EcoFlow Double Voltage Hub (Power Input/Output) | DELTA Pro | Default Title
EcoFlow Double Voltage Hub - Power Input/Output (DELTA Pro)
Regular price USD $159.00
Sale price USD $159.00 Regular price $159.00
-$0
Connect 2 × EcoFlow DELTA Pro with the Smart Home Panel 2 using this hub.
Highlights:
-Even More Output: Chain 2 × DELTA Pro together for an output of 7200W, enough for the most heavy-duty appliances.
-Double Your Capacity: Link 2 × DELTA Pro and keep your home running longer with a capacity of 7.2kWh.
Specifications:
AC Input: 120V~ 60Hz 30A (×2) Max per port
3600W (×2) Max per port total 240V total 7200W
AC Output: 120V/240V~ 60Hz 30A Max 7200W Max
Dimensions: 11.4×3.5×2 in (290×90×50.9 mm)
USD $159
Subscribe to get 5% off and updates
Thank you for submission!
