Buy EcoFlow DELTA Pro Portable Power Station | DELTA Pro + DELTA Pro Smart Extra Battery | EcoFlow
EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station
USD $4,099.00
Hot
Video
Hot
Regular price USD $4,099.00
Sale price USD $4,099.00 Regular price $6,498.00
-$2,399
Up to EcoCredits for cash deduction
Get up to $1,229.70 in rebates through the Residential Clean Energy Credit. Learn More >
Up to $1,229.70 in rebates
Amount 30% off
Claim By: December 31, 2032
Program: Residential
  • Rentals do not qualify.
  • Must be grid-tied.
• 3.6-25kWh expandable capacity with DELTA Pro Smart Extra Battery
USD $749 USD $1,199
22.6% Conversion Rate | IP68
USD $1,599 USD $2,799
USD $599
USD $749 USD $1,199
USD $599
USD $599
USD $599
You Could Apply for 30% Tax Credit*, When You Install DELTA Pro as a Home Power Solution Learn more
USD $4,099 $6,498 -$2,399
$3,299.00 $4,798.00
“Enjoy Free Solar Energy with 50% lower price”
Fast Charge with 23% conversion rateFull charge with solar in 3.8hr
Add To Cart
EcoFlow DELTA Pro + EcoFlow DELTA Pro Smart Extra Battery
DELTA Pro + Smart Extra Battery
$4,099.00 $6,498.00
“Enjoy 3X power capacity with 50% lower price”
Expand your DELTA Pro to 10.8kWhTriple power at up to 50% lower cost
Add To Cart
Power for any situation.
All the AC output you’ll need.
A single DELTA Pro unit packs a 3600W AC output, which can be expanded up to 4500W with X-Boost technology. Power 99.99% heavy-duty devices at home, outdoors, or at work. You can even pair two units together to achieve 7200W.
Simple, sustainable, and affordable whole-home backup power solutions with an output power of up to 7200W and a whopping 21.6kWh capacity for security and comfort. Easily chain together two DELTA Pros using the Double Voltage Hub and plug in to your breaker panel via a transfer switch. The solution provides a convenient home battery system without rewiring or running dangerous extension cables through your home.
A clean energy alternative.
Power your entire home.
With the Double Voltage Hub, DELTA Pro* provides unparalleled AC output of up to 7200W and 240V. Run 99% of all home appliances, even high-wattage clothes dryers and electric heaters, so you can keep your home running smoothly.*Double Voltage Hub requires two EcoFlow DELTA Pro units.
Smart energy management.
Travel without limits.
Connect DELTA Pro with an Extra Battery for a huge capacity of 7.2kWh, and stay powered for up to a week*. Run daily essentials such as a fridge, laptop, coffee maker, and even the air conditioner. You'll have the power to experience all that nature has to offer.
EV backup charging solution.
Power that means business.
Unleash your creativity.
Take energy on the go and get the creative juices flowing. Whether you're a filmmaker capturing precious moments or just want to work on the go, DELTA Pro's impressive output and large capacity can power all your equipment, ensuring a smooth workflow no matter where you are.
Customize a simple, reliable and sustainable home backup system to keep your essential circuits running when a blackout hits. Ensure peace of mind with the easily integrated whole-home backup kit: DELTA Pro, Transfer Switch, and Power Cord.
What's the max input DELTA Pro can achieve?
When charging DELTA Pro and its extra battery together, you can reach 6500W max charging speeds by combining AC, solar and Smart Generator methods. For DELTA Pro single unit, you can recharge it at standard wall outlets (1800W max), at EV station (3400W max)/Smart Home Panel/240V outlets (3000W max).
How many solar panels can I use at the same time?
It depends on the combined voltage and current of the solar panels you choose. It's fine as long as the solar panels use connectors and their combined voltage and current are within 11-150 volts and under 15 amps.
Can I run a 240V device on the 120V US version?
You'll need to connect two DELTA Pro units to power 240V electronics. You can do this by: 1) the Double Voltage Hub and use the AC outlets on the hub, or 2) the Smart Home Panel and use your home's 240V outlets (you'll need to setup 240V wiring on the Smart Home Panel during installation).
How do I update the firmware?
First of all, make sure your DELTA Pro is connected to the EcoFlow App using Internet mode. Secondly, go to the Firmware section in the Setting of the DELTA Pro you're looking to upgrade. Check for the latest firmware and follow the steps to finish the upgrade.
How do I recharge DELTA Pro at 200V-240V in a 100V-120V region?
The cable provided with your DELTA Pro won’t plug into higher-voltage outlets, and you’ll need a third party adapter/charging cable.
3600Wh
Extra Battery
4500W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
Anderson Port
12.6V, 30A
AC Charging Input
Solar Charging Input
1600W Max, 11-150V, 15A Max
Car Charging Input
Support 12V/24V battery, 8A
Connection
Wi-Fi, Bluetooth
Approx. 99lbs/45kg
Dimension
Disclaimer
Effective date: Jan 1, 2023
