EcoFlow RAPID Pro Power Bank + RAPID Mag Qi2.2 Power Bank + 140W Charg | Black / RAPID Pro X Power Bank (27650mAh | 300W) / RAPID Pro Charger (140W | 4 Ports | GaN)
EcoFlow RAPID Pro Power Bank + RAPID Mag Qi2.2 Power Bank + 140W Charger EcoFlow RAPID Pro Power Bank + RAPID Mag Qi2.2 Power Bank + 140W Charger EcoFlow RAPID Pro Power Bank + RAPID Mag Qi2.2 Power Bank + 140W Charger EcoFlow RAPID Pro Power Bank + RAPID Mag Qi2.2 Power Bank + 140W Charger
USD $326.97
Free Shipping
Regular price USD $326.97
Sale price USD $326.97 Regular price
-$-326.97
RAPID Pro X:
1. Compact Size, Huge Power: 27,650 mAh (99.54 Wh) Air-travel-friendly.
2. Fast Recharging Speed: 20 min to recharge to 80% using the EcoFlow RAPID Pro 320W Charging Station.
3. 300W Multi-Device Charging
4. Fast Multi-Device Charging: Total output (3 ports): 300W, 1 × 140W USB-C port, 2 × 65W USB-C ports.
5. Modular Design: Detachable magnetic cases to match your style.
6. Smart LCD Screen: View power status, customize standby display.
7. Smart Power Control via the EcoFlow App: Set up battery optimization mode to extend the battery life of both the power bank and devices while charging.
Your Complete Kit: EcoFlow RAPID Pro X Power Bank (27,650mAh, 300W) and EcoFlow RAPID Pro X Magnetic Block (60cm Retractable Cable) included. Backed by a 24-month warranty, it's your hassle-free travel companion.
RAPID Pro Power Bank (27,650 mAh, 300W, 140W Built-in-Cabe):
1. Compact Size, Huge Power: 27,650mAh (99.54Wh) Air-travel-friendly.
2. Fast Recharging Speed: 20 min to recharge to 80% using EcoFlow RAPID Pro 320W Charging Station.
4. High Wattage for Laptop Charging: 140W (Max) USB-C.
5. Fast Multi-Device Charging: Total output (4 ports): 300W, 1 × 140W retractable USB-C cable, 1 × 140W USB-C port, 2 × 65W USB-C ports.
6. Modular Design: Detachable magnetic cases to match your style.
7. Smart LCD Screen: View power status, customize standby display.
8. Smart Power Control via the EcoFlow App: Set up battery optimization mode to extend the battery life of both the power bank and devices while charging.
9. Integrated 60 cm Built-in Cable: There's no need to carry extras. Just pull out the cable and charge.
RAPID Mag Qi2.2 Power Bank (10K mAh, 25W, Built-in USB-C Cable):
1. Qi2.2 25W Wireless Charging: Experience next-level wireless 25W Qi2.2 fast charging—over 3× faster than Qi1 and fully optimized for iPhone 17 to deliver safe, reliable and efficient power quickly whenever you need it.
2. 36W Max-Speed Wired Charging: Fast-charge your iPhone with the built-in 36W USB-C cable. Power up to three devices at once—no extra cables needed.
3. 10,000mAh in Your Pocket: Slim enough to slip into your pocket, yet powerful enough to charge your iPhone 16 up to 1.9 times. RAPID’s 10,000mAh battery gives you all-day power without the bulk.
4. Ultra-Strong Magnetic Hold: No slips, no stress—RAPID Mag’s 11N magnetic grip keeps your phone attached securely during bumpy commutes, workouts, or the typical daily grind.
Charge While Recharging: RAPID Mag powers your phone and recharges itself at the same time. Wake up ready to go with everything fully charged.
5. Built-in Stand for Versatile Use: The kickstand offers hands-free upright or side-viewing and also serves as a desktop stand.
RAPID Pro Charger (140W, 4 Ports, GaN):
1. 4-in-1 Charger, Charge Four Devices at Once: Power up your laptop, phone, and earbuds simultaneously with one multi-port fast charger.
2. Fast, Cool, & Safe Charging: Advanced temperature control technology reduces power output to prevent overheating. Real-time monitoring protects both your charger and devices. For added peace of mind, in the rare event of a fire, built-in flame-retardant tech extinguishes flames within 10 seconds—no dripping or reigniting.
3. Built to Last: The AC plug endures over 5,000 plug-and-unplug cycles without causing wear and tear—sturdy and reliable for the long haul.
4. Compact & Travel-Ready: Lightweight and space-saving design makes it easy to pack and carry. Protective build keeps the plug safe from being damaged. Dimensions: 67 × 63 × 31 mm / 2.64 × 2.48 × 1.22 in
RAPID Mag Qi2.2 Magnetic Power Bank (10,000mAh, 25W, Built-in USB-C Cable)
RAPID Pro Charger
USD $326.97
Subscribe to get 5% off and updates
Thank you for submission!
EcoFlow RAPID Pro Charging System
Superior Performance
Leading Fast Recharging
Ultra Fast Multi-Device Charging
Superior Safety
Premium and Compact Design
Charging
Style
Screen
Easy to carry and reduces cable tangling — just snap on to start charging
- Detachable cases with magnetic attachment
- Limited Edition cases sold separately (2 styles available)
Equipped with a 3.9-inch LCD screen, view power status and standby graphics at a glance. Set your favourite theme for your standby display, or create your own graphic via the EcoFlow Power Management app.
In-app Power Management & Customisation
* Custom copy feature coming soon.
One Power Solution for Every Situation
Remote Work
Travel
Entertainment
Office Work
Remote Work
Remote Work
Remote Work
Remote Work
Travel
Travel
Entertainment
Entertainment
Entertainment
Entertainment
Entertainment
Entertainment
Office Work
Office Work
4 Devices charging at Once
Compatible with 99% of everyday electronic devices.
Single-Port Charging
Two-Port Charging
Three-Port Charging
Four-Port Charging
Learn More About EcoFlow
Specifications
Total Cell Capacity
27650mAh(99.54Wh)
56.51*63.95*151.98mm
700g
Total Output
300W
Single Output
C1:140W
C2/C3: 65W
Outlets
3
Input
320W
APP Support
Yes
Screen Display
LCD
Which devices are compatible?
Compatible devices are laptops, phones, tablets, headphones, smartwatches, game consoles and other devices with USB-C ports such as MacBook Pro/Air, iPhone,iPad, Dell XPS and Samsung Galaxy.
What protocols does RAPID Pro power bank support, what is the power distribution for charging and discharging, and does it support chaging and discharging at the same time?
Supports pass-through charging, with the power level depending on the power requirements of the devices connected to each port.
Input supports PD3.1 protocol and is compatible with PD3.0 PPS, QC3.0, AFC, BC1.2;
Output supports PD3.1 protocol and is compatible with PD3.0 PPS, QC3.0, AFC, Apple2.4A, BC1.2, SCP, FCP, UFCS
Why does the power bank provide less electricity than expected?
There will usually be a difference from what is expected, with the capacity reduction mainly due to energy losses in the battery and the conversion circuit.
How to keep the power bank charging and discharging quickly?
To ensure fast and stable charging and discharging performance when using the power bank, we recommend the following.
1. Choose the Right Charger:
Use a charger that supports fast charging protocols and has a high output power (such as PD 65W or 100W). Avoid using low-power chargers (such as 5V/1A).
2. Use a Good Charging Cable:
Select original or high-quality fast charging cables (such as those supporting 5A, 240W). Keep connectors clean and secure, and avoid excessively long cables.
3. Device Compatibility:
Make sure the connected devices support fast charging protocols; otherwise, fast charging will not be achieved.
Can the RAPID Pro power bank be taken on the plane?
Yes, according to regulations by the International Civil Aviation Organization (ICAO) and most airlines, carrying a power bank with a capacity under 100Wh is allowed. The RAPID Pro, with a capacity of 27650mAh (99.54Wh), meets this requirement and can be carried on board without concern.
Battery life and temperature FAQs
The power bank retains over 80% of its battery capacity after 300 charge cycles. It supports charging and discharging at altitudes below 3000 meters and in environments with temperatures between 0°C and 40°C. If not used for an extended period, it is recommended to store the power bank in an environment between -20°C and 40°C and to recharge it at least once every three months.
Can it be used directly after unboxing?
Yes, the product supports plug-and-play. However, as the product features are continuously being updated and improved, it is recommended to connect to the app and upgrade to the latest firmware for a better user experience.
What are the functions of using the APP? Is it necessary to connect to the app to use it?
The app supports functions such as power monitoring, firmware upgrades, device management, theme switching, and charging strategy settings. Not connecting the power bank to the app does not affect its normal charging and discharging functions.
How do I connect the RAPID Pro power bank to the EcoFlow application via Wi-Fi/Bluetooth?
On the device screen, go to “Settings” > “Wi-Fi & BLE”, then press the confirm button to turn on the switch.
On the phone used to log into the app, make sure Bluetooth is enabled.
Wi-Fi Connection:
On the app homepage, tap the “+” icon in the top right corner to enter the device search page. You will be redirected to the pairing page.
Select the Wi-Fi network you want to connect to, enter the password, and tap “Next” to connect.
Once the connection is successful, the app will navigate to the device page, where a Wi-Fi icon will appear at the top of the screen.
(Note: Only 2.4GHz Wi-Fi is supported. If the connection fails, please follow the on-screen instructions to retry.)
Bluetooth Connection:
On the pairing page, tap “Set up later” at the bottom to skip Wi-Fi configuration.
You will be redirected to the device page, and a Bluetooth icon at the top will indicate a successful Bluetooth connection.
You can also tap the cloud icon in the top right corner of the device page while in Bluetooth mode to enter the Wi-Fi setup process.
Select your Wi-Fi network, enter the password, and complete the connection.
Does it support pass-through charging? Why does it sometimes not work?
Yes, the power bank supports pass-through charging. However, a charger with a rated power of 20W or higher is required, and the input must be greater than output power to ensure the full load operation of the device.
Why is the clock screensaver not showing on the display?
The clock screensaver is turned off by default at the factory. If it’s not enabled, the screen won’t display the time.To enable it, please follow these steps:
1.Open the EcoFlow App
2.Connect your power bank
3.Go to settings and turn on the “Clock ” option
Why are the watch module and glow-in-the-dark case not included in the package?
The watch module and glow-in-the-dark case are optional accessories and must be purchased separately. They are not included in the standard package.
¹ Airline regulations vary by region and carrier. Please confirm battery restrictions with your airline before travel.
² Phone model dependent
