EcoFlow WAVE 3 Portable Air Conditioner with Heater | WAVE 3 + DELTA Pro
EcoFlow WAVE 3 Portable Air Conditioner with Heater EcoFlow WAVE 3 Portable Air Conditioner with Heater EcoFlow WAVE 3 Portable Air Conditioner with Heater EcoFlow WAVE 3 Portable Air Conditioner with Heater EcoFlow WAVE 3 Portable Air Conditioner with Heater EcoFlow WAVE 3 Portable Air Conditioner with Heater EcoFlow WAVE 3 Portable Air Conditioner with Heater EcoFlow WAVE 3 Portable Air Conditioner with Heater EcoFlow WAVE 3 Portable Air Conditioner with Heater EcoFlow WAVE 3 Portable Air Conditioner with Heater EcoFlow WAVE 3 Portable Air Conditioner with Heater EcoFlow WAVE 3 Portable Air Conditioner with Heater EcoFlow WAVE 3 Portable Air Conditioner with Heater EcoFlow WAVE 3 Portable Air Conditioner with Heater
USD $2,399.00
Hot
Hot
Regular price USD $2,399.00
Sale price USD $2,399.00 Regular price $4,998.00
-$2,599
1. Exceptional cooling and heating: 6100 BTU cooling capacity and 6800 BTU heating capacity.
2. Wireless and portable: Supports 8 hours of continuous wireless use.
3. Fast Cooling: Rapid temperature change in just 15 minutes.
4. Hassle-free installation: Insulated Exhaust Duct adapts to various outdoor scenes for easy installation, suitable for any outdoor scenario.
5. Smart App: One-click simple control.
6. Multiple Charging Options: Ensures a continuous, uninterrupted outdoor comfort experience.
7. 2-Year Warranty.
EcoFlow WAVE 2 Add-on Battery
USD $429 USD $899
For WAVE 2 / WAVE 3, Lowest Price
EcoFlow WAVE 3 Add-on Battery
USD $699 USD $899
USD $199 USD $389
EcoFlow WAVE Series Silver Protection Bag
USD $159
USD $199 USD $389
USD $699 USD $899
USD $199 USD $389
USD $699 USD $899
USD $199 USD $389
USD $699 USD $899
USD $199 USD $389
USD $699 USD $899
USD $199 USD $389
USD $699 USD $899
USD $199 USD $389
USD $699 USD $899
USD $199 USD $389
USD $699 USD $899
USD $199 USD $389
USD $699 USD $899
USD $699 USD $899
USD $269 USD $599
USD $199 USD $389
USD $699 USD $899
USD $199 USD $389
USD $699 USD $899
Please note that WAVE 3 does not have a built-in battery and requires battery (Add-on Battery or DELTA series) or AC power connected to operate in its optimal performance.
USD $2,399 $4,998 -$2,599
Why EcoFlow WAVE 3 Stands Out
Built for Every Scenario
Car Camping
Tent Camping
RV Adventures
Outdoor Fun
Indoor Spaces
Semi-Trucks
Boating
Rapid cooling and heating
6100 BTU cooling power & 6800 BTU heating power
Drop 15℉ in just 15 minutes [1] with 6100 BTU power, setting an ideal environment for any scenario. Quickly warm up with 6800 BTU heating, raising the temperature by 17°F in just 15 minutes [2], perfect for staying cozy during chilly outdoor activities like autumn camping.
8 Hours of Wireless Comfort
1024Wh LFP Add-On Battery
The add-on battery offers up to 8 hours of uninterrupted use [3]—perfect for a full night of restful sleep. High-quality LFP cells ensure a lifespan of up to 10 years in daily use.
It's All on the App
Powered by EcoFlow Oasis
Easily manage everything from real-time battery status to water drain notifications, mode changes, and scheduled shutdowns—all from your phone, no matter where you are.
Intelligent Modes for Maximum Comfort
Automatic Function
Pet Care
Dehumidification Function
Sleep Mode
Water Drain Alert
Automatically switches to heating when temperatures drop, keeping you cozy even on chilly mountain camping trips, ensuring a good night's sleep.
Set a temperature range of 77°F to 113°F via the app to protect your pet from heatstroke indoors. Once the set temperature is exceeded, WAVE 3 automatically starts cooling and sends you an app notification.
Adjusts humidity to your desired level, so you can stay comfortable, even during rainy seasons.
Operates at just 44 dB, about the same as a quiet conversation, ensuring peaceful rest.
When the water tank nears full, the app sends a reminder to drain it, ensuring optimal performance.
Endless Cooling On the Go
Fast charging in just 75 min
By combining AC charging and solar charging, the Add-On Battery can be fully charged in as fast as 75 minutes. With the EcoFlow Alternator Charger, you can charge while driving—1 hour of driving, and stay comfortable all night.
Solar Charging (400W)
EcoFlow Alternator Charger (400W/800W)
AC Charging (700W)
Car Power Outlet (100W)
Fully charged in 3 hours. Charging port: XT60 on the Add-On Battery.
Charge while driving. In 102 minutes, you're ready to go. Charging port: Both WAVE 3 and Add-On Battery (not recommended to use WAVE 3 directly due to unstable power).
Fully charged in 2 hours. Charging port: XT150 on WAVE 3 and Add-On Battery.
Emergency charging in 10 hours. Charging port: XT60 on the Add-On Battery.
What's In The Box?
EcoFlow WAVE 3
EcoFlow WAVE 3 Add-On Battery
WAVE 3 Specs
Approximately 33.7 lb (15.3 kg)
20.4×11.7×13.2 in (519×297×336 mm)
Cooling Capacity
6100BTU (1800W)
Heating Capacity
6800BTU (2000W)
Temperature Setting Range
60.8-86℉ (16-30℃)
Refrigerant/Amount
R290/0.25 lb (R290/112 g)
Air Volume
330m³/h
Rated Cooling Power (AC/DC)
690W/640W
645W/606W
Cooling Efficiency (AC/DC)
2.6/2.8
Heating Efficiency (AC/DC)
3.1/3.3
AC Input
100-240V~50/60 Hz, 820W Max
Add-on Battery Input
700W Max
Operating Temperature
41-122℉ (5-50℃)
IP Rating
IPX4
Noise Level
44-58 dB
Remote Control
App (Wi-Fi(2.4G, 5G), Bluetooth)
Run Time with EcoFlow Add-On Battery
2-8 hr
WAVE 3 Add-On Battery Specs
Approximately 21.4 lb (9.7 kg)
20.3×11.1×4.4 in (516×281×111 mm)
Battery Capacity
1024Wh 51.2V 20Ah
80%+ capacity after 4000 cycles
Maximum Input Power
1000W Max
Automobile Auxiliary Power Outlet Charging Input
12V/24V,8A Max, 200W Max
Solar Input
11-60V, 13A Max, 400W Max
Maximum Output Power
858W Max
5/9/12V, 2.4/2/1.5A, 18W Max
5/9/12/15V⎓3A Max; 20V/28V⎓5A Max, 140W Max
Charge Temperature
32-113℉ (0-45℃)
Discharge Temperature
14-122℉ (-10-50℃)
IP Rating
IP65
Thanks for sharing!
