EcoFlow DELTA 2 Portable Power Station | (Members-only) DELTA 2 Portable Power Station | EcoFlow
EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station EcoFlow DELTA 2 Portable Power Station
USD $649.00
Hot
Hot
Regular price USD $649.00
Sale price USD $649.00 Regular price $999.00
-$350
Up to EcoCredits for cash deduction
• Huge AC output(2200W with X-Boost Technology)
• 7x Faster AC charging
• Built to last 6x longer
• Control from anywhere
• 5-Year warranty
EcoFlow 220W Bifacial Portable Solar Panel
USD $399 USD $649
23% Conversion Rate | IP68
USD $599 USD $799
USD $599
USD $399 USD $649
USD $599 USD $799
USD $599
USD $399 USD $649
USD $599
USD $649 $999 -$350
♻️You’ll get instant credit to purchase a brand-new EcoFlow DELTA 2. Learn more
DELTA 2 + 220W Bifacial Solar Panel
$999.00 $1,648.00
“Enjoy Free Solar Energy with 50% lower price”
Fast Charge with 23% conversion rateFull charge with solar in 2.3hr
Add To Cart
EcoFlow DELTA 2 + EcoFlow DELTA 2 Smart Extra Battery
DELTA 2 + Smart Extra Battery
$1,199.00 $1,798.00
“Enjoy 2X power capacity with 50% lower price”
Expand your DELTA 2 to 2048WhDouble power at up to 50% lower cost
Add To Cart
EcoFlow DELTA 2 is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
With a capacity of 1kWhto start with, you've got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra battery to reach 2048Wh, the DELTA Max Smart Extra Battery to hit 3040Wh, or the DELTA 2 Max Smart Extra Battery for an impressive 3072Wh. Great for home backup or everyday appliances.
Use an extra battery to expand capacity. Great for extended power outages, long camping trips, or your RV.
Power pretty much anything.
A 1800W AC output means you can power more than 90% of your home appliances. That's your microwave, fridge, or even coffee maker covered in a blackout. Or, try plugging in up to 15 devices at once for when you're around the table with the family. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2200W thanks to X-Boost technology.
Go green without sacrificing speed.
Pair with solar panels and charge in as fast as 3-6 hours with 1x400W, 2x220W portable solar panels. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency. That means a more efficient charge than other brands.
Pick from a range of solar panels to get the speed you need (110W, 160W, 220W, 400W). With that, you've got access to free energy anywhere.
Safety first
DELTA 2's built-in battery management system regulates vitals to keep it safe, secure, and built to stand the test of time.
Ready for emergencies.
A simple power outage solution to power your essential home appliances with 1800W AC output by directly connecting the DELTA 2 with your home's power inlet box* with a generator cord for partial home backup. With a plug-and-play design, it's easier than ever to prepare for blackouts. *including transfer switch which has a male L14-30 twist-lock connection that can accept a L14-30 extension cord.
1. DELTA 2 2. AC Charging Cable 3. Car charging cable 4. DC5521 to DC5525 cable 5. User Manual 6. App quick start guide 7. Warranty card*
The solar to XT60 charging cable is included in EcoFlow portable solar panels.
1024 Wh
Extra Battery
6 outlets, 1800W total (Surge 2700W)
2200W
2 ports, 5V, 2.4A, 12W Max
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A, 38W Max
AC Charging
X-stream Fast Charge 1200W max
AC Input Voltage
100~120V (50Hz/60Hz)
11-60V, 15A, 500W max
Car Charging
Support 12V/24V battery, 8A
DC Charging
1100W
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
27lbs
Net Weight (kg)
12kg
