EcoFlow 50 Amp Hub | DELTA Pro Ultra | Default Title
EcoFlow 50 Amp Hub
Regular price USD $299.00
Sale price USD $299.00 Regular price
-$-299
50 Amp Hub connects 2 × EcoFlow DELTA Pro 3(output current 33A) or 2 × DELTA Pro Ultra Inverter
Highlights:
Double the Output: Chain 2 × DELTA Pro Ultra Inverter together for a continuous output of 12kW and peak output of 18kW to run even the most heavy-duty appliances.
In the Box:
EcoFlow 50 Amp Hub × 1
EcoFlow Power Input/Output Cable × 2
Specifications:
EcoFlow DELTA Pro Ultra:
AC Input: 120/240V~ 60Hz~ 30A (×2) Max per port
AC Output: 120/240V~ 60Hz~ 12000W Max~ Total 50A Max
Dimensions: 13.2×6.2×2.4 in (335×158.5×60.5 mm)
EcoFlow DELTA Pro 3:
AC Input: 120/240V~ 60Hz ~ 16.7A (×2) Max per port
AC Output: 120/240V~ 60Hz~ 8000W Max~ Total 33A Max
USD $299
