Buy Rigid Solar Panel – EcoFlow US | 175W Rigid Solar Panel
EcoFlow 175W Rigid Solar Panel
USD $169.00
Regular price USD $169.00
Sale price USD $169.00 Regular price $249.00
-$80
· Up to 25% cutting-edge solar conversion efficiency rate
· Use TOPcon solar cells that work well in low light and high-temperature environments, maintaining high power output.
· Built to last with an IP68 waterproof rating
· Use in various scenarios, including Class B vans and home
· Fast and easy installation
· Up to a 5-year warranty and 30-year lifespan
USD $169 $249 -$80
Generate even more energy
Utilizing Revolutionary N-Type TOPCon Solar Cells
With N-Type TOPCon solar cell technology, we've raised the bar on conversion efficiency, reaching heights of 25%. Generate and store more more sunshine than ever before.
Designed to weather any storm
Coated with Highly Protective Lamination and Tempered Glass
Built with a robust anti-corrosive aluminum frame, it's designed for years of solar-ray collection. Its TOPcon cells are coated with highly protective lamination and tempered glass and comes with an IP68 waterproof rating to enhance performance and offer long-lasting durability.
With just the right specs to maximize roof space
Industry-first design exclusively for Class B vans
Long-lasting solar solution for your home
Perfectly Tailored for Home Use
Ready to install on any surface
Pre-Drilled Slots for Secure Mounting
With pre-cut holes along the panel's perimeter, the 175W rigid panel is ready to mount on your van or off-grid build. Pair with the Rigid Solar Panel Mounting Feet for a secure attachment to any surface.
Just plug and play with your power system
Universally Compatible Solar Cable
Using an all-inclusive solar connector, connect with any existing third-party solar system. Charge 48V power systems and portable power stations with single or multiple panels.
EcoFlow 175W Rigid TOPCon Solar Panel Charging Times
How to choose your solar panel
What‘s In The Box
Rated Power
175W (+/-3W)
Cell Type
N Type TOPCon Monocrystalline Silicon
Efficiency Rating
Up to 25%
Weight (Solar Panel)
20.5 lb (9.3 kg)
46.3×30×1.2 in (1176 x 762 x 30 mm)
Connector Type
Photovoltaic Connectors (Adaptable to MC4 Connectors)
Warranty (US)
5 Years
Waterproof & Dustproof Rating
Short Circuit Current
8.3 A
Open Circuit Voltage
25.5 V
Maximum Operating Voltage
22.3V
7.85A
Can I use solar panels of different specifications for mixed use?
Yes, but it is not recommended. Different energy storage controllers have requirements and restrictions on the output of solar panels. When solar panels with different current values are used in series, they will be limited, resulting in the inability to release the output power and even the short-board effect of 1+1<2
What features and advantages does EcoFlow TOPcon solar panel have compared to other solar panels?
EcoFlow TOPcon solar panel has a next-level solar conversion efficiency rate of 25%, significantly higher than the 18%-20% conversion efficiency of many traditional solar panels. It maintains high power output even in low light and high-temperature environments, making it perform better in various weather conditions. It has an IP68 waterproof rating, ensuring greater durability and reliability, with a lifespan of up to 30 years.
What is the power range that a 175W solar panel can typically achieve?
On a sunny day without clouds and direct sunlight, the power range of a 175W solar panel is between 130–145W (this data is obtained under the conditions of irradiance of 800–900W/m2 and the panel surface at 60°C (140°F)). The nominal data of the solar panel is obtained by testing under the conditions of AM1.5, meteorological conditions of 1000W/m2, and panel surface temperature of 25°C (77°F). A power close to the nominal value can usually be reached at midday on a sunny day in winter.
Do I need to clean the 175 W Solar Panel regularly?
Yes. There can be a lot of dust and foreign objects on the surface of the solar panel after the panel has been used outdoors for a long time, which block the light to a certain extent, reducing the power output. Regular cleaning can help keep the surface of the solar panel clean and free from obstructions and generate a higher power output.However, when cleaning, be careful to wipe the surface with soft materials to prevent hard materials scratching the surface of the panel and affecting the output.
