading intelligent battery protection
With IP54 battery protection, water damage is minimized. Its robust fire-retardant shell survives rough conditions. Even after a 3 ft (1.5 m) fall, RIVER 3 Plus won't get damaged.
RIVER 3 Plus has a lifespan of 3000 charging cycles. That's around 10 years of everyday use before its capacity drops to 80%.
Featuring an advanced algorithm for cloud-based battery monitoring with 40+ safety measures, RIVER 3 Plus protects against various current, voltage, temperature, and circuit risks.
Upgraded smart control
Convenient, intelligent, customized power control
Product Details
286Wh
9.2×9.1×5.8 in
10.4 lb
UPS
<10 ms
Noise
<30 dB
2 ports, 5V=2.4A, 12W max per port, total 24W
1 port, 5/9/12/15⎓3A Max, 20V⎓5A Max,100W Max
AC Input
100~120V, 10A Max, 50/60Hz, 380W 0-100% in 60 min
Solar Input
220W, 0-100% in as fast as 1.5 hr
Car Input
220W, 11~55V, 0-100% in 3.3 hr
Generator Input
Optimal Operating Temperature
68°F-86°F
Charge Temperature
32°F-113°F
Discharge Temperature
14°F-113°F
Storage Temperature
68°F-86°F
Footnote:
All the test results displayed on the page are based on our internal testing, subject to different conditions, including temperature variations, humidity levels, and equipment calibration standards. Please note that these results are provided for informational purposes only and should not be considered as conclusive evidence for all scenarios. Data was tested in a controlled laboratory environment and actual user experience may vary.
3. The IP54 water-proof rating applies only to the battery pack, not the entire package. It does not prevent water immersion but can prevent fire or explosion in the event of a short circuit if the battery is splashed with water or rain, ensuring user safety and property protection
