EcoFlow DELTA 2 Max Portable Power Station | DELTA 2 Max + DELTA 2 Max Smart Extra Battery | EcoFlow
EcoFlow DELTA 2 Max Portable Power Station EcoFlow DELTA 2 Max Portable Power Station EcoFlow DELTA 2 Max Portable Power Station EcoFlow DELTA 2 Max Portable Power Station
USD $2,799.00
Hot
Hot
Regular price USD $2,799.00
Sale price USD $2,799.00 Regular price $3,298.00
-$499
Up to EcoCredits for cash deduction
Get up to $839.70 in rebates through the Residential Clean Energy Credit. Learn More >
Up to $839.70 in rebates
Amount 30% off
Claim By: December 31, 2032
Program: Residential
  • Rentals do not qualify.
  • Must be grid-tied.
• Expandable capacity - 2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit a capacity of 6144Wh. Ideal for home backup, RVing, outdoors or even everyday use.
• Built to last 6× longer - Get 10 years of daily use until hitting 80% of its original capacity. That’s down to its LFP battery chemistry giving you 3000+ cycles.
• Huge AC output - With X-Boost mode get up to 3400W output power to run 99% of home appliances. Power 15 devices at once including 6 AC outlets.
• Fastest recharging - World's fastest AC recharging and X-Stream dual AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3 hours.
• Capture more energy - 99% MPPT efficiency maximizes solar generation anytime.
• Customized in-app energy management - Prioritize solar or AC charging, view input and output power, battery levels and more.
• 5-Year warranty
EcoFlow 220W Bifacial Portable Solar Panel
USD $399 USD $649
23% Conversion Rate | IP68
USD $1,099 USD $1,399
USD $599
USD $399 USD $649
USD $599
USD $399 USD $649
USD $599
USD $2,799 $3,298 -$499
♻️You’ll get instant credit to purchase a brand-new EcoFlow DELTA 2 Max. Learn more
EcoFlow DELTA 2 Max Solar Generator (PV220W)
DELTA 2 Max + 220W Bifacial Solar Panel
$1,799.00 $2,548.00
“Enjoy Free Solar Energy with 50% lower price”
Fast Charge with 23% conversion rateFull charge with solar in 2.3hr
Add To Cart
EcoFlow DELTA 2 Max+ EcoFlow DELTA 2 Max Smart Extra Battery
DELTA 2 Max + Smart Extra Battery
$2,799.00 $3,298.00
“Enjoy 3X power capacity with 50% lower ”
Expand your DELTA 2 Max to 6144WhTriple power at up to 50% lower cost
Add To Cart
Ditch Gas, Go Solar
Winner of Red Dot Design Award 2023. EcoFlow DELTA 2 Max Solar Generator
Durable, Safe, Lightweight
LFP Battery Chemistry
Advanced BMS Protection
Robust Design
Upgraded Tech, Lighter Weight
Power pretty much anything with up to 3400W Output
DELTA Max powers almost all the devices you need with a large 2400W AC output. With X-Boost proprietary technology, run appliances with an output of up to 3400W. Compared with similar portable power stations, DELTA 2 Max can power more devices while also preventing overloading and overheating.
120V Home Backup: Power through outages
Power your essential appliances with a hefty 2400W AC output by connecting DELTA 2 Max (2kWh) and up to two Smart Extra Batteries (6kWh) with your home's transfer switch for partial home backup. With a plug-and-play design, it's easier than ever to prepare for blackouts.
Power for the entire family
2048Wh Capacity
Home Backup
RVing & Outdoors
DIY Projects
Filmmaking & Photography
Expandable up to 6kWh
Triple the power
Fuel Up 80% in Only 43 Mins*
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 1.1 hour.
Take control of your power
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Save more on electricity billsCustomize the working time of DELTA 2 Max to avoid peak rates.
Experience peace of mind during power outages With our all-new AC Always On Mode, the AC power button stays on, even during a power outage or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust power Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings.Prioritize solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
Always power readyGet a notification via the app when the battery hits a low.
Extensive 5-Year Warranty
As Quiet as 30 dB
Peaceful charging
DELTA 2 Series
Learn More About DELTA 2
DELTA 2 Max
DELTA 2 Max
AC Charging Cable
AC Charging Cable
Car Charging Cable
Car Charging Cable
DC5521 to DC5525 Cable
User manual & warranty card
2048Wh
Extra Battery
6 outlets, 2400W total (Surge 4800W)
X-Boost 3400 W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
AC Charging
X-stream Fast Charge 1800W, 15A
AC Input Voltage
100-120V~ max. 15A 50Hz/60Hz
Car Charging
Support 12V/24V battery, 8A
EcoFlow WAVE & WAVE 2 & GLACIER & Smart Generator
Supported
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
50 lbs
Net weight (kg)
23kg
