EcoFlow WAVE 2 + Add-on Battery + EcoFlow WAVE 2 Bag | WAVE 2 + Add-on Battery + WAVE 2 Bag | EcoFlow
EcoFlow WAVE 2 + Add-on Battery + EcoFlow WAVE 2 Bag EcoFlow WAVE 2 + Add-on Battery + EcoFlow WAVE 2 Bag
USD $2,267.00
Regular price USD $2,267.00
Sale price USD $2,267.00 Regular price $2,267.00
-$0
Up to EcoCredits for cash deduction
Please note that the estimated shipment of WAVE 2 Add-on Battery and Bag begins in mid September.
• Fastest Cooling and Heating
• Installation-free! Fits Anywhere
• 8 Long Hours of Comfort
• 44dB: Perfect For Quiet Sleep
• Using R290: A Greener Way to Beat the Heat
• 4 Ways to Charge
USD $2,267
A 1800W AC output means you can power more than 90% of yourhome appliances.That's your microwave fridge, or even coffee maker covereed in a blackout. Or, tryplugging in upto 13 devices at once for when you're around the table with the family.Unlike other brands, DELTA 2 can prevent overloading from devicces up to 2400W..thankstoX-Boost technology.
The world's first wireless portable AC with a heater
Fastest cooling and heating
EcoFlow's tailor-made compressor enables WAVE 2 to provide 5100 BTUs of cooling and 6100 BTUs of heating. Prepare for ultimate comfort with WAVE 2!
  • 5 min of cooling from 86°F to 68°F (-18°F)
  • 5 min of heating from 68°F to 86°F (+18°F)
  • The Gold Standard in cooling - 120% more powerful than industry norms
*Drop 50°F from 95°F for 10m³ in 5 min with 5100 BTUs of cooling and raise 50°F from 68°F in 5 minutes for 10m³ with 6100 BTUs of heating in optimal running performance.
Installation-free! Fits pretty much anywhere
Ideal for any compact space, WAVE 2 is simple to use, requirinig no installation or even drainage*. With a variety of air duct adapters that fit any space you can enjoy the convenience of cooling and heating without any fuss.
* No drainage is needed in cooling mode, only in heating mode.
Sleep peacefully, all night long
With EcoFlow's advanced software algorithm. WAVE 2 offers multiple modes and app control. In Sleep Mode. WAVE 2 runs quietly at only 44 dB and for as long as 8 hours in Eco Mode. Experience long-lasting comfort in your tent, RV,or home with its powerful and portable design.
With a capacity of 1kWh to start with, you've got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra batttery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
Power pretty much anything
A 1800W AC output means you can power more than 90% of yourhome appliances.That's your microwave fridge, or even coffee maker covered in a blackout. Or, try plugging in upto 13 devices at once for when you're around the table with the family. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2400W thanks to X-Boost technology.
AC Input
100/240V, 50/60Hz, 820W Max
Solar Charging Input
11-60V, 13A, 400W Max
Car Charging Input
96W/192W (12/24V, 8A Max)
Add-on Battery Power
700W Max
Approximately 14.5 kg (32.0 lbs)
518 × 297 × 336 mm (20.4 × 11.7 × 13.2 in)
Bluetooth
Wi-Fi
This product supports 2.4G Wi-Fi only
Noise Level
44-56dB
Refrigerant/Amount
R290/130 g
No-Drain Function
Supported (in cooling state)
Cooling Area
≤ 10 ㎡ / 107.6 ft²
IP Rating
IPX4
Rated Cooling Input Power (AC/DC)
550W/495W
Cooling Capacity
1500W/5100BTU
600W/540W
Heating Capacity
1800W / 6100BTU
Optimal Operating Temperature
5°C-50°C (41°F-122°F)
Charge Temperature
0°C-45°C (32°F-113°F)
Discharge Temperature
–20°C-50°C (–4°F-122°F)
Ambient Temperature for Storage
–10°C-60°C (14°F-140°F)
Temperature Setting Range
16°C-30°C (60°F-86°F)
