EcoFlow DELTA + 160W Solar Panel
100% secure shopping
Reliable warranty
Free shipping
Regular price
$1,797.00
Sale
$1,797.00
Regular price
$2,299.00
Sold out
per
Model
  • DELTA (1300)
  • DELTA (1000)
Number of Solar Panel
  • 1
  • 2
  • 3
  • 4
View cart
  • RECHARGE 0%--80% WITHIN 1 HOUR The patented EcoFlow X-Stream technology enables you to charge the DELTA from 0-80% within 1 hour and offers a full charge in just 2 hours. Use the EcoFlow 160W Solar Panel to charge DELTA in 10.5-21 hours at a recharging rate of 10-65V/10A max, 400W max input.
  • 6x AC OUTLETS (Total 1800W) & 1260Wh CAPACITY DELTA can power up to 13 devices simultaneously with multiple outlet options, including 6 pure sine wave AC outlets. It offers up to 1260Wh power, which is ideal for home backup situations where you need to power smartphones, laptops, refrigerators, and more.
  • INTELLIGENT SOLAR CHARGING The EcoFlow 160W Solar Panel has a high conversion efficiency of 21-22%. Combine the 160W Solar Panel with an EcoFlow Power station to enjoy improved solar charging in cold and cloudy environments.
  • DURABLE, DUST & WATER RESISTANT The EcoFlow 160W Solar Panel has IP67 rated dust and water resistance, which is thanks to a seamless, one-piece design, making it ideal for outdoor activities like camping and hiking. An ETFE film provides extra protection against ultraviolet light, prolonging the lifespan of the product.
*Please NOTE: This item is only available for sale in the contiguous United States.
Customer reviews
4.0 563 Reviews
  • 5 star
    75%
  • 4 star
    60%
  • 3 star
    10%
  • 2 star
    8%
  • 1 star
    1%
Reliable warranty
Free shipping
Stay in charge of any situation with DELTA and keep your devices powered at all times. DELTA has a huge 1260Wh capacity that’s perfect for power outages, outdoor adventures, and professional work.
High Capacity
X-Stream Fast Charge
6x AC Outlets
Power Multiple Devices
The world’s fastest charging portable power stations
EcoFlow have the world's fastest charging power stations. DELTA charges from 0-80% in under an hour, giving you a quick boost of power even during the worst situations.
So Much More Sun
32 premium monocrystalline silicon cells provide a high conversion efficiency of 22%. Recharge even faster by chaining multiple panels in series or in parallel.
Better Together
Recharge freely and naturally when you link EcoFlow’s 110W Solar Panel to a DELTA portable power station.
What’s in the Bundle
1. EcoFlow DELTA 2. DELTA Bag 3.Solar Panel Charging Cable 4. 1.5m AC Charging Cable 5. 1.5m Car Charging Cable 6. User Manual of DELTA 7. 110W Solar Panel 8. 110W Solar Panel Bag 9. User Manual of 110W Solar Panel
Compare The Models
DELTA
Capacity:1260Wh
Life Cycles: 800+ Cycle
Output: 1800W (Surge 3300W)
AC Input: 1200W Max
Solar Input: 400W
$1399
RIVER Pro
Capacity:720Wh
Output: 600W (Surge 1200W)
AC Input: 660W Max
Solar Input: 200W
$649
RIVER Max
Capacity:576Wh
Life Cycles: 500+ Cycle
AC Input: 500W Max
Solar Input: 200W
$599
DELTA can be recharged to 0%~80% in 1 hour, and be fully recharged within 1.6 hours.
Under perfect sunlight conditions, DELTA can be fully charged with the following solar panel setups: 1x 110W solar panel: 16h-32h 2x 110W solar panel (in series): 7.5h-15h 3x 110W solar panel (in series): 5h-10h 4x 110W solar panel: 4-8hrs
Yes. During this situation, DELTA will prioritise AC charging, and default to DC charging when AC charging is not used.
It can be an emergency power source (EPS), which will have the same result as UPS for most electronics. Here's the difference. When your DELTA is plugged into the wall, anything plugged into it gets power from the grid, not its battery. If power from the grid stops, DELTA automatically switches to its battery supply mode within 30 milliseconds. That means anything connected will not have power for 30 milliseconds, which may mean sensitive electronics like desktop computers and data servers turn off. Test your devices individually to see if they need UPS to stay powered.
DELTA can power essential devices whether you’re at home or outdoors. Devices include lights, microwave ovens, fridges, hairdyers, laptops, phones, electric frying pans, and more.
Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
Yes, if the only thing between it and the sun is transparent, but it won’t charge as well compared to being outside. You can compare the difference by looking at the input section of your power station’s LCD screen.
Specs of DELTA (1300)
30.9lbs (14kg)
Dimension
15.7 x 8.3 x 10.6 in (40 x 21 x 27 cm)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
Color
Gray & black
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel
Full Recharge Time
1.6 Hours (AC) 13.5 Hours (12/24V Car Adaptor) 4-8 Hours (Using 4x 110W Solar Panels in parallel) 3.5-7 Hours (Using 3x 160W Solar Panels) 4-8 Hours (Using 1x400W Solar Panel)
1260Wh (50.4V)
Cell Chemistry
Lithium-ion
Shelf Life
1 year (after fully charged)
Life Span
800 Cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection.
Testing and certification
UL CE FCC RoHS PSE
Cell Type
18650
AC Charge Input Power
X-Stream charge (1200W max)
AC Charge Input Voltage
100-120Vac (50Hz/60Hz)
Solar Charge Input
400W 10-65V DC 10A max
Car Charger
12V/24V DC 8A max
AC Output (x6)
1800W total (Surge 3300W), 120Vac (60Hz)
USB-A Output (x2)
5V DC, 2.4A, 12W Max, per port
USB-A Fast Charge (x2)
5V/2.4A,9V/2A,12V/1.5A 18W Max
USB-C Output (x2)
5V DC, 9V DC, 15V DC, 20V DC, 3A, 60W Max, per port
Car Power Output (x1)
108.8W, 13.6V DC, 8A max
Specs of DELTA (1000)
30.9lbs (14kg)
Dimension
Charge Temperature
Color
Gray & black
24 months
Charge Method
Full Recharge Time
1.6 Hours (AC) 10.5 Hours (12/24V Car Adaptor) 2.6-5.3 Hours (Using 3x 160W Solar Panels) 3.2-6.3 Hours (Using 1x 400W Solar Panel)
1008Wh
Cell Chemistry
NCM
Shelf Life
Life Span
500 cycles to 80+% capacity
Management Systems
UL CE FCC RoHS PSE
Cell Type
18650
X-Stream charge (1000W max)
Solar Charge Input
Car Charger
12V/24V DC 8A max
AC Output (x6)
1600W total (Surge 3100W), 120Vac (60Hz)
USB-A Output (x2)
USB-C Output (x2)
Specs of 110W Solar Panel
Weight
13.2 lb (Solar Panel 8.8 lb)
Unfolded Dimensions
62.5 × 20.2 × 1.0 in (158 × 51.4 × 2.4 cm)
Folded Dimensions
16.5 × 20.2 × 1.0 in (42 × 51.4 × 2.4 cm)
12 months
Rated Power
110W (±5W)
Efficiency
21%–22%
Connector Type
MC4
Open Circuit Voltage
21.7V (Vmp 18.5V)
Short Circuit Current
6.3A (Imp 6.0A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−4°F to 185°F
