- RECHARGE 0%--80% WITHIN 1 HOUR The patented EcoFlow X-Stream technology enables you to charge the DELTA from 0-80% within 1 hour and offers a full charge in just 2 hours. Use the EcoFlow 160W Solar Panel to charge DELTA in 10.5-21 hours at a recharging rate of 10-65V/10A max, 400W max input.
- 6x AC OUTLETS (Total 1800W) & 1260Wh CAPACITY DELTA can power up to 13 devices simultaneously with multiple outlet options, including 6 pure sine wave AC outlets. It offers up to 1260Wh power, which is ideal for home backup situations where you need to power smartphones, laptops, refrigerators, and more.
- INTELLIGENT SOLAR CHARGING The EcoFlow 160W Solar Panel has a high conversion efficiency of 21-22%. Combine the 160W Solar Panel with an EcoFlow Power station to enjoy improved solar charging in cold and cloudy environments.
- DURABLE, DUST & WATER RESISTANT The EcoFlow 160W Solar Panel has IP67 rated dust and water resistance, which is thanks to a seamless, one-piece design, making it ideal for outdoor activities like camping and hiking. An ETFE film provides extra protection against ultraviolet light, prolonging the lifespan of the product.
*Please NOTE: This item is only available for sale in the contiguous United States.
Customer reviews
5 star
4 star
3 star
2 star
1 star
Stay in charge of any situation with DELTA and keep your devices powered at all times. DELTA has a huge 1260Wh capacity that’s perfect for power outages, outdoor adventures, and professional work.
High Capacity
X-Stream Fast Charge
6x AC Outlets
Power Multiple Devices
The world’s fastest charging portable power stations
EcoFlow have the world's fastest charging power stations. DELTA charges from 0-80% in under an hour, giving you a quick boost of power even during the worst situations.
So Much More Sun
32 premium monocrystalline silicon cells provide a high conversion efficiency of 22%. Recharge even faster by chaining multiple panels in series or in parallel.
Better Together
Recharge freely and naturally when you link EcoFlow’s 110W Solar Panel to a DELTA portable power station.
Title
What’s in the Bundle
1. EcoFlow DELTA 2. DELTA Bag 3.Solar Panel Charging Cable 4. 1.5m AC Charging Cable 5. 1.5m Car Charging Cable 6. User Manual of DELTA 7. 160W Solar Panel 8. 160W Solar Panel Bag 9. User Manual of 160W Solar Panel
Compare The Models
DELTA
Capacity:1260Wh
Life Cycles: 800+ Cycle
Output: 1800W (Surge 3300W)
AC Input: 1200W Max
Solar Input: 400W
$1399
RIVER Pro
Capacity:720Wh
Output: 600W (Surge 1200W)
AC Input: 660W Max
Solar Input: 200W
$649
RIVER Max
Capacity:576Wh
Life Cycles: 500+ Cycle
AC Input: 500W Max
Solar Input: 200W
$599
Specs of DELTA (1300)
30.9lbs (14kg)
Dimension
15.7 x 8.3 x 10.6 in (40 x 21 x 27 cm)
Charge Temperature
32 to 113°F (0 to 45°C)
Discharge Temperature
-4 to 113°F (-20 to 45°C)
Color
Gray & black
24 months
Charge Method
AC Wall Outlet, 12V Car Adaptor, Solar Panel
Full Recharge Time
1.6 Hours (AC) 13.5 Hours (12/24V Car Adaptor) 4-8 Hours (Using 4x 110W Solar Panels in parallel) 3.5-7 Hours (Using 3x 160W Solar Panels) 4-8 Hours (Using 1x400W Solar Panel)
1260Wh (50.4V)
Cell Chemistry
Lithium-ion
Shelf Life
1 year (after fully charged)
Life Span
800 Cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection, Low Temperature Protection, Low Voltage Protection, Overcurrent Protection.
Testing and certification
UL CE FCC RoHS PSE
Cell Type
18650
AC Charge Input Power
X-Stream charge (1200W max)
AC Charge Input Voltage
100-120Vac (50Hz/60Hz)
Solar Charge Input
400W 10-65V DC 10A max
Car Charger
12V/24V DC 8A max
AC Output (x6)
1800W total (Surge 3300W), 120Vac (60Hz)
USB-A Output (x2)
5V DC, 2.4A, 12W Max, per port
USB-A Fast Charge (x2)
5V/2.4A,9V/2A,12V/1.5A 18W Max
USB-C Output (x2)
5V DC, 9V DC, 15V DC, 20V DC, 3A, 60W Max, per port
Car Power Output (x1)
108.8W, 13.6V DC, 8A max
Specs of DELTA (1000)
30.9lbs (14kg)
Dimension
Charge Temperature
Color
Gray & black
24 months
Charge Method
Full Recharge Time
1.6 Hours (AC) 10.5 Hours (12/24V Car Adaptor) 2.6-5.3 Hours (Using 3x 160W Solar Panels) 3.2-6.3 Hours (Using 1x 400W Solar Panel)
1008Wh
Cell Chemistry
NCM
Shelf Life
Life Span
500 cycles to 80+% capacity
Management Systems
UL CE FCC RoHS PSE
Cell Type
18650
X-Stream charge (1000W max)
Solar Charge Input
Car Charger
12V/24V DC 8A max
AC Output (x6)
1600W total (Surge 3100W), 120Vac (60Hz)
USB-A Output (x2)
USB-C Output (x2)
Specs of 110W Solar Panel
Weight
13.2 lb (Solar Panel 8.8 lb)
Unfolded Dimensions
62.5 × 20.2 × 1.0 in (158 × 51.4 × 2.4 cm)
Folded Dimensions
16.5 × 20.2 × 1.0 in (42 × 51.4 × 2.4 cm)
12 months
Rated Power
110W (±5W)
Efficiency
21%–22%
Connector Type
Solar Connector
Open Circuit Voltage
21.7V (Vmp 18.5V)
Short Circuit Current
6.3A (Imp 6.0A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−4°F to 185°F
The EcoFlow RIVER Max features the RIVER power station plus an Extra Battery, which doubles up the battery capacity and offers you reliable, portable, and easy-to-access power wherever you are.
X-Boost Technology
The EcoFlow X-Boost technology gives you the ability to use the 600W inverter to power essential devices like kitchen appliances and tools up to 1800W. This unique technology is perfect for outdoor adventures when you need to power your favorite devices on the go. Please conduct full test on a case-by-case basis to confirm the X-Boost feature works with your appliances. Use X-Boost with devices below 1200W for the best product experience.
X-Stream Charging Technology
EcoFlow’s X-Stream technology offers one of the fastest recharging rates for a power station on the market. With the built-in smart inverter, EcoFlow RIVER Max can recharge from 0-80% within 1 hour, achieving a full charge in just 1.6 hours.
Modular Design + Extra Battery
The EcoFlow RIVER Max features a compact, modular design that allows you to attach an extra battery to double the capacity of the device from 288Wh to 576Wh. Alternatively, you can detach the Extra Battery to make the device more portable. Whether you’re with family or going on a solo road trip, the modular design gives you all the freedom to customize your power options however you like.
Power 10 Devices Simultaneously
EcoFlow RIVER Max fits many types of the ports you’ll need to charge all your devices. The 100W USB-C is perfect for charging laptops while the full sine wave AC outlets give you more flexibility in charging heavy duty devices. With the informative EcoFlow APP, you can control and monitor the unit on your hands.
Efficient Solar Power
The EcoFlow RIVER Max is also compatible with the EF Solar Panels, which provide you with a way to generate clean, reliable solar power on the go. Two 110W Solar Panels can be connected in parallel to charge the EcoFlow RIVER Max from 3-6 hours.
Easy-to-Carry Handle
Introducing the future of portable power stations. EcoFlow RIVER Max weighs 17lbs, is exceptionally durable, and features an easy-to-carry handle. This incredibly portable power station can be taken around wherever you go, whether that be on your car trunk, coffee table, or the great outdoors. It’s that easy.
Power a Wide Range of Devices
The RIVER Max comes with three AC outlets. (Note that the total rated wattage of the three AC outlets is 600W (surge 1200W)). With a built-in 600W inverter, the RIVER Max can power devices up to 1800W with the X-Boost mode on. This provides support for a wide range of essential devices such as a fridge, TV, laptop, hairdryer, and more.
Note: It is not recommended to use the RIVER series power station to power heavy-duty devices e.g., air conditioners, ovens or washing machines.
Warning: DO NOT use RIVER series portable power station AC charging cables on DELTA series power stations. EcoFlow takes no responsibilities for any damages caused by customers' failure to follow instructions. Doing so will void the warranty.
What EcoFlow RIVER Max Can Power?
*The duration and times of the appliances indicated in this table are for reference only.
Specifications
General Info | |
Net Weight | *17 lbs (7.7kg) |
Dimension | *11.4 x 7.3 x 9.3 in (28.9 x 18.4 x 23.5 cm) |
Charge Temperature | 32-113°F +/- 5°F (0-45°C +/- 3°C) |
Discharge Temperature | -4-113°F +/- 5°F (-20-45°C +/- 3°C) |
Color | Cyber Black |
Warranty | 24 months |
Charging | |
Charge Method | AC Wall Outlet, 12V Car Adaptor, Solar Panel |
Full Recharge Time | 1.6 Hours (AC)
6.5 Hours (12/24V Car Adaptor) 3-6 Hours (Using 2x110W Solar Panels in parallel with full sun) 4.8-9.6 Hours (Using 1x160W Solar Panel with full sun) |
Battery Info | |
Capacity | 576Wh (28.8V) |
Cell Chemistry | Lithium-ion |
Shelf Life | 1 year (after fully charging the device) |
Cycle Life | 500 Cycles to 80%+ capacity |
Management Systems | BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection Low Temperature Protection, Low Voltage Protection, Overcurrent Protection |
Testing and certification | UL Standard CE FCC RoHS RCM |
Input Ports | |
AC Charge Input Power | X-STREAM Charge 500W max |
AC Charge Input Voltage | 100-120Vac(50Hz/60Hz) International Version 220-240Vac(50Hz/60Hz) |
Solar Charge Input | 200W 10-25V DC 12A Max |
Car Charger | 12V DC 8A Max |
Output Ports | |
AC Output (x3) | 600W (Surge 1200W) total,120Vac( 50Hz/60Hz) |
USB-A Output (x2) | 5V DC,2.4A,12W Max, per port |
USB-A Fast Charge (x1) | 5V DC,9V DC,12V DC,2.4A,28W Max |
USB-C Output (x1) | 5V DC,9V DC,12V DC,15V DC,20V DC,5A,100W Max |
Car Power Output (x1) | 136W, 13.6V DC, 10A Max |
DC5521 Output (x2) | 13.6V DC, 3A Max, per port |
EcoFlow RIVER Max Portable Power Station
Product | Quantity |
EcoFlow RIVER Max | X 1 |
DC5521-DC5525 Cable | X 1 |
1.5m MC4 to XT60 Solar Charging Cable | X 1 |
1.5m AC
1.5m Car
User Manual | X 1 |
User Manual
- Click to Download EcoFlow RIVER Max User Manual
