Already have an account? Sign In
Double your capacity: Plans for using tons of energy off-grid? Link two DELTA Pro units and their battery management systems will distribute capacity evenly to anything plugged into this hub.
Even more output: House battery backup never had this much output. Chain two units together and your DELTA Pro’s will output a whopping 7200W, enough for even the most heavy-duty of appliances.
Portable & lightweight: The double voltage hub is easy to carry, and pairs with your DELTA Pro to bring even more versatility to your portable battery set up. Charge up, link your power stations and you’re good to go.
Three more outlets: The hub has two NEMA 6-20 outlets that power 20-amp equipment and tools. It also has a NEMA L14-30 outlet, making it that much easier to switch out your old gas generator.
Note: The Double Voltage Hub requires two EcoFlow DELTA Pro units.
Adding product to your cart
Please note the difference in voltage between the US and EU. If you are a Ukraine user we will redirect your to the EU site to continue shopping.
Since each region has specific voltage and plug requirements, we'll redirect you to your location.
You’ll be redirected to our Canadian site for a better shopping experience. Here’s a special welcome gift — use code WELCOMETOCA at checkout!
Your shopping cart is empty
I agree to EcoFlow's Privacy Policy and Terms of Service.
* EcoCredits can be redeemed for discounts and gifts
