Top up 1kWh in only 1.3 hours
Charge 8× faster while you drive with our EcoFlow 800W Alternator Charger and recharge your power station in only 1.3 hours. With the EcoFlow 800W Alternator Charger, charge 8 times faster than with traditional vehicle auxiliary power outlets simply by using excess energy generated by your vehicle. The charger uses its onboard DC-DC converter to restore your EcoFlow power station's energy while you drive.
Note: Alternator capacity varies by vehicle - Please verify with your manual (or the alternator's manual) that the alternator's output supports the alternator charger's maximum power draw for safe operation.
The 3-in-1 charger, maintainer, and jump starter saves time, money, and precious in-vehicle space. With its smart and efficient fast charging capabilities, you'll stay powered no matter how long you're on the road.
*The reverse charging and battery maintenance functions require the XT150 cable. However, DELTA 3 Max Plus, DELTA 3 Ultra Plus, DELTA Pro, and DELTA Pro 3 require the EcoFlow Alternator Charger Custom Fit Output Cable (2m). Compatible with EcoFlow DELTA Series products only.
Charging Mode
Reverse Charging Mode
Battery Maintenance Mode
Extend your RV house battery runtime
Conveniently adapts to 12V/24V RV house batteries.Connects to EcoFlow portable power stations and protects RV house batteries while expanding energy storage capacity by up to 7.2kWh*.
*With EcoFlow DELTA Pro and DELTA Pro Extra Battery
Compatible with all EcoFlow and most third-party power stations
Compatible with an XT60 connection, designed to charge EcoFlow RIVER, DELTA Series, and most third-party power stations. The charger's 800W fast-charging is compatible with most SUV, Pickup, and RV alternators, meeting diverse short-trip car camping power needs. *The 800W Alternator Charger comes with an XT150 cable to pair with EcoFlow DELTA Series products. An additional purchase of XT60 cable is required for wider compatibility.
With a high thermal resistance, Gallium Nitride (GaN) technology ensures safe charging every single time.The 800W Alternator Charger offers multiple safety features, including undervoltage protection that prevents excessive energy use and damage to the starting battery. A 2-year warranty ensures your experience and peace of mind.
Smart Charge, Smarter Control - Industry-first vehicle infotainment integration
Monitor your power station and remaining charging time at a glance. Stay connected with real-time control through Apple iOS CarPlay & Android Auto support. Access the EcoFlow App directly via your vehicle's infotainment system, turning your drive into a hub of intelligent energy management. Everything at your fingertips without constantly checking your phone, ensuring safer driving.
Connect your 800W Alternator Charger to your vehicle's starter battery or RV's house battery to enjoy a worry-free power experience during your journey.
Connect the Fuse Cable
Connect the Input Cable
Start Charging
1. Connect the fuse cable to the input cable on one end. 2. Connect the fuse cable to the vehicle battery on the other end.
1. Connect the black cable to the chassis terminal. 2. Thread the other end of the input cable through the car body towards the charger. If the input cable is bulky or difficult to pull through, disconnect the cable ends before threading. 3. Plug the other side of the input cable into the EcoFlow 500W Alternator Charger.
Plug in the output cable from the EcoFlow 500W Alternator Charger to the portable power station.
Will this product damage the alternator, starter battery, or affect the overall lifespan of the vehicle?
No, the 800W alternator charger's charging logic does not rigidly apply 800 watts. Instead, it depends on the power surplus of the car's alternator. It ensures the alternator is not overloaded, allowing up to a maximum of 800 watts without harming the car's battery.
Will this product consume more fuel (i.e. affect gas mileage) when used?
The product uses the electricity generated by the car's alternator. Even if all the electrical devices inside the car are turned off, the alternator still generates
electricity while the car is running. The alternator charger utilizes the surplus electricity generated by the car's alternator and stores it in a portable power station through the charger. The impact on fuel consumption is very minimal.
Drilling is not required for installation. The wiring connection to the alternator at the front of the car does not need drilling and will not damage the vehicle. It can simply be wired through the firewall near the driver's seat. The alternator charger can also be installed using methods that do not require drilling.
Is this product suitable for DIY installation?
The installation of the alternator charger is not very complicated, and it is feasible for professional users with some hands-on ability to install it themselves. However, it is still recommended to contact professional personnel from related workshops for installation.
Installation advice: When wiring, avoid high temperature, sharp, and friction-prone areas, and securely fasten the cables to avoid cable wear or loose connections caused by cable movement. The alternator charger may generate high temperatures, so avoid covering the product. After use, avoid immediate direct contact to prevent the risk of burns.
Is it normal for the alternator charger to get hot?
Yes. The alternator charger may generate high temperatures, so avoid covering the product. After use, avoid immediate direct contact to prevent the risk of burns.
How long does it take to fully charge a DELTA Series product?
DELTA 2 (1kWh) - 1.3 hr;
DELTA 2 Max (2kWh) - 2.6 hr;
DELTA Pro (3.6kWh) - 4.8 hr;
DELTA Max 2000 - 2.6 hr;
DELTA Max 1600 - 2.1 hr;
DELTA 2 Extra Battery - 1.3 hr;
DELTA 2 Max Extra Battery - 2.6 hr.
Compared to charging via the cigarette lighter, what advantages does the alternator charger offer when used in a vehicle?
The charging power is significantly increased. The charging power of a cigarette lighter is about 100W, whereas the alternator charger can support charging continuously at a high power of 800W during driving for portable power stations, which is 8 times the power of a cigarette lighter.
Solution to the problem that the EcoFlow WAVE 2 add-on battery does not work with the alternator charger.
Please first connect the EcoFlow WAVE 2 add-on battery to EcoFlow WAVE 2, and then upgrade the firmware to the latest version through the app.
How can I tell if the alternator charger is applicable to my car?
The alternator charger operates with an input voltage of 11V-35V, so in theory, any vehicle with a starter battery operating on a 12V or 24V voltage can use this product.
What protections are in place for the alternator charger in a car?
Reverse polarity protection/overcurrent protection/short circuit protection/overvoltage and undervoltage protection.
How many operation modes are there for the alternator charger?
1. Charging mode: Strictly speaking, it is the car's alternator charging the battery of the portable power station, with the car's battery acting as a load to conduct the current.
2. Reverse charging mode: The portable power station charges the vehicle starter battery or the RV house battery reversely at a rapid rate, with a relatively high current.
3. Battery maintenance mode: Similarly, the portable power station charges the battery, but with a smaller current.
What does the indicator light on the alternator charger mean?
Green light: Charging mode;
Blue light: Battery maintenance mode;
White light: Reverse charging mode;
Yellow light: Unbinding success indicator;
Red light: Device failure indicator.
How does the alternator charger start and stop?
The alternator charger operates based on voltage recognition, and it can charge when the input voltage is greater than 13V.
What type of vehicles are suitable for installation? Do they all reach the maximum charging power of the alternator charger?
Based on the principle of the alternator charger, gasoline vehicles are the most suitable for use, while hybrid and range-extended vehicles can also be adapted.
The specific operating power depends on the surplus power of the vehicle's alternator, so the charging power may fluctuate. Additionally, some older or special models may not work properly due to overall low voltage.
What is the overall size of the alternator charger?
242x194x35 mm
What is the input of the alternator charger?
Charging mode: 11V-35V, 76A Max
Battery maintenance mode: 40V-60V, 3A Max
Reverse charging mode: 40V-60V, 21A Max
What is the output of the alternator charger?
Charging mode: 40V-60V, 800W Max
Battery maintenance mode: 13.8V/27.6V, 100W Max
Reverse charging mode: 13.8V/27.6V, 800W Max
What are the operating and storage temperatures of the alternator charger?
Operating temperature: –20°C to 60°C
Storage temperature: –30°C to 70°C
Will installing an alternator charger affect my car's warranty?
Please confirm with your vehicle manufacturer regarding vehicle warranty issues.
Model
EF-FC-301-1
5.1 lb (2.3 kg)
Dimensions (W × D × H)
9.5×7.6×1.4 in
(242×194×35 mm)
Wi-Fi
Frequency: 2412MHz-2472MHz
Maximum output power: <20dBm
Bluetooth
Frequency: 2402MHz-2480MHz
Maximum output power: <10dBm
Charging Mode
Input: 11V-31V, 76A Max.
Output: 40V-60V, 800W Max.
Input: 40V-60V, 3A Max.
Input: 40V-60V, 21A Max.
Fuse's Rated Current
125A
Protection Type
Overcurrent protection
Short circuit protection
Overvoltage protection
Undervoltage protection
Operating Temperature
–4℉ to 140℉ (–20℃ to 60℃)
Storage Temperature
–22℉ to 158℉ (–30℃ to 70℃)
Operating Humidity
≤95%
Storage Humidity
≤95%
Terms and Conditions:
¹The 800W refers to the speed under full power charging. The charging power is related to the car generator's current and operating condition.
Choosing a selection results in a full page refresh.
Press the space key then arrow keys to make a selection.
Are you a Ukraine user?
Please note the difference in voltage between the US and EU. If you are a Ukraine user we will redirect your to the EU site to continue shopping.
Welcome to EcoFlow US
Since each region has specific voltage and plug requirements, we'll redirect you to your location.
Shopping from Canada?
You’ll be redirected to our Canadian site for a better shopping experience. Here’s a special welcome gift — use code WELCOMETOCA at checkout!
Shopping Cart
My Shopping Cart
