EcoFlow 125W Bifacial Modular Solar Panel | 125W Bifacial Modular Solar Panel
EcoFlow 125W Bifacial Modular Solar Panel (125W, 250W, 500W kits) EcoFlow 125W Bifacial Modular Solar Panel (125W, 250W, 500W kits) EcoFlow 125W Bifacial Modular Solar Panel (125W, 250W, 500W kits) EcoFlow 125W Bifacial Modular Solar Panel (125W, 250W, 500W kits) EcoFlow 125W Bifacial Modular Solar Panel (125W, 250W, 500W kits) EcoFlow 125W Bifacial Modular Solar Panel (125W, 250W, 500W kits) EcoFlow 125W Bifacial Modular Solar Panel (125W, 250W, 500W kits) EcoFlow 125W Bifacial Modular Solar Panel (125W, 250W, 500W kits) EcoFlow 125W Bifacial Modular Solar Panel (125W, 250W, 500W kits) EcoFlow 125W Bifacial Modular Solar Panel (125W, 250W, 500W kits)
USD $249.00
Regular price USD $249.00
Sale price USD $249.00 Regular price $299.00
-$50
Feature:
  • Modular design: Max parallel connection of 8 panels (1000W)
  • Adjustable angle (30-60°) for optimal solar energy collection
  • Up to 25% conversion efficiency
  • STC 125W,BNPI 138W
  • TOPCon solar cells perform well in low light and high temperatures
  • Versatile use for home, backyard, and RV setups
  • Lightweight: 4 panels weigh only 35.2 lb (16.2kg)
  • Up to 5-year warranty and 30-year lifespan
USD $249 $299 -$50
The EcoFlow 125W bifacial modular solar panel offers 25% efficiency, plug-and-play expansion, and reliable performance in various weather conditions, making it ideal for long-term home and outdoor use.
Perfectly Tailored for Home Use
Long-Lasting Solar Solution for Your Home
With a 30-year lifespan, this durable, low-maintenance solar panel is ideal for home use.
New extension cables make it easy to connect multiple panels in your backyard.
Integrated 30-60° adjustable support for optimal solar capture from your garden. The screw-fixation design ensures stability, perfect for long-term outdoor use.
Home Backyard
RV
Fully charge EcoFlow DELTA Pro 3(4kWh) in as fast as 3-4 hours with 3 sets of 500W (125W × 4) panels[1].
Fully charge EcoFlow DELTA 3(1kWh) in as fast as 2-3 hours with 1 set of 500W (125W × 4) panels[1].
Modular Design
Seamless Expansion and Broad Compatibility
The EcoFlow 125W Bifacial Solar Panel features an innovative modular design, delivering 125W power, 50V, and 3A current output, designed for seamless expansion within its safe range, it offers exceptional adaptability with various EcoFlow portable power stations.
50V Design For Parallelling
50V high-voltage, low-current design: Tailored for 60V and 150V energy storage systems, enabling flexible compatibility and easy parallel connection. Unlike traditional systems that increase power via series connections, the 60V voltage limit naturally restricts series options, making the 50V parallel setup more suitable for achieving high power output. Meanwhile, it also supports series connections to achieve 150V output.
Shading Resistance: The 125W bifacial solar panel supports multiple parallel connections, reducing efficiency loss due to shading. In series connections, partial shading on one panel restricts the entire circuit's current, significantly impacting performance.
Upgraded XT-60 Ports
The XT-60 port integrates both positive and negative terminals, simplifying connections, preventing miswiring, and supporting direct panel connections. It’s waterproof, providing an excellent outdoor experience. Its 30A current limit covers EcoFlow power stations’ maximum 25A current input.
Simple Connections, High Expandability
Plug-and-Play Connections: Traditional series setups require extensive wiring for multiple panels, making installation complex. The 125W panel’s innovative design enables easy parallel or simple series connections, achieving true plug-and-play functionality.
Enhanced Expandability: Compatible with multiple EcoFlow portable power stations, this solar panel can easily scale power levels by adjusting the number of panels used, and adapting to various EcoFlow models. Mixing old and new panels won’t impact overall output, maximizing efficiency.
Revolutionary N-Type TOPCon Solar Cells & Dual-Sided Design
Maximize Energy Generation
With N-Type TOPCon technology, achieve up to 25% conversion efficiency. The dual-sided design generates Max. 138W[2] bifacial output, capturing more solar energy.
Coated with Protective Lamination & Tempered Glass
Durable, All-Weather Design
Built with robust anti-corrosive aluminum frame, TOPCon cells feature 1.1mm ultra-thin tempered glass for excellent light transmission, POE films for UV and moisture resistance, PET backsheets for durability. The panel is IP68-rated with waterproof XT60-W connector, ensuring robust, weather-resistant performance.
Flexible, Lightweight Design for Adjustable Power Needs
The 500W setup weighs only 37 lbs (16.8 kg) . The modular design enables flexible power configuration. For situations requiring less than 500W or a lighter setup, the system can be split into individual panels, offering both flexibility and reduced weight. Featuring 3M™ Dual Lock™ Reclosable Fasteners[3], ensures quick and steady assembly, and the protective bag makes transport and storage effortless.
Universally Compatible Solar Cable
Plug and Play with Your Power System
Easily connect to third-party solar systems using the included photovoltaic connector (MC4 compatible)[4]. Safely charge your power systems and portable power stations with XT60 connectors, featuring waterproof, touch-safe, anti-leak technology for reliable performance.
EcoFlow XT60W to Solar Connector Extension Cable (MC4 Compatible), connects solar panels in series.
EcoFlow Solar Connector to XT60i Extension Cable (MC4 Compatible), connects solar panels with your power stations.
EcoFlow Solar Extension Cable(2M), provides a longer extension range for series connection of solar panels.
EcoFlow 125W Bifacial Modular Solar Panel Charging Times
What‘s In The Box
Rated Power
STC 125W (±3W) BNPI 138W (±3W)
Open Circuit Voltage
50V
Short Circuit Current
STC 3.2A BNPI 3.4A
Optimal Operating Voltage
43V
Optimal Operating Current
STC 3ABNPI 3.2A
Recommended Ambient Temperature
-40°C to 85°C (-24°F to 185°F)
Efficiency
25%
Bifaciality Coefficients
80%±5%
Weight
Approx. 4.2 kg (9.26 lbs)
Dimensions (L×W×H)
612×1154×22 mm (24.1×45.4×0.87 in)
Maximum System Voltage
600V DC (IEC/UL)
Cell Type
TOPCon monocrystalline silicon
Connector Type
XT60
Waterproof & Dustproof Rating
Solar Panel IP68 XT-60 Connector IP68
Warranty (US)
5 Years
Lifespan
30 years, 90%
Footnotes:
[1] Tested under optimal conditions.
[2] The maximum combined power output of the 125W bifacial panel is 138W. Under the same lighting conditions, the bifacial panel can generate up to 10% more power on the rear side compared to a single-sided panel, calculated as (138-125)/125 * 100% = 10.4%.
[3]The term "3M" and "dual lock" are both trademarks belonging to the 3M Company, also known as the Minnesota Mining and Manufacturing Company.
[4] Included with the 500W (125W × 4) bifacial modular solar panel set.
Thanks for sharing!
