EcoFlow DELTA 2 Max Solar Generator (PV220W) | 1*220W + DELTA 2 Max | EcoFlow
EcoFlow DELTA 2 Max Solar Generator (PV220W) EcoFlow DELTA 2 Max Solar Generator (PV220W) EcoFlow DELTA 2 Max Solar Generator (PV220W) EcoFlow DELTA 2 Max Solar Generator (PV220W) EcoFlow DELTA 2 Max Solar Generator (PV220W)
USD $1,799.00
Hot
Hot
Regular price USD $1,799.00
Sale price USD $1,799.00 Regular price $2,548.00
-$749
Up to EcoCredits for cash deduction
• Expandable capacity: 2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit a capacity of 6144Wh. Ideal for home backup, RVing, outdoors or even everyday use.
• Built to last 6× longer: Get 10 years of daily use until hitting 80% of its original capacity. That’s down to its LFP battery chemistry giving you 3000+ cycles.
• Huge AC output: With X-Boost mode get up to 3400W output power to run 99% of home appliances. Power 15 devices at once including 6 AC outlets.
• Fastest recharging: World's fastest AC recharging and X-Stream dual AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3 hours.
• Capture more energy: 99% MPPT efficiency maximizes solar generation anytime.
• High conversion efficiency rating: guarantees a faster solar charging speed. 0-100% in 2.6 hours (4 sets), 3.5 hours (3 sets) and 5.4 hours (2 sets).
• Customized in-app energy management: Prioritize solar or AC charging, view input and output power, battery levels and more.
• Comprehensive warranties: DELTA 2 Max includes a 5-year warranty and 12 months for the 220W Bifacial Solar Panel.
• 5-Year warranty5 years for DELTA 2 Max, 12 months for 220W Solar Panel.
USD $1,799 $2,548 -$749
EcoFlow DELTA 2 Max Solar Generator is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
Winner of Red Dot Design Award 2023. EcoFlow DELTA 2 Max Solar Generator
Fuel Up 80% in Only 43 Mins*
Experience the world's fastest 43-minute recharge
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 1.1 hour.
Power pretty much anything with up to 3400W Output
DELTA Max powers almost all the devices you need with a large 2400W AC output. With X-Boost proprietary technology, run appliances with an output of up to 3400W. Compared with similar portable power stations, DELTA 2 Max can power more devices while also preventing overloading and overheating.
Power for the entire family
2048Wh Capacity
Home Backup
RVing & Outdoors
DIY Projects
Filmmaking & Photography
Take control of your power
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Save more on electricity billsCustomize the working time of DELTA 2 Max to avoid peak rates.
Experience peace of mind during power outages With our all-new AC Always On Mode, the AC power button stays on, even during a power outage or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust power Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings.Prioritize solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
Always power readyGet a notification via the app when the battery hits a low.
What's in the box - DELTA 2 Max
DELTA 2 Max
DELTA 2 Max
AC Charging Cable
AC Charging Cable
Car Charging Cable
Car Charging Cable
DC5521 to DC5525 Cable
User manual & warranty card
