EcoFlow RAPID Magnetic Power Bank (5000mAh) EcoFlow RAPID Magnetic Power Bank (5000mAh) EcoFlow RAPID Magnetic Power Bank (5000mAh) EcoFlow RAPID Magnetic Power Bank (5000mAh) EcoFlow RAPID Magnetic Power Bank (5000mAh) EcoFlow RAPID Magnetic Power Bank (5000mAh) EcoFlow RAPID Magnetic Power Bank (5000mAh) EcoFlow RAPID Magnetic Power Bank (5000mAh) EcoFlow RAPID Magnetic Power Bank (5000mAh)
USD $32.99
Free Shipping
Regular price USD $32.99
Sale price USD $32.99 Regular price
-$-32.99
  • Qi2 15W Wireless Charging: Enjoy the ease of 15W wireless charging, which is two times faster than Qi1 7.5W charging and backed by Qi2 certification, ensuring quick, safe, and effective energy top-ups.
  • Ultra-Fast Charging with 30W Built-in Cable: With a 30W built-in cable, you don't need to bring extra cables with you for ultra-fast charging. Enjoy magnetic ease with maximum charging speed wherever you go.
  • Flash Recharging: With 30W input, charge from 0% to 70% in under 33 minutes while you get ready to head out.
  • Compact and Streamlined Design: Experience our compact, lightweight power bank. Small yet mighty, it charges your iPhone 15 Pro 1.1 times. Perfect for life on the go—stay connected always.
  • Built-in Stand for Versatile Use: The kickstand for upright or side view offers hands-free use, doubling as a desktop stand.
Color
Silver
Blue
Black
Charger
EcoFlow RAPID 20W GaN Charger with 60W Cable
USD $12.99 USD $29
EcoFlow RAPID 30W GaN Charger with 60W Cable
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $32.99
Subscribe to get 5% off and updates
Thank you for submission!
X-Stream
Flash charge and recharge with RAPID power
RAPID uses patented X-Stream technology for flagship smartphone-level energy density and fast charging capability. Plus, it works with the PD3.0 protocol for flash charging and recharging. Paired with Qi2-certified wireless charging and a built-in cable design, RAPID ensures snap-on charging convenience with maximum charging speeds.
Qi2-certificated wireless charging that's twice as fast
Max-speed charging with built-in cable
The ultimate fast-recharging power bank
Rely on RAPID for power on the go
With a high output power and multiple charging protocol compatibility, RAPID charges most portable devices, including Macbooks, iPads, Kindles, fitness bands, and earbuds.
Remote Work
On-the-go
Socializing
Give your 13-inch MacBook Air a boost with RAPID 10000mAh for an extra 4 hours of power「5」.
Perfect as a travel charging hub for your iPhone, AirPods, and other essentials, as well as recharging itself at the same time.
Share power with your friends and charge two phones simultaneously.
Built-in stand and strong magnetic connection
Kickstand for upright/side view
Anti-slip Magnetism
1. Place it vertically on a desk, to use your phone as a digital clock or make video calls.
2. Lay it horizontally to comfortably watch movies.
With N52 magnets for a powerful bond and anti-slip components, the power bank and the phone connect smoothly. The power bank holds firmly in place without sliding when the phone is in use.
Exclusive structure maintains a low temp
Using advanced car-grade ultra-low internal resistance technology, along with special internal cooling system, we significantly reduced overheating issues of magnetic charging.
Temperature sensor for real-time monitoring, 4.32 million times per day
RAPID's temperature sensor monitors the power bank 50 times per second, that's more than 4 million daily checks to prevent the power bank from overheating.
Two-year worry-free use
Color
Silver
5000mAh
Ports
C1: Type- C built in cable (input/output)
C2: Type-C Ports (input/output)
Wired Charging Input
30W
Recharging Time
33min-70% 59min-100%
Wired Charging Output
30W
Wireless Charging Output
Qi2.0 15W
Wireless Charging Time
42min - iPhone15 Pro to 50%
Bluetooth
No
Digital Display
No
APP
No
108mm*70mm*14.4mm/4.25*2.76*0.57 inch
Weight
180g/6.35oz
