EcoFlow DELTA Pro Solar Generator (PV220W) | 1*220W + DELTA Pro | EcoFlow
EcoFlow DELTA Pro Solar Generator (PV220W) EcoFlow DELTA Pro Solar Generator (PV220W) EcoFlow DELTA Pro Solar Generator (PV220W) EcoFlow DELTA Pro Solar Generator (PV220W)
USD $3,799.00
Regular price USD $3,799.00
Sale price USD $3,799.00 Regular price $4,248.00
-$449
Up to EcoCredits for cash deduction
  • An economical home backup solution that protects your home from frequent power outages.
  • Generates up to 7.8kWh daily with 4 pieces of 220W Portable Solar Panel.
  • A 4500 AC output with X-Boost.
  • Up to 23% conversion with a unique two-in-one bifacial design to guarantee a fast solar charging speed: 0-100% in 5 hours (4 sets), 6.5 hours (3 sets), and 10 hours (2 sets).
  • IP68 dust and water resistance.
  • Smart remote control with EcoFlow app.
  • 5-year warranty for DELTA Pro and 12-month warranty for 220W Bifacial Portable Solar Panel.
**DELTA Pro and 220W Bifacial Portable Solar Panel will be shipped separately.
Shipment services to Alaska, Puerto Rico, and Hawaii are temporarily suspended.
USD $3,799 $4,248 -$449
Introducing the world's first portable home battery with an expandable ecosystem for home backup, smart energy management, lower energy bills, and more. The EcoFlow DELTA Pro is the next leap in portable power technology, offering you power security and independence, wherever you are.
Expandable Capacity
Power Pretty Much Anything (3600W-7200W Output)
World's Fastest Charging (MultiCharge 6500W)
Home Integration
Power for any situation.
All the AC output you’ll need.
A single DELTA Pro unit packs a 3600W AC output, which can be expanded up to 4500W with X-Boost technology. Power 99.99% heavy-duty devices at home, outdoors, or at work. You can even pair two units together to achieve 7200W.
Fully charge in 1.8 hours.
EcoFlow’s X-Stream charging technology isn't just fast, it's safe too. The battery management system ensures safety and longevity while you fully charge DELTA Pro from a standard AC wall outlet in 1.8 hours*.
Charge up at thousands of EV stations worldwide.
For the first time ever with a portable power station, you can charge up at thousands of EV stations worldwide. This unique charging method gives you up to 3400W fast charging on the go.
Go renewable with 1600W solar charging.
EcoFlow's suite of solar products give you a cost-effective renewable energy source to stay powered. You can use solar energy to charge DELTA Pro in just 2.8-5.6 hours. DELTA Pro has a wide voltage range from 11-150V, which makes it compatible with 90% of third-party solar panels with Solar connectors. And when the weather gets unpredictable, the smart maximum power point tracking (MPPT) automatically adjusts, maximizing your solar generation at any time of the day.
Get emergency backup power with the EcoFlow Smart Generator.
The EcoFlow Smart Generator serves as an emergency option that integrates with your DELTA Pro ecosystem. It auto-starts when your DELTA Pro hits a low level of charge, re-charges your DELTA Pro, and stops the engine all by itself once your DELTA Pro hits a full charge. Compared to a traditional gas generator, the EcoFlow Smart Generator delivers less energy loss, faster charging and higher efficiency.
Multiple ways to control & monitor.
Control DELTA Pro either on the unit itself, using the remote control accessory, or unlock a ton of customization via the EcoFlow app. On the app, you can access your power settings, such as charging and discharging levels, AC charge speeds, control the Smart Generator and a whole lot more.
The world’s first portable home battery ecosystem.
DELTA Pro's expandable ecosystem provides you with power during blackouts, customizable energy around the clock, and lower energy bills. How does it achieve all this? With a selection of extra batteries, smart generators, solar trackers, wind turbines, a smart home panel, and more. From backup power to reducing your reliance on the grid with green alternatives, the DELTA Pro ecosystem can be customized to your needs.
Introducing the EcoFlow Smart Home Panel.
The new EcoFlow Smart Home Panel is the heart of the DELTA Pro home battery ecosystem. It integrates up to two DELTA Pro units with 10 home circuits. Each DELTA Pro can be connected with extra batteries, solar panels, or smart generators, giving you uninterrupted power during blackouts, smart energy management for your critical loads, and lower energy bills.
Uninterrupted home backup.
With a fast 20ms switchover time, DELTA Pro and the Smart Home Panel can keep you powered on during a blackout. All the while, the EcoFlow app keeps you in the know, letting you select and modify your device priorities.
Smart Energy Management.
The EcoFlow DELTA Pro ecosystem stores energy day and night, reducing your reliance on the grid and lowering your energy bills by combating time-of-use rates. It integrates directly with your home using the EcoFlow Smart Home Panel. The EcoFlow app gives you a smart breakdown of your energy habits, and you can customize your energy usage for any type of situation.
RV living made easy.
With DELTA Pro, you can take home with you, wherever you go. It features wheels and a suitcase-esque extendable handle that makes transport easy. And if you’re looking for a complete power solution for RV road trips and outdoor adventures, DELTA Pro comes with dedicated 30A Anderson port and AC outlet.
Power that means business.
Not only does DELTA Pro provide home backup and off-grid power, it also gives you a secure power source for any type of professional work. Whether you’re working at home or outdoors, from DIY to professional projects, DELTA Pro helps you get the job done.
Specs of DELTA Pro
3600Wh
Extra Battery
4500W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
Anderson Port
12.6V, 30A
AC Charging Input
Solar Charging Input
1600W Max, 11-150V, 15A
Car Charging Input
Support 12V/24V battery, 8A
Connection
Wi-Fi, Bluetooth, wired
Approx. 99lbs/45kg
Dimension
Specs of 220W Solar Panel
Rated Power
220W Front Side/155W Rear Side
Cell Type
Monocrystalline Silicon
Efficiency
22-23%
82*183*2.5cm (32.3*72.0*1.0 in)
Connector Type
Solar Connector
Open Circuit Voltage
21.8V (Vmp 18.4V)
Short Circuit Current
13A (Imp 12.0A) Front Side/ 8.8A (Imp8.4A) Rear Side
Weight (Solar Panel)
Approx. 9.5kg (20.9lbs)
