Choose another country or region to see content specific to your location and shop online.
Canada
China
Germany
Japan
Korea
Italy
Spanish
EcoFlow RIVER + 110W Portable Solar Panel
100% secure shopping
Reliable warranty
Free shipping
Regular price
$549.00
Sale
$549.00
Regular price
$748.00
Sold out
per
Number of Solar Panel
  • 1
  • 2
View cart
Compact and portable, EcoFlow RIVER is an ideal recreational power which gives you accessibility to handy wall outlets. EcoFlow RIVER is the perfect companion for camping, overlanding, tailgating, boating, etc.
  •  3 x 600W AC OUTLETS AND 288Wh CAPACITY
  • RECHARGE FROM 0% TO 80% WITHIN 1 HOUR
  • COMPATIBLE WITH 80% HOME APPLIANCES
  • FIT YOUR NEEDS, NOW AND LATER
Stay off the grid with EcoFlow 110W Solar Panel Charger. Made up of efficient monocrystalline silicon cells,  it can recharge DELTA and your electric devices, and keep your equipment running without interruption when connected to our portable power station.
  • PORTABLE & FOLDABLE KICKSTAND PANEL
  • WATERPROOF & DURABLE
TO USE 2x 110W SOLAR PANEL WITH EcoFlow RIVER, YOU NEED TO PURCHASE THE SOLAR PARALLEL CABLE TO CONNECT SOLAR PANEL IN PARALLEL: Solar Parallel Cable
*Please NOTE: This item is only applicable to orders in the US mainland states(except Hawaii, Alaska, Virgin Islands and Puerto Rico).
    Customer reviews
    4.0 563 Reviews
    • 5 star
      75%
    • 4 star
      60%
    • 3 star
      10%
    • 2 star
      8%
    • 1 star
      1%
    Reliable warranty
    Free shipping
    Stay charged with EcoFlow’s 110W Solar Panel. Its monocrystalline cells charge RIVER faster so your outdoor energy use never skips a beat.
    X-Stream Fast Charging
    Power Multiple Devices
    Expandable Battery
    Portable
    The Centerpiece of Your Adventure
    Power up to 10 devices at once with all the ports you’ll need. Sporting a 288Wh capacity, you’ll have enough juice to charge your phone 21 times, triple your drone’s charge, or make 12 cups of coffee with a coffee maker. Just don’t drink them all at once.
    So Much More Sun
    32 premium monocrystalline silicon cells provide a high conversion efficiency of 22%. Recharge even faster by chaining multiple panels in series or in parallel.
    Better Together
    Recharge freely and naturally when you link EcoFlow’s 110W Solar Panel to a RIVER portable power station.
    Compare The Models
    RIVER
    Capacity:288Wh
    Life Cycles: 500+ Cycle
    Output: 600W (Surge 1200W)
    AC Input: 250W Max
    Solar Input: 200W
    $349
    RIVER Max
    Capacity:576Wh
    AC Input: 500W Max
    Solar Input: 200W
    $599
    RIVER Pro
    Capacity:720Wh
    Life Cycles: 800+ Cycle
    AC Input: 660W Max
    Solar Input: 200W
    $649
    Each of the RIVER Series has its advantages. RIVER is ideal for lightweight, grab-and-go power, which you can expand with the extra battery. RIVER Max includes the extra battery by default, which you can remove to go lightweight. RIVER Pro is made for those that need even more capacity for off-grid, long haul adventures.
    Yes. RIVER can power devices up to 1800W with our proprietary technology, X-Boost. *X-Boost can run devices that require up to 1800W, however, it’s best to test before use. Some 600W-1800W appliances with strict voltage requirements may not function (eg. air compressors).
    Yes. You can control RIVER using your phone. Just link to it in the EcoFlow app to control it from afar.
    Yes. You can connect up to 2 sets of 110W solar panels to sustainably charge your RIVER in under 3 hours.
    It can be an emergency power source (EPS), which will have the same result as UPS for most electronics. Here's the difference.When your RIVER is plugged into the wall, anything plugged into it gets power from the grid, not its battery. If power from the grid stops, RIVER automatically switches to its battery supply mode within 30 milliseconds. That means anything connected will not have power for 30 milliseconds, which may mean sensitive electronics like desktop computers and data servers turn off. Test your devices individually to see if they need UPS to stay powered.
    Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
    Yes, if the only thing between it and the sun is transparent, but it won’t charge as well compared to being outside. You can compare the difference by looking at the input section of your power station’s LCD screen.
    Specs of RIVER
    *11 lbs (5kg)
    Dimension
    *11.3 x 7.3 x 7.7 in (28.8 x 18.5 x 19.4 cm)
    Charge Temperature
    32-113°F +/- 5°F (0-45°C +/- 3°C)±
    Discharge Temperature
    -4-113°F +/- 5°F (-20-45°C +/- 3°C)
    Color
    Black
    24 months
    Charge Method
    AC Wall Outlet, 12V Car Adaptor, Solar Panel
    Full Recharge Time
    1.6 Hours (AC) 3 Hours (12V Car Adaptor) 1.6-3 Hours (Using 2x110W Solar Panels simultaneously with full sun) 2.4-5 Hours (Using 1x160W Solar Panel with full sun)
    288Wh - 576Wh (With MAX extra battery)
    Cell Chemistry
    Lithium-ion
    Shelf Life
    1 year (after fully charging the device)
    500 Cycles to 80%+ capacity
    Management Systems
    BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
    Testing and certification
    UL Standard CE FCC RoHS RCM
    AC Charge Input Power
    X-STREAM Charge 250W max/500W Max (With Extra Battery)
    AC Charge Input Voltage
    100-120Vac(50Hz/60Hz)
    Solar Charge Input
    200W 10-25V DC 12A max
    Car Charger
    12V DC 8A max
    AC Output (x3)
    600W (Surge 1200W) total,120Vac( 50Hz/60Hz)
    USB-A Output (x2)
    5V DC,2.4A,12W Max, per port
    USB-A Fast Charge (x1)
    5V/2.4A,9V/2A,12V/1.5A 18W Max
    USB-C Output (x1)
    5V DC,9V DC,12V DC,15V DC,20V DC,5A,100W Max
    Car Power Output (x1)
    136W, 13.6V DC, 10A Max
    DC5521 Output (x2)
    13.6V DC, 3A Max, per port
    Specs of 110W Solar Panel
    Weight
    13.2 lb (Solar Panel 8.8 lb)
    Unfolded Dimensions
    62.5 × 20.2 × 1.0 in (158 × 51.4 × 2.4 cm)
    Folded Dimensions
    16.5 × 20.2 × 1.0 in (42 × 51.4 × 2.4 cm)
    12 months
    Rated Power
    110W (±5W)
    Efficiency
    21%–22%
    Connector Type
    Solar Connector
    Open Circuit Voltage
    21.7V (Vmp 18.5V)
    Short Circuit Current
    6.3A (Imp 6.0A)
    Cell Type
    Monocrystalline Silicon
    Operating & Storage Temperature
    −4°F to 185°F
    The EcoFlow RIVER Max features the RIVER power station plus an Extra Battery, which doubles up the battery capacity and offers you reliable, portable, and easy-to-access power wherever you are.
    X-Boost Technology
    The EcoFlow X-Boost technology gives you the ability to use the 600W inverter to power essential devices like kitchen appliances and tools up to 1800W. This unique technology is perfect for outdoor adventures when you need to power your favorite devices on the go. Please conduct full test on a case-by-case basis to confirm the X-Boost feature works with your appliances. Use X-Boost with devices below 1200W for the best product experience.
    X-Stream Charging Technology
    EcoFlow’s X-Stream technology offers one of the fastest recharging rates for a power station on the market. With the built-in smart inverter, EcoFlow RIVER Max can recharge from 0-80% within 1 hour, achieving a full charge in just 1.6 hours.
    Modular Design + Extra Battery
    The EcoFlow RIVER Max features a compact, modular design that allows you to attach an extra battery to double the capacity of the device from 288Wh to 576Wh. Alternatively, you can detach the Extra Battery to make the device more portable. Whether you’re with family or going on a solo road trip, the modular design gives you all the freedom to customize your power options however you like.
    Power 10 Devices Simultaneously
    EcoFlow RIVER Max fits many types of the ports you’ll need to charge all your devices. The 100W USB-C is perfect for charging laptops while the full sine wave AC outlets give you more flexibility in charging heavy duty devices. With the informative EcoFlow APP, you can control and monitor the unit on your hands.
    Efficient Solar Power
    The EcoFlow RIVER Max is also compatible with the EF Solar Panels, which provide you with a way to generate clean, reliable solar power on the go. Two 110W Solar Panels can be connected in parallel to charge the EcoFlow RIVER Max from 3-6 hours.
    Easy-to-Carry Handle
    Introducing the future of portable power stations. EcoFlow RIVER Max weighs 17lbs, is exceptionally durable, and features an easy-to-carry handle. This incredibly portable power station can be taken around wherever you go, whether that be on your car trunk, coffee table, or the great outdoors. It’s that easy.
    Power a Wide Range of Devices
    The RIVER Max comes with three AC outlets. (Note that the total rated wattage of the three AC outlets is 600W (surge 1200W)). With a built-in 600W inverter, the RIVER Max can power devices up to 1800W with the X-Boost mode on. This provides support for a wide range of essential devices such as a fridge, TV, laptop, hairdryer, and more.
    Note: It is not recommended to use the RIVER series power station to power heavy-duty devices e.g., air conditioners, ovens or washing machines.
    Warning: DO NOT use RIVER series portable power station AC charging cables on DELTA series power stations. EcoFlow takes no responsibilities for any damages caused by customers' failure to follow instructions. Doing so will void the warranty.
    What EcoFlow RIVER Max Can Power?
    *The duration and times of the appliances indicated in this table are for reference only.
    Specifications
    General Info
    Net Weight*17 lbs (7.7kg)
    Dimension*11.4 x 7.3 x 9.3 in (28.9 x 18.4 x 23.5 cm)
    Charge Temperature32-113°F +/- 5°F (0-45°C +/- 3°C)
    Discharge Temperature-4-113°F +/- 5°F (-20-45°C +/- 3°C)
    Color Cyber Black
    Warranty24 months
    Charging
    Charge MethodAC Wall Outlet, 12V Car Adaptor, Solar Panel
    Full Recharge Time1.6 Hours (AC)
    6.5 Hours (12/24V Car Adaptor)
    3-6 Hours (Using 2x110W Solar Panels in parallel with full sun)
    4.8-9.6 Hours (Using 1x160W Solar Panel with full sun)
    Battery Info
    Capacity576Wh (28.8V)
    Cell ChemistryLithium-ion
    Shelf Life1 year (after fully charging the device)
    Cycle Life500 Cycles to 80%+ capacity
    Management SystemsBMS, Over Voltage Protection, Overload Protection,
    Testing and certificationUL Standard CE FCC RoHS RCM
    Input Ports
    AC Charge Input PowerX-STREAM Charge 500W max
    AC Charge Input Voltage100-120Vac(50Hz/60Hz) International Version 220-240Vac(50Hz/60Hz)
    Solar Charge Input200W 10-25V DC 12A Max
    Car Charger12V DC 8A Max
    Output Ports
    AC Output (x3)600W (Surge 1200W) total,120Vac( 50Hz/60Hz)
    USB-A Output (x2)5V DC,2.4A,12W Max, per port
    USB-A Fast Charge (x1)5V DC,9V DC,12V DC,2.4A,28W Max
    USB-C Output (x1)5V DC,9V DC,12V DC,15V DC,20V DC,5A,100W Max
    Car Power Output (x1) 136W, 13.6V DC, 10A Max
    DC5521 Output (x2)13.6V DC, 3A Max, per port
    EcoFlow RIVER Max Portable Power Station
    ProductQuantity
    EcoFlow RIVER MaxX 1
    DC5521-DC5525 CableX 1
    1.5m MC4 to XT60 Solar Charging Cable
    X 1
    1.5m AC Charging Cable
    X 1
    1.5m Car Charging Cable
    X 1
    User ManualX 1
    User Manual
    • Click to Download EcoFlow RIVER Max User Manual
