EcoFlow DELTA 2 Solar Generator (PV220W) | 1*220W + DELTA 2 | EcoFlow
EcoFlow DELTA 2 Solar Generator (PV220W) (Members-only) DELTA 2 + 220W Portable Solar Panel*2 EcoFlow DELTA 2 Solar Generator (PV220W) EcoFlow DELTA 2 Solar Generator (PV220W)
USD $999.00
Hot
Hot
Regular price USD $999.00
Sale price USD $999.00 Regular price $1,648.00
-$649
Up to EcoCredits for cash deduction
  • Generates up to 3kWh daily.
  • A 1800W AC output.
  • Up to 23% conversion with a unique two-in-one bifacial design to guarantee a fast solar charging speed: 0-100% in 3 hours (2 sets) and 6 hours (1 set).
  • IP68 dust and water resistance.
  • Smart remote control with EcoFlow app.
  • 5-year warranty for DELTA 2 and 12-month warranty for 220W Bifacial Portable Solar Panel.
**DELTA 2 and 220W Bifacial Portable Solar Panel will be shipped separately.
Shipment services to Alaska, Puerto Rico, and Hawaii are temporarily suspended.
USD $999 $1,648 -$649
EcoFlow DELTA 2 Solar Generator is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
Power 99% of appliances
with X-Boost.
DELTA 2 can prevent overloading from devices up to 2200W thanks to X-Boost technology. A 1800W AC output means you can power more than 90% of your home appliances. That's your microwave, fridge, or even coffee maker covered in a blackout.
Go green without sacrificing speed.
Pair with solar panels and charge in as fast as 2.3 hr with 2 × 220W. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency, so you're never left without power.
A simple power outage solution to power your essential home appliances with 1800W AC output by directly connecting the DELTA 2 with your home's power inlet box* with a generator cord for partial home backup. With a plug-and-play design, it's easier than ever to prepare for blackouts. *including transfer switch which has a male L14-30 twist-lock connection that can accept a L14-30 extension cord.
1. DELTA 2 2. AC Charging Cable 3. Car charging cable 4. DC5521 to DC5525 cable 5. User Manual 6. App quick start guide 7. Warranty card*
The solar to XT60 charging cable is included in EcoFlow portable solar panels.
Specs of DELTA 2
1024 Wh
Extra Battery
6 outlets, 1800W total (Surge 2700W)
2200W
2 ports, 5V, 2.4A, 12W Max
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A, 38W Max
AC Charging
X-stream Fast Charge 1200W max
AC Input Voltage
100~120V 15A, 220~240V 10A(50Hz/60Hz)
11-60V, 15A, 500W max
Car Charging
Support 12V/24V battery, 8A
DC Charging
1100W
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
27lbs
Net Weight (kg)
12kg
Specs of 220W Solar Panel
Rated Power
220W Front Side/155W Rear Side
Cell Type
Monocrystalline silicon
Efficiency
22-23%
82*183*2.5cm (32.3*72.0*1.0 in)
Open Circuit Voltage
21.8V (Vmp 18.4V)
Short Circuit Current
13A (Imp 12.0A) Front Side/ 8.8A (Imp8.4A) Rear Side
Weight (Solar Panel)
Approx. 9.5kg (20.9lbs)
