12V 100Ah Marine Trolling Motor Battery | EcoFlow US | EcoFlow Lithium 12V 100Ah Deep Cycle Marine Trolling Motor Battery + Power Hat(Large-XLarge)
EcoFlow Lithium 12V 100Ah Deep Cycle Marine Trolling Motor Battery EcoFlow Lithium 12V 100Ah Deep Cycle Marine Trolling Motor Battery EcoFlow Lithium 12V 100Ah Deep Cycle Marine Trolling Motor Battery EcoFlow Lithium 12V 100Ah Deep Cycle Marine Trolling Motor Battery EcoFlow Lithium 12V 100Ah Deep Cycle Marine Trolling Motor Battery EcoFlow Lithium 12V 100Ah Deep Cycle Marine Trolling Motor Battery
USD $358.00
Regular price USD $358.00
Sale price USD $358.00 Regular price $448.00
-$90
- Best lithium battery for 30–70 lb trolling motors
- 300A@30s instantaneous output current, for smoother and more precise control of the trolling motor.
- 1280Wh capacity, 1280W continuous output
- Best-in-class EV-grade LFP cells with 6000+ cycles
- 5-year warranty, UL1973, FCC, UN38.3, RoHS certified
- 50% less weight, 50% more energy than lead acid
- IP65 waterproof rating
- X-Guard BMS with low-temp cut-off
- Highest-level UL5VA flame-retardant casing
USD $358 $448 -$90
2× Capacity, ½ the Weight
Lithium v.s. Lead-acid 12V Battery
Twice the capacity, half the weight, and lasts 12 times longer with a lifetime cost of only $0.03/kWh.
Extended Power and Flexibility
Expandable Up to 20.48kW
Our 12V battery is designed to start your boat's trolling motor with a continuous output of 1800W and a peak output current of 300A.
Add more batteries to power your RV, cabin or off- grid workshop for even longer.
12V Trolling Motor
RV
Off-grid Cabin
Workshop
Make Long-Term Savings
A Cost-Effective Solution
Our battery offers a low lifetime cost of just $0.03 per kWh, that's $250 for 1.28kWh over 6000 cycles. It boasts the lowest lifetime cost among LFP 12V batteries in the industry, ensuring you save money while enjoying reliable, hassle-free power.
Robust and Secure
Experience Superior Battery Protection
X-Guard provides fail-safe protection and unmatched durability, ensuring optimal performance even in harsh conditions.
Advanced Battery Safety System
The structure system securely fixes battery cells, boosting safety and reliability. Fireproof foam is used for cell and pack fixation, offering protection, vibration and friction reduction, short circuit prevention, damage resistance, and excellent thermal insulation.
Unmatched Protection
Our X-Guard BMS provides round-the-clock safety with six features: low temp, over-discharge, overcharge, high temp, short circuit, and overcurrent protection, ensuring safer recovery than most lead-acid batteries without a BMS. With dual-channel CMOS protection, it secures optimal performance & safety even in severe weather or during faults.
Water-Resistant & Temperature Safe
Experience enhanced safety with vehicle-grade LFP battery cells. Meeting top UL9540 standards, this 12V battery is designed to minimize heat and resist water, even from low-pressure jets. With a 5VA-grade, self-extinguishing casing, it automatically extinguishes itself within 30 seconds in the unlikely event of a fire, preventing the risk of flames spreading.
Compact and Durable
Small Size, Big Power
With an 8% smaller volume than lead-acid, the EcoFlow 12V 100Ah Lithium Battery can fit into small spaces for storage and acts as a slot-in replacement for Group 27-31 batteries. Its built-in handle makes it convenient to carry or move whenever you need to.
Stay Powered Anywhere
3 Fast Charging Methods
Charge the EcoFlow 12V 100Ah Lithium Battery using solar, generator, or from the grid, so no matter where you are, there's an option. Fully charge in as fast as 2 hours, 6 times quicker than lead-acid batteries.
Loved by 3,000,000+ users
EcoFlow is sold in more than 100 countries and regions, with a user base of 3,000,000+ worldwide. Our products are at the forefront of industry technology and have been certified and affirmed by tech media and awards. We are authorized as official strategic partners by major RV and outdoor industry companies.
Quality Services You Can Expect
Cell Type
LiFePO4
6000 cycles at 80% DOD
Nominal Voltage
12.8V
Rated Capacity
100Ah
Energy
1280Wh
Max. Expansion (Parallel&Series)
4P4S, 2S8P
Certifications
IEC62619, UL 1973
BMS
100A
Max. Continuous Output Power
1280W
Max. Continuous Charge Current
100A
Max. Continuous Discharge Current
100A
Max. Discharge Current 30 Seconds
300A
Charge Method
CC/CV
Charge Voltage
14.4V±0.2V
Recommend Charge Current
50A(0.5C)
Charge Operating Temperature
32℉ to 131℉
Discharge Operating Temperature
-14℉ to 131℉
Storage Temperature
32℉ to 113℉
Terminals
M8 bolts
Weight
26.7 lb
Size
11.4 x 6.9 x 8.7 in
Protection Class
IP65
5 years
