EcoFlow RIVER Pro Solar Generator (PV160W) - 1*160W + RIVER Pro - EcoFlow
USD $799.00
Regular price USD $799.00
Sale price USD $799.00 Regular price $1,098.00
-$299
  • Generates up to 1.5kWh daily.
  • A 1800W output with X-Boost mode on to power up to 90% of devices.
  • A high conversion rate guarantees a fast solar charging speed: 0-100% in 5.5 hours (1 set).
  • IP68 dust and water resistance. It works well in extreme conditions.
  • Smart remote control from anywhere with EcoFlow app.
  • 2-year warranty for RIVER Pro and 12-month warranty for 160W Portable Solar Panel.
**RIVER Pro and 160W Portable Solar Panel will be shipped separately.
Shipment services to Alaska, Puerto Rico, and Hawaii are temporarily suspended.
USD $799 $1,098 -$299
Step into the wild with a massive 720Wh of battery capacity. RIVER Pro is the powerhouse for your off-grid adventure. Keep multiple devices powered on at once and recharge in record times via car, solar, or standard AC outlets.
X-Stream Fast Charge
Expandable Capacity
X-Boost Output
Power Multiple Devices
The Centerpiece of Your Adventure
Power up to 10 devices at once with all the ports you’ll need.
So Much More Sun
32 premium monocrystalline silicon cells provide a high conversion efficiency of 22%. Recharge even faster by chaining multiple panels in series or in parallel.
Better Together
Recharge freely and naturally when you link EcoFlow’s 160W Solar Panel to a RIVER Pro portable power station.
Compare The Models
RIVER Max
Capacity:576Wh
Life Cycles: 500+ Cycle
Output: 600W (Surge 1200W)
AC Input: 500W Max
Solar Input: 200W
$599
RIVER Pro
Capacity:720Wh
Life Cycles: 800+ Cycle
AC Input: 660W Max
Solar Input: 200W
$649
DELTA
Capacity:1260Wh
Output: 1800W (Surge 3300W)
AC Input: 1200W Max
Solar Input: 400W
$1399
Yes. You can control RIVER Pro using your phone. Just link to it in the EcoFlow app to control it from afar.
Yes. RIVER Pro can power devices up to 1800W with our proprietary technology, X-Boost. *X-Boost can run devices that require up to 1800W, however, it’s best to test before use. Some 600W–1800W appliances with strict voltage requirements may not function (e.g. air compressors).
Yes. You can connect up to 2 sets of 110W solar panels to sustainably charge your RIVER Pro in under 3 hours.
It can be an emergency power source (EPS), which will have the same result as UPS for most electronics. Here's the difference. When your RIVER Pro is plugged into the wall, anything plugged into it gets power from the grid, not its battery. If power from the grid stops, RIVER Pro automatically switches to its battery supply mode within 30 milliseconds. That means anything connected will not have power for 30 milliseconds, which may mean sensitive electronics like desktop computers and data servers turn off. Test your devices individually to see if they need UPS to stay powered.
Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
Yes, if the only thing between it and the sun is transparent, but it won’t charge as well compared to being outside. You can compare the difference by looking at the input section of your power station’s LCD screen.
Specs of RIVER Pro
16.8 lbs (7.6kg)
11.4 x 7.1 x 9.3in (28.9 x 18.0 x 23.5cm)
Charge Temperature
32 to 113°F +/- 5°F (0 to 45°C +/- 3°C)
Discharge Temperature
-4 to 113°F +/- 5°F (-20 to 45°C +/- 3°C)
Color
Black
24 months
Charging Method
AC Wall Outlet, 12V Car Adapter, Solar Panel(s)
Full Recharge Time
1.6 Hours (AC) 8 Hours (12V Car Adapter) 4-8 Hours (Using 2x 110W Solar Panels in parallel with direct sunlight) 6-12 Hours (Using 1x 160W Solar Panel with direct sunlight)
720Wh (28.8V)
Cell Chemistry
Lithium-ion
Shelf Life
1 year (once fully charged)
800 cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certifications
UL Standard, CE, FCC, RoHS, RCM
AC Charge Input Power
X-Stream Charge 660W Max
AC Charge Input Voltage
100-120Vac (50Hz/60Hz)
Solar Charge Input
200W 10-25Vdc 12A Max
Car Charger
12Vdc 8A Max
AC Output (x3)
600W (Surge 1200W) total, 120Vac ( 50Hz/60Hz)
USB-A Output (x2)
5Vdc, 2.4A, 12W Max per port
USB-A Fast Charge (x1)
5V/2.4A,9V/2A,12V/1.5A 18W Max
USB-C Output (x1)
5Vdc, 9Vdc, 12Vdc, 15Vdc, 20Vdc, 5A, 100W Max
Car Power Output (x1)
136W, 13.6Vdc, 10A Max
DC5521 Output (x2)
13.6Vdc, 3A Max per port
Specs of 160W Solar Panel
Weight
15.4 lb (Solar Panel 11 lb)
Unfolded Dimensions
61.8 26.8 × 1.0 in (158 × 51.4 × 2.4 cm)
Folded Dimensions
16.5 × 26.8 × 1.0 in (42 × 51.4 × 2.4 cm)
12 months
Rated Power
160W (±5W)
Efficiency
21%–22%
Connector Type
Solar Connector
Open Circuit Voltage
21.4V (Vmp 18.2V)
Short Circuit Current
9.6A (Imp 8.8A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−4°F to 185°F
The RIVER Pro Extra Battery is sold separately.
