Buy EcoFlow 110W Portable Solar Panel | 110W Portable Solar Panel | EcoFlow
EcoFlow 110W Portable Solar Panel EcoFlow 110W Portable Solar Panel
USD $219.00
Regular price USD $219.00
Sale price USD $219.00 Regular price $399.00
-$180
Up to EcoCredits for cash deduction
• Portable and lightweight
• Up to 23% conversion rate
• Self-supporting
• One-piece folding design
    EcoFlow Solar Extension Cable
    USD $29.99
    USD $219 $399 -$180
    Get off the grid with EcoFlow’s 110W Solar Panel for renewable energy wherever you end up.
    Powerfully portable
    With an industry-leading 23% conversion rate, it's far lighter and approx. 10% smaller than similar portable solar panels on the market. That means a faster, easier charge wherever you are.
    Self-supportable
    Take it camping, on a road trip or in your backyard with a case that doubles as a stand. Unzip and prop up your panel at just the right angle to ensure maximum solar coverage.
    Waterproof & Durable
    Designed to withstand your adventurous lifestyle, this panel is IP68 certified. That means we dunked it underwater for 72hrs in lab conditions. Just to make sure*. Built with a high-strength composite, it can take a beating too. That's an all-weather ready panel designed to stand the test of time.
    It comes with a carry case too.
    On the go? Keep your panel folded up and protected while you hit the road. Save valuable trunk space and go easy knowing your panel is safe. Once you arrive, simply unfold, prop up and start generating clean, green electricity.
    1. 110W Solar Panel 2. 110W Solar Panel Bag 3. 110W Solar Panel User Manual
    How do I get the most solar power?
    Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
    Does it charge if it's inside?
    Yes, if the only thing between it and the sun is transparent, but it won’t charge as well compared to being outside. You can compare the difference by looking at the input section of your power station’s LCD screen.
    Unfolded Dimensions
    20.2*62.5*0.8 in /178.5*42.0*2.5cm
    Folded Dimensions
    20.2*16.5*0.8 in/42.0 x 48.0 x 2.5cm
    Weight
    8.8lb (4kg)
    12 months
    Rated Power
    110W (±5W)
    Efficiency
    22%–23%
    Connector Type
    Solar Connector
    Open Circuit Voltage
    21.8V (Vmp 18.4V)
    Short Circuit Current
    6.5A (Imp 6.0A)
    Cell Type
    Monocrystalline Silicon
    Operating & Storage Temperature
    −4°F to 185°F
