The all-in-one home energy monitor
Data monitoring
Discover your home's eco-friendly potential
Curious about your home's eco-friendliness? You'll find all the answers here!
Solar power generation
Home energy consumption and sources
Remaining battery
PowerInsight is a comprehensive energy dashboard that lets you easily view your home energy data in real-time, by day, month, or even year.
Energy optimization
Always find a better way to save energy and money
Meet your smart energy optimizer and money saver!
EcoFlow PowerInsight optimizes energy use and saves costs by smartly leveraging battery/solar power, grid feeding, battery timing, and device usage alerts.
Smart device control
Control your devices and run a smart, connected home
Whether you want to turn off all your lights when you leave or crank up the heating before you get home, do it all at the touch of a button.
Using Matter support and smart plugs, control all the connected appliances around your home.
See what works with EcoFlow PowerInsight
Wi-Fi | Matter
*Supported appliances will be added in the future.
- EcoFlow PowerOcean -EcoFlow PowerOcean DC Fit - EcoFlow Smart Plug - EcoFlow PowerPulse -EcoFlow PowerOcean Plus(Three Phrase) -EcoFlow PowerGlow
Third-party devices
- Smart Plugs: Shelly, Tapo, Kasa EP10 - Smart Meters: Shelly 3EM, Shelly pro 3em//Powerfox/ Tibber Pulse IR - Thermostats: EcoBee, Google Nest, Ecobee,Tado
Matter
- Smart Lights - Smart Plugs and Outlets - Thermostats and Other Temperature Controllers
- More to come: Smart Locks, Contact Sensors
Temperature auto-adjustment
Stay comfortable while saving energy
With a built-in indoor temperature sensor, PowerInsight adjusts your home's climate so it's always just right. By constantly monitoring the air temp, you're lowering energy use and your bills.
Why choose EcoFlow PowerInsight?
Wall bracket
Power Cable (USB-C to USB-C)
Screw (4×30mm) *4 & Anchor (Ø6×27mm)*4
Quick Start Guide & Warranty Card
Specifications
Specifications
244.4mm*158.6mm*12.4mm (H*W*D)
Weight
Approx. 600g
Color
Black
Button
Power on/off
Size
10.1 inch
Type
IPS
Resolution
1280 x 800 pixels
Screen
10-point multi touch
CPU
MT8168
ROM
16GB
RAM
2GB
Battery
3000mAh
Charging
5V/2A charging, Pogo Pin charger
WLAN
802.11 a/b/g/n/ac 2.4GHz, 5GHz
Bluetooth
Bluetooth 5.0
Sensors
Temperature and Humidity Sensor Ambient Light Sensor Proximity Sensor
Where can I place my EcoFlow PowerInsight?
There are two ways to place it: on the wall or on flat surfaces.
1. On the Wall: You can fix the bracket to the wall, and then place PowerInsight onto the bracket. (The bracket and the fixing screws required for installation are included in the installation list.)
2. On Flat Surfaces: Place it on a stand holder (not included in the box) like a tablet.
Does it support expandable memory card?
No.
How is it different from running the app on a tablet? Can I use a third-party tablet instead of PowerInsight?
It cannot be completely replaced. PowerInsight has the following advantages:
1. PowerInsight comes with a 10.1-inch screen and a customized information interface, allowing users to obtain key energy management information at a glance. The operation is simple, with fast mode/scene adjustment capabilities, and handy functions such as network configuration, device sharing, and service acquisition.
2. PowerInsight supports offline data storage. Even if there is no Internet connection, you can still view the connected device and store data normally. (LAN control function is currently under development.)
3. Automatic control and adjustment with several built-in sensors at your fingertips.
4. PowerInsight supports the Matter protocol, which allows you to connect more home smart devices.
Can one of the two Type-C ports of the bracket be used for output?
No, the Type-C port cannot be used for output.
Do I need to keep it plugged in?
The product has a built-in 3000mAh battery that provides a battery life of over 3 hours.
Does it support smart voice?
No.
What EcoFlow products can it be used with?
Currently it supports EcoFlow PowerOcean (three-phase), EcoFlow PowerOcean DC Fit, EcoFlow Smart Home Panel 2, and EcoFlow DELTA Pro Ultra. More products will be supported in the future. Please stay updated by visiting our official website for the latest information.
What third-party products can it be used with?
The third-party Matter device categories that we plan to support include lighting, smart plugs/outlets, and HVAC devices. PowerInsight currently supports Shelly smart plugs and Ecobee thermostats. More products will be supported in the future. Please stay updated by visiting our official website for the latest information.
Does it support the simultaneous use of multiple sets of PowerInsight?
PowerInsight supports multiple logins with one account, with no upper limit.
Can I update firmware for connected products using PowerInsight?
Currently not available.
Can I remotely control the power on and off of products using PowerInsight?
Are there any sensors built into it?
Yes, it is equipped with 3 types of built-in sensors for temperature and humidity sensing, ambient light sensing, and proximity sensing. It can detect ambient temperature/light and execute corresponding strategies, and also detect if someone is near the device to determine whether to automatically wake up the screen.
Does it support LAN connection and control?
What is Matter?
Matter is a relatively new communication protocol used in smart home devices. Matter offers significant advantages in interoperability, simplicity, security, compatibility, and scalability.
How to add Matter devices to the EcoFlow ecosystem?
The steps are as follows:
1. Bind PowerInsight and EcoFlow app. Click [Settings] > [Matter] > [Bind Matter] on PowerInsight. The QR code will be displayed on the screen. Then click [+] > [Scan] on EcoFlow app to scan the QR code on the PowerInsight screen to complete the binding.
2. Add Matter devices to EcoFlow app. Use EcoFlow app to scan the QR code of the Matter device to complete the connection.
Can I use EcoFlow app to scan the Matter QR code of EcoFlow Smart Plug to add this device?
No. To add an EcoFlow Smart Plug, please click [+] > [Add Device] in EcoFlow app to complete the addition. This method can obtain more device data and intelligent services than adding by scanning the Matter QR code.
What are the requirements for the mobile phone and the Wi-Fi connection to PowerInsight when adding Matter devices?
1. When adding a Matter device, the mobile phone needs to be connected to a 2.4G Wi-Fi band.
2. When the mobile phone and PowerInsight's [Matter network] are connected to a dual-band Wi-Fi, routers from some manufacturers may not support adding Matter devices. If you encounter failure to add a device under a dual-band router, you can change the connection to a 2.4G band router and try again.
How many Matter devices can be added to one account?
Currently, up to 16 devices are supported to be added to one account, and we plan to add more in the future.
Choosing a selection results in a full page refresh.
Press the space key then arrow keys to make a selection.
Are you a Ukraine user?
Please note the difference in voltage between the US and EU. If you are a Ukraine user we will redirect your to the EU site to continue shopping.
Welcome to EcoFlow US
Since each region has specific voltage and plug requirements, we'll redirect you to your location.
Shopping from Canada?
You’ll be redirected to our Canadian site for a better shopping experience. Here’s a special welcome gift — use code WELCOMETOCA at checkout!
Shopping Cart
My Shopping Cart
