EcoFlow DELTA Max Solar Generator (PV220W) | DELTA Max (2000) / 1*220W | EcoFlow
EcoFlow DELTA Max Solar Generator (PV220W) EcoFlow DELTA Max Solar Generator (PV220W) EcoFlow DELTA Max Solar Generator (PV220W) EcoFlow DELTA Max Solar Generator (PV220W) EcoFlow DELTA Max Solar Generator (PV220W) EcoFlow DELTA Max Solar Generator (PV220W) EcoFlow DELTA Max Solar Generator (PV220W) EcoFlow DELTA Max Solar Generator (PV220W)
USD $1,599.00
Regular price USD $1,599.00
Sale price USD $1,599.00 Regular price $2,748.00
-$1,149
Up to EcoCredits for cash deduction
  • Generates up to 3.5kWh to 4kWh daily.
  • 2800W to 3400W AC output with X-Boost.
  • Up to 23% conversion with a unique two-in-one bifacial design to guarantee a fast solar charging speed: 0-100% in 3-3.5 hours (3 sets), 4.5-5.5 hours (2 sets) and 9-11 hours (1 set).
  • IP68 dust and water resistance.
  • Smart remote control with EcoFlow app.
  • 3-year warranty for DELTA Max and 12-month warranty for 220W Bifacial Portable Solar Panel.
**DELTA Max and 220W Bifacial Portable Solar Panel will be shipped separately.
Shipment services to Alaska, Puerto Rico, and Hawaii are temporarily suspended.
Model
Number of Solar Panel
USD $1,599 $2,748 -$1,149
Expandable Capacity
Dual Charging
Power Multiple Devices
800W max Solar Input
Multiple ways to charge.
It depends on the total voltage and watts of solar panels you choose. As long as the solar panels use MC4 connector and its voltage and current are under 11-100V, 13A max range.
When charging DELTA Max and its extra battery together, you can reach 3600W max charging speeds by combining any two methods of AC, solar and Smart Generator. For DELTA Max single unit, you can recharge it at standard wall outlets (1800W max), or combine AC and solar charging to reach max 2000W charging speeds.
When your portable power station is plugged into the wall, any electronics plugged into it are powered from the grid and not its battery. When power from the grid stops, as in a blackout, the power station automatically switches to battery power within 30ms.
DELTA Max is not water-resistance, so it should be kept away from liquids. Or if you're looking for water-resistance solution, you can purchase the DELTA Max case to water-resistance protection.
Specs of DELTA Max (2000)
2016Wh
Extra Battery
Support up to two DELTA Max Smart Extra Battery/Smart Generator
6 outlets, 2400W total (Surge 5000W)
3400W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
AC Charging Input
1800W Max, 15A
Solar Charging Input
800W Max, 11-100V, 13A
Car Charging Input
Support 12V/24V battery, 8A
NCM
800 cycles to 80% capacity
Connection
Wi-Fi
Approx. 48lbs
Dimension
19.6*9.5*12 in
Specs of DELTA Max (1600)
1612Wh
Extra Battery
6*20A outlets, 2000W total (Surge 5000W)
2800W
USB-A Fast Charge
Car Power Output
DC5521 Output
AC Charging Input
1600W Max, 15A
Car Charging Input
NCM
500 cycles to 80% capacity
Connection
Wi-Fi
Approx. 48lbs
Dimension
19.6*9.5*12 in
Specs of 220W Solar Panel
Rated Power
220W Front Side/155W Rear Side
Cell Type
Monocrystalline Silicon
Efficiency
22-23%
82*183*2.5cm (32.3*72.0*1.0 in)
Connector Type
Solar Connector
Open Circuit Voltage
21.8V (Vmp 18.4V)
Short Circuit Current
13A (Imp 12.0A) Front Side/ 8.8A (Imp8.4A) Rear Side
Weight (Solar Panel)
Approx. 9.5kg (20.9lbs)
*DELTA Max needs to be connected to the DELTA Max Smart Extra Battery for dual charging.
