EcoFlow DELTA Pro 3 Whole-Home Power Kit | 2*DELTA Pro 3 + 50 amp Hub + Transfer Switch
EcoFlow DELTA Pro 3 Whole-Home Power Kit EcoFlow DELTA Pro 3 Whole-Home Power Kit EcoFlow DELTA Pro 3 Whole-Home Power Kit
USD $5,699.00
Regular price USD $5,699.00
Sale price USD $5,699.00 Regular price $8,096.00
-$2,397
Capacity: 8kWh-24kWh
Week of home power during outages.
Power Output: 8kW
Runs 3-ton central AC and all other essential appliances you need.
Endless energy
Compatible with portable generators, auto rechargeing when connecting with EcoFlow Smart Generator 4000.
Easy to Use
Three ways to flexibly connect EcoFlow DELTA Pro 3 to your home(Inlet Box, Transfer Switch and Smart Home Panel 2)
 Forget Refueling
 Fast solar/car/outlet charging, charges to 80% in just 50 minutes, refueling with no worries.
Recommend
EcoFlow 400W Portable Solar Panel (Recommended Accessory)
USD $529 USD $1,199
EcoFlow DELTA Pro 3 Smart Extra Battery (Recommended Accessory)
USD $1,799 USD $2,599
DELTA Pro 3 Smart Extra Battery will ship in early-April 2026.
USD $529 USD $1,199
USD $529 USD $1,199
You Could Apply for 30% Tax Credit*, When You Install EcoFlow DELTA Pro 3 as a Home Power Solution Learn more
USD $5,699 $8,096 -$2,397
* Requires 3 x EcoFlow DELTA Pro 3, 3 x EcoFlow DELTA Pro 3 Smart Extra Batteries, 3 x EcoFlow Smart
Generator 4000 (Dual Fuel) & 1 x EcoFlow Smart Home Panel 2 (sold separately).
** Requires 1 x EcoFlow DELTA Pro 3, 2 x EcoFlow DELTA Pro 3 Smart Extra Batteries.
*** Requires EcoFlow Alternator Charger.
Keep Your Home Running Smoothly
Ensure essential appliances keep working
Effortlessly expandable power
A comprehensive 10ms UPS
A single source to power almost all of your essential home appliances. Power high-demand appliances—from 3 ton*central AC to 1 HP water pump—with robust 4000W and dual 120V/240V capabilities. Keep your kitchen buzzing and essential systems like garage doors running, all powered simultaneously and reliably by EcoFlow.
*Tested under controlled laboratory conditions with central AC soft starter.
Easily run multiple appliances at the same time. Connect in parallel to expand power up to 12,000W, supporting multiple high-power appliances simultaneously. No constant unplugging or switching required.
Safeguard your data. It ensures swift 10ms switch-overs, protecting your NAS systems, servers, and entertainment devices from power disruptions and keeping your technology safe and continuously powered.
Effortless Power for Every Family Member
Easy, plug-and-play setup
Power. With just one tap
Effortless portability and space-efficient
Easily place anywhere, no house remodelling needed. Take it out of the box, find a spot, and plug it in. That's it. No installation, no home tweaks.
Fully manage home power from anywhere with an app. Stay connected to your home energy with the EcoFlow app anywhere, anytime. Control and monitor your power seamlessly, even remotely, during outages.
Portable design for an ideal lifestyle. Boosts portability with its wide wheels, ergonomic handle, and compact design. Its magnetic sliding doors simplify access, optimizing space and power for mobility without compromise. Ideal for dynamic lifestyles and maximizing family space.
Quiet Comfort for Your Home and Neighbors, Too!
It's whisper-quiet with X-Quiet technology, ensuring a peaceful hum*, promising you a night of peaceful sleep even if you keep it beside your bed. It's so silent that you'll hardly notice it's there.
*as low as 30 dB, thanks to our X-Quiet tech
Freedom from Refueling Concerns
Freedom from Refuelling Concerns
A single unit
Extended backup power settings
Hybrid power kit
Charge up, fast, and everywhere
Introducing EcoFlow's groundbreaking X-Stream fast charging technology, setting a new industry standard. Charge from 0 to 80% in just 50 minutes. With multi-charge combinations, enjoy up to 7000W of super-fast charging.
7 unique and 18 combo charging methods to meet your charging needs anywhere, anytime
Indoor: Dual-PV Charging
Indoor: AC Wall Charging
Garage: EcoFlow Smart
Home Panel 2
Backyard: With Gas
Generator
Outdoor: EV Charging
Piles
RV/Van: EcoFlow
Alternator Charger
Car: Cigarette Lighter
Charging
Fast Multi-Charging
Solutions
Three Ways to Flexibly Connect EcoFlow DELTA Pro 3 to Your Home
Inlet Box
Manual Transfer Switch
Connect up to 3 EcoFlow DELTA Pro 3 to the Smart Home Panel 2 for streamlined, smart home power. It ensures quick, 20ms switch-overs during outages to protect sensitive devices and allows precise app control of up to 12 circuits.
Simply connect the built-in NEMA L14-30R split-phase socket with the Inlet Box to power 120V/240V home appliances.
Ensure seamless power changes with the Manual Transfer Switch. Switch effortlessly between 120V and 240V for diverse power needs while maintaining a reliable supply.
State-of-the-art LFP Tech
Powered by ground-breaking X-Guard BMS
Revolutionizing Durable Construction
5 Years Warranty, Zero Worries
Crafted with automotive-grade LFP cells, the EcoFlow DELTA Pro 3 features the industry's first IP65-rated battery pack, resisting impacts, water, dust, and fire. With 4000 cycles to 80%, enjoy 11 years* of daily power. Dependable in any weather, ensuring peace of mind.
*Tested under controlled laboratory conditions with charging and discharging at 0.5C rate under 77°F conditions
X-Guard BMS monitors 40 safety indicators 24/7, app-managed for smart, secure energy.
CTC design, UL-certified 5VA fireproof shell fortify DELTA Pro 3, setting new standards for resilience.
5-year warranty, streamlined support for swift solutions, minimal downtime. Quality redefined.
Effortless All-in-One Command with the EcoFlow App
What's In The Box?
Can EcoFlow DELTA Pro 3 be connected to EcoFlow Smart Home Panel 2 for use?
Yes, EcoFlow DELTA Pro 3 can be connected to EcoFlow Smart Home Panel 2 through the power input/output port.
Can EcoFlow DELTA Pro 3 be connected to EcoFlow 50 Amp Hub for use?
Yes, EcoFlow DELTA Pro 3 can be connected to the EcoFlow 50 Amp Hub dedicated for EcoFlow DELTA Pro Ultra via the AC Power IN/OUT port, supporting the parallel connection of up to 2 sets of EcoFlow DELTA Pro 3.
EcoFlow DELTA Pro 3 has two PV input ports, which are for high-voltage PV port and low-voltage PV, respectively.High-voltage PV: 30-150V, 15A Max, 1600W Max. Low-voltage PV: 11-60V, 20A Max, 1000W Max.The maximum solar input for the EcoFlow DELTA Pro 3 is 2600W. Please note that this value is based on experimental results under optimal conditions. Achieving this maximum input may require the use of higher-power solar panels that are within the product’s voltage tolerance but exceed the PV port’s power limit. Actual solar input performance can vary depending on the solar panels used, environmental factors, and system configuration. For more information on designing your own solar setup, please contact EcoFlow Customer Service. Before performing any installation, please ensure that it is carried out by a qualified and certified professional.
Can EcoFlow DELTA Pro 3 be used with an EV charger?
Yes, it supports Level 1/2 EV chargers. You will need to purchase a dedicated EcoFlow adapter, the EV X-Stream Adapter (DELTA Pro Ultra). Typyically, the grid charging port on the US model only supports AC 120V 2000W charging (Level 1). However, by using the AC POWER IN/OUT port along with the EV X-Stream Adapter (DELTA Pro Ultra), you can connect a 240V EV charger, increasing the charging rate to 4000W (Level 2).
Can EcoFlow DELTA Pro 3 output 120V and 240V AC power simultaneously?
No, but it can perform split-phase output as a standalone unit.There are two buttons for AC output: 120V AC ON/OFF and 240V AC ON/OFF.1. When the 120V AC button is pressed, four 120V 20A outlets and one 30A RV outlet will supply power, and the 240V outlet will be turned off.2. When the 240V AC button is pressed, one L14-30 split-phase outlet and one 6-20R 240V outlet output power, and the 120V outlet will be turned off.
Will EcoFlow DELTA Pro 3 automatically turn on if connected to solar panels while it is turned off?
Yes, it will.However, there are specific requirements for the light conditions. In weak lighting environments, it might not trigger the device to power on.
  1. EcoFlow 800W Alternator Charger
  2. EcoFlow Smart Home Panel 2
  3. EcoFlow Smart Generator (Dual Fuel)
  4. EcoFlow DELTA Pro to Smart Generator Adapter
  5. EcoFlow PowerInsight Home Energy Manager
  6. EcoFlow WAVE 2
  7. EcoFlow Smart Generator 4000 (Dual Fuel)
Which EcoFlow products are compatible with EcoFlow DELTA Pro 3? (EcoFlow DELTA Pro series)
  1. EcoFlow DELTA Pro Smart Extra Battery
  2. EcoFlow 50 Amp Hub
  3. EcoFlow EV X-Stream Adapter
  4. EcoFlow DELTA Pro Remote Control
How long is the cycle life of the battery in EcoFlow DELTA Pro 3?
4000 cycles.After undergoing 4000 cycles at a rate of 0.5C/0.5C at 25°C (77°F), the battery maintains over 80% of its state of health (SoH).
Optimal operating temperature: 20°C-30°CCharging temperature range: 0℃-45℃Discharge temperature range: –10℃-45℃Recommended long-term storage temperature: 20℃-30℃
As the core component of the device, the safety and protection level of the battery pack is crucial. To better protect the battery pack and reduce the risk of short circuits and fires caused by water ingress, the EcoFlow DELTA Pro 3 battery pack is sealed. It has reached an IP65 waterproof and dustproof rating, effectively preventing dust from entering and resisting water spray.However, the EcoFlow DELTA Pro 3 main unit does not have a waterproof and dustproof rating (IP20). The device is suitable for use in well-ventilated indoor environments or sheltered outdoor environments to avoid the impact of rain and dust on the device. Please ensure that the surrounding environment is dry and clean during installation and use to ensure the device's normal operation and longevity.
EcoFlow DELTA Pro 3 is equipped with an internal GFCI ground circuit. Users can connect an external GFCI protector according to their needs. When an external GFCI protector is connected to EcoFlow DELTA Pro 3, the GFCI support switch must be turned on in the app for the external GFCI protector to function properly.
Is the EcoFlow DELTA Pro 3 Extra Battery compatible with the EcoFlow DELTA Pro?
No, not supported.
Is the EcoFlow DELTA Pro Smart Extra Battery compatible with the EcoFlow DELTA Pro 3?
Yes, supported. Please note that all devices need to be upgraded to the latest firmware version to ensure compatibility.
Can the EcoFlow DELTA Pro 3 main unit be used with the EcoFlow DELTA Pro main unit?
No, not supported.
Can the EcoFlow DELTA Pro 3 Smart Extra Battery and the EcoFlow DELTA Pro Smart Extra Battery be mixed and plugged into the EcoFlow DELTA Pro 3?
Supported. However, due to the different capacities of the EcoFlow DELTA Pro Extra Battery and the EcoFlow DELTA Pro 3 Extra Battery, there will be some SOC imbalance.
Is the EcoFlow DELTA Pro 3 compatible with the EcoFlow DELTA Pro Ultra?
No, not supported.
Rated Capacity
4096Wh
12kWh (2 × DP3 Extra Battery)
AC Continuous Output
4000W, 6000W with X-boost
Expanable Capacity (System*)
36kWh (6 × DP3 Extra Battery); Up to 48kWh**
AC Surge Output
8000W
Scalability(System*)
12kW
Cell Chemistry
Battery IP Rating
IP65
4000 cycles to 80% capacity
UPS
10 ms
12V DC Output
2.6V⎓30A, 378W total
DC5221: 1 × 5A Max
Anderson Port: 1 × 30A Max
120V AC Output
4 × NEMA 5-20R, 20A
1 × NEMA TT-30R, 30A
USB-A
2 × 5V-2.4A/9V-2A/12V-1.5A,
18W Max per port, 36W total
240V AC Output
1 × NEMA 6-20R, 16.7A
USB-C
2 × 5/9/12/15/20V-5A, 100W Max per port, 200W total
120/240V AC Output
1 × NEMA L14-30R, 16.7A
AC Charging Input
Charge Only: 100-240V~15A 50/60Hz
Bypass Mode: 100-120V~15A (3 hours Max), 12A (continue), 50/60Hz
Solar Charging Input
2600W total, 2 ports
High-PV Input: 30V-150V⎓, 15A, 1600W Max
Low-PV Input: 11V-60V⎓, 20A, 1000W Max
Car Charging Input:
12V⎓8A Max / 48V⎓20A Max
Dimension:
410.4 × 341 × 693 mm(16.16 × 13.43× 27.28 in.)
51.5kg (113.54 lb)
5-year warranty
Connection
WiFi 2.4GHz/Bluetooth/CAN
Discharging temp
-10°C to 45°C | 14° to 113°F
Charging temp
0°C to 45°C | 32° to 113°F
Storage temp
** Requires 3 × EcoFlow DELTA Pro 3, 3 × EcoFlow DELTA Pro 3 Smart Extra Batteries, 3 × EcoFlow Smart Generator 4000 (Dual Fuel) & 1 × EcoFlow Smart Home Panel 2 (sold separately).
EcoFlow DELTA Pro 3 Compatiblity*
*Please note that EcoFlow DELTA Pro 3 is not compatible with EcoFlow DELTA Pro/EcoFlow DELTA Pro Ultra.
EcoFlow Smart Home Panel 2 (or Smart Home Panel 2 bundle) + Installation fee Installation Terms & Conditions
Installation Conditions
2. If customer's home is such that the required wiring length may cause voltage drop and not satisfy NEC requirements, the installation may not be possible.
3. In the event of unforeseen circumstances that may prevent inistallation, EcoFlow reserves the right to determine the final feasibility of installation.
1.To support sales of Smart Home Panel 2 or Smart Home Panel 2 bundle in North America through the EcoFlow US official website, EcoFlow offers an installation service package, which includes the basic installation cost for Smart Home Panel 2.
2.Customers who purchase EcoFlow Smart Home Panel 2 or EcoFlovw Smart Home Panel 2 bundle through Shopify may opt to purchase the "Installation service Package". EcoFlow customer service is responsible for matching the customers with electricians who can take the orderand for following up on the progress of the installation.
3.Installation Service Package includes wiring the EcoFlow Smart Home Panel 2 to the existing load center. It does not include pulling permits from AHD (If required by customers, addiitional fees may apply), wiring the EcoFlow Smart Home Panel 2 to a generator, or wiring thee EcoFlow Power Station to solar panels or PV systems. If the customer requires the installation to include wiringthe EcoFlow Smart Home Panel 2 to generator, or wiring to solar panels or PV systems, the electrician reserves the right to refuse to take the order.
4.The installation service fee on the official website covers labor costs and the materials needed for installing Smart Home Panel 2 within 2 feet of the load center. This excludes:
a.Additional material and labor costs due to excessive distance or incompatibility between the existing circuit breaker and Smart Home Panel 2.
c. The electrician's on-site assessment fee, which can be waivedif the circumstance has been assessed by the electrician to be suitable for installation and the customer does not request for refund of the installation service fee.
The above extra costs and fees shall be subject to the actual quote from the electrician. Customers are responsible for directly paying the electrician for any extra costs ircurred. EcoFlow reserves the right to final interpretation of the installation service fee.
5.By agreeing to EcoFlow's installation services, you consent to the collection and processing of personal information necessary for completing the service. This may include, but is not limited to, your name,address, contact information, and any relevant details related to the installation. We will handle your personal information in compliance with applicable data protection laws and regulations and will only use it for the purpose of fulfilling the installation service. Please refrain from directly providing your personal information to the electrician during the installation process, otherwise you will be responsible for any loss or damage caused by the disclosure of such information.
3. Should a customer opt for our installation service and then decide to return the Smart Home Panel 2 due to dissatisfaction after installation, the paid installation fee cannot be funded. Additionally, the customer will be responsible for any costs associated with the removal of Smart Home Panel 2.
4. The installation service does not include any cleaning or removalof debris generated during the installation process. Residents are responsible for managing and disposing of all trash and debris resulting from the installation.
5. Any holes or modifications made to the premises during theinstallation are considered normal and necessary for the proper completion of the service. The installer shall nnot be held liable for any unavoidable damages or alterations made to the premises during the installation process.
7. Any product issues or defects resulting from installation by an unauthorized installer shall be the sole responsibility of the resident. The resident shall bear full responsibility or any after-sales service or repairs needed due to such unauthorized installations.
Disclaimer
Effective date: Jan 1, 2023
