EcoFlow GLACIER Classic Portable Fridge Freezer | 55L / GLACIER Plug-in Battery + 60W Solar Panel
EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer EcoFlow GLACIER Classic Portable Fridge Freezer
USD $988.00
Regular price USD $988.00
Sale price USD $988.00 Regular price $1,637.00
-$649
1. Dual-Zone Design (45L & 55L only): Keep fresh and frozen foods separate, with a maximum temperature difference of 39.6 °F maintained within ±1.8°F for ultimate freshness.
2. High Capacity: Holds up to 58 cans (35L), 72 cans (45L), or 90 cans (55L) of 330ml soda.
3. Extended Off-Grid Operation: The 298Wh plug-in battery maintains items at 39°F for up to 43 hours (35L) or 39 hours (45L/55L).
4. Enhanced Insulation: Featuring 2-inch foam and superior sealing to keep contents colder longer while minimising temperature fluctuations and leakage.
5. Efficient Cooling: A high-efficiency copper wire compressor cools more rapidly with less power, thereby extending battery life during off-grid use.
6. Smart App Control: Enjoy simple, one-click control.
7. Versatile Charging Options: Multiple charging methods ensure continuous, uninterrupted outdoor comfort.
8. 2-Year Warranty
Accessories
USD $149 USD $299
EcoFlow GLACIER XT60-2.5m Cable
USD $39
USD $149 USD $299
USD $149 USD $299
USD $149 USD $299
USD $149 USD $299
USD $149 USD $299
USD $39
USD $149 USD $299
USD $39
USD $149 USD $299
USD $149 USD $299
USD $149 USD $299
USD $149 USD $299
USD $39
USD $149 USD $299
USD $39
USD $149 USD $299
USD $149 USD $299
USD $39
USD $988 $1,637 -$649
Keep Fresh Here, Frozen There
Dual-zone flexibility*
The dual-zone design (45L & 55L only) lets you store fresh and frozen food simultaneously with a maximum temperature difference of 39.6°F. Advanced sensors maintain precise conditions (±1.8°F) to keep food perfectly fresh.
*The 35L model features single-zone cooling, switchable between fridge and freezer modes.
Sized Down, Packed Up
40%* more compact for extra room on the go. The space-saving design gives you more room in your car—to store other essentials. The EcoFlow GLACIER Classic fits 58 cans (35L), 72 cans (45L), and 90 cans (55L) while staying sleek and efficient.
* 40% smaller than standard electric coolers, based on lab testing.
Built for Every Scenario
Car Camping
RV Camping
Tent Camping
Tailgating
Grocery Runs
Up to 43 Hours of Fresh
The EcoFlow GLACIER Classic keeps your items chilled at 39°F for up to 43 hours (35L) or 39 hours (45L and 55L)*
*Tested at 77°F ambient temperature with a fully charged battery.
No melted ice, no soggy food
Max Performance, Minimal
Effort Energy-saving cooling system
Road-Ready
Dual-Sided Door Access
Available in 35L, 45L, and 55L capacities, the EcoFlow GLACIER Classic 35L is comparable to a standard 24-inch suitcase. It's an ideal fit for SUVs, Class B RVs, off-road vehicles, and more, saving valuable space while providing ample storage for your adventures.
* The Slide Rail is an optional accessory.
Access your items from either side,no matter how the cooler is positioned in your vehicle. The dual-sided door design ensures flexible, hassle-free access, making it suitable for any setup.
Adventure-Ready Accessories (Coming Soon)
Hidden Dual-Side Wide Handles
It's All on the App
Powered by EcoFlow Oasis
Max Mode
Eco Mode
Temperature Alert
Get notified if the internal temperature deviates by over 41°F for 10+ minutes, keeping items like meat and dairy safe.
Temperature History
Coolness That Never Stops
Multiple charging options
*For optimal performance, use the plug-in battery to avoid unstable power due to inconsistent sunlight.
*Compatible with EcoFlow 500W and 800W Alternator Chargers.
Doubles as a power bank
What's in the box?
GLACIER Classic 35L
Dimensions- external
706×400×405 mm / 27.8×15.8×15.9 in
Dimensions- internal
487×284×298.5 mm / 19×11×11.7 in
20.5 kg/45 lb
Usable Volume
35L
Number of 330ml Cans
58
Temperature Zone
Variable Dual Temperature
AC Input
AC Adapter: 95W max,14.5V; 100-240V 50/60Hz
DC Input
Solar Charging: 11-30V, 8A/110W max
Battery Runtime
43 hr(Tested @ Ambient temperature: 25°C/77°F, Eco mode)
Rated Power
55W
Noise
< 38.5 dB
Protection Level
IPX4
(-20°C/-4°F) ~ (20°C/68°F)*The left and right temperature zones support a 22°C/39.6°F temperature difference
(-10°C/14°F) ~ (50°C/122°F)
Storage Temperature
(-20°C/-4°F) ~ (60°C/140°F)
Temperature Accuracy
Max mode: ±1°C/1.8°F
Refrigeration(4°C/39°F): 165wh/24h; 0.57 Ah/h
Freezing (-18°C/-0.4°F): 520wh/24h; 1.8 Ah/h(Tested @ Ambient temperature: 25°C/77°F, Eco mode)
App
Suppported
2 Years(ES 3 Years)
Refrigerant
R600a
GLACIER Classic 45L
706×400×480 mm / 27.8×15.8×18.9 in
487×284×373.5 mm / 19×11×14.7 in
23.2 kg/51 lb
Usable Volume
45L
72
Temperature Zone
Dual Temperature Zone
AC Input
DC Input
Battery Runtime
39 hr(Tested @ Ambient temperature: 25°C/77°F, Eco mode)
Rated Power
55W
Noise
< 38.5 dB
Protection Level
IPX4
Storage Temperature
App
Suppported
2 Years(ES 3 Years)
Refrigerant
R600a
GLACIER Classic 55L
706×466×480 mm / 27.8×18.4×18.9 in
487×350×373.5 mm / 19×13.8×14.7 in
25.2 kg/55.6 lb
Usable Volume
55L
90
Temperature Zone
AC Input
DC Input
Battery Runtime
Rated Power
55W
Noise
< 38.5 dB
Protection Level
IPX4
Storage Temperature
App
Suppported
2 Years(ES 3 Years)
Refrigerant
R600a
