EcoFlow DELTA 3 Max Solar Generator EcoFlow DELTA 3 Max Solar Generator EcoFlow DELTA 3 Max Solar Generator EcoFlow DELTA 3 Max Solar Generator
USD $1,249.00
Starting at 0% APR with Pay
Ends in
Days
DELTA 3 Max (2048Wh)
1. 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws.
2. 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging.
3. Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product.
Common Features
1. Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport.
2. 10ms Auto-Switch: Fast enough to keep critical devices like NAS systems and servers running smoothly.
3. 25dB Whisper-Quiet Operation: Ultra-low noise (≤25dB at 600W).
4. OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. Storm Guard Mode automatically activates backup power before extreme weather hits. Self-Powered Mode and Scheduled Tasks save you money daily.
5. Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Learn more
Regular price USD $1,249.00
Sale price USD $1,249.00 Regular price $1,398.00
-$149
Solar Panel Options
Selection Summary
EcoFlow Solar Generator With 2 x 160W Solar Panel EcoFlow DELTA 3 Max Solar Generator
USD $1,249 $1,398
USD $1,249 $1,398 -$149
2400W Output— Powerful. Stable. Built to Handle It All
EcoFlow DELTA 3 Max (2048Wh) delivers 2400W AC rated output. With X-Boost™ 3.0 technology, it supports devices up to 3400W—effortlessly taking on your heavy-duty appliances. The inverter samples AC voltage and current every 33μs with high precision using a DSP chip, ensuring pure sine wave output with beyond grid-level stability—ideal for powering sensitive electronics reliably.
Kitchen
Kitchen
Living Room
Living Room
Office
Office
Garage
Garage
Laundry Room
Laundry Room
RV Camping
RV Camping
Kitchen
Living Room
Office
Garage
Laundry Room
RV Camping
4 Ways to Charge Up — Ready in Just 68 Mins
Remote charging control for added peace of mind.
Wall Charging
Wall Charging
Generator Charging
Generator Charging
Alternator Charging
Alternator Charging
Wall Charging
Generator Charging
Alternator Charging
1800W Input, 0-80% in 68 mins[3]. EcoFlow’s exclusive Storm Guard Mode[4] monitors severe weather alerts and automatically triggers AC charging remotely using industry-leading X-Stream fast charging tech—so it can be ready long before a disaster hits.
With 1800W input, recharge to 80% in just 68 mins[1]. The EcoFlow Smart Generator 4000 (Dual Fuel) powers up DELTA 3 Max (2048Wh) for storms, outages, and off-grid living[5].
500W Input, 0-80% in 3.43 hrs. Pair it with EcoFlow Solar Panels (25% high-efficiency) for reliable power during camping trips, van life, or off-grid living[6].
With the EcoFlow 500W Alternator Charger[7], get ready fast while on the move.
Built to Last
From battery chemistry to structural design, DELTA 3 Max (2048Wh) is engineered for extreme durability, environmental resilience, and whisper-quiet performance.
Smart, 24/7 Battery Protection
EV-Grade CTC Structure
Extreme Environment Resistance
Class B EMC Certification
25dB Whisper-Quiet Operation Under Loads [9]
EcoFlow’s advanced BMS uses a high-performance ARM Cortex chipset and intelligent algorithms to monitor your battery in real time. By tracking SOC, SOH, temperature, and more, it ensures peak performance, extended battery life, and worry-free operation.
Built with a cell-to-chassis (CTC) structure, DELTA 3 Max (2048Wh) is drop-resistant and shockproof—protecting against overnight condensation and off-road bumps during transport. You get stable power even in the most demanding conditions.
DELTA 3 Max (2048Wh) keeps your power flowing through freezing cold, scorching heat, humid environments (95% humidity tolerance), or coastal air—for reliable energy anytime, anywhere[8].
Certified to Class B EMC standards, it won’t interfere with TVs, Wi-Fi, or other home electronics.
Powered by X-Quiet™ 3.0, EcoFlow’s stepless fan control adjusts airflow smoothly to maintain precise thermal regulation—keeping your home or workspace peacefully quiet, even under heavy loads.
Compact, Portable, Lighter than Ever — Works Anywhere
Lightweight and easy to carry, DELTA 3 Max (2048Wh) fits into any setting—from home to the great outdoors. Weighing just 20.3 kg, it’s 13% lighter[10] for effortless portability while still packing serious power.
Monitor your energy usage and solar generation—all with one intuitive dashboard. Set timed charging/discharging missions so that you can charge during off-peak hours, discharge during peak rate periods to save costs.
User Story
Compatibility
*Compatibility note: Reverse charging and battery preservation modes rely on XT150 or 4+8 pin communication cables. DELTA 3 Max features an XT60 port only, making these functions unavailable.
What's In The Box?
1. 0-80% in 68 minutes was measured in optimal conditions using AC charging with X-Stream Fast Charging mode on.
2. Based on proper product usage, DELTA 3 Max (2048Wh) is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
3. All charging speed data comes from EcoFlow Labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
4. Feature requires preset activation via the EcoFlow App.
5. EcoFlow Smart Generators are sold separately.
6. EcoFlow Solar Panels are sold separately.
7. EcoFlow 500W Alternator Charger is sold separately.
8. Unless otherwise noted, all images, videos, and screen display contents about the product itself on this page are for reference only. Actual product effects (including but not limited to appearance, color, and size) and screen display contents (including but not limited to backgrounds, UI, and illustrations) may vary.
9. Noise levels measured at 1m under 25°C ambient: ≤25dB (600W) for charging/discharging.
10. Compared with EcoFlow DELTA 2 Max
20.3+0.4kg
Dimensions (HWD)
494mm×239mm×305mm
Rated Capacity
2048Wh 51.2V 40Ah
Cell Chemistry
LFP (LiFePO4)
120V 60Hz 2400W total, 20A (x4) Max per
port
X-Boost
3400W
USB-A (x1): 5V-3A/9V-2A/12V-1.5A, 18W Max
USB-C (x1): 5/9/12/15V-3A,20V--5A, 100W Max
USB-C (x2): 5/9V-3A, 15V-2A,30W Max per port, total 30W
Cigarette Lighter Output Port
12.6V, 10A, 126W Max
AC Input (Charge Only)
100-120V~15A 50/60Hz
Maximum PV Input Power(W)
500W
Charge Temperature
0°C-45°C (32°F-113°F)
Discharge Temperature
-10 to 45°C (14°F-113°F)
Operating Humidity
20%-95%
5-Year Warranty
Communication Method
Wifi 2.4GHz/ Bluetooth5.0
EMC
Class B
UPS
<10ms
