EcoFlow DELTA Pro Ultra + 4 × 400W Rigid Solar Panels + Smart Home Pan | DELTA Pro Ultra + 4 × 400W Rigid + Smart Home Panel 2
EcoFlow DELTA Pro Ultra + 4 × 400W Rigid Solar Panels + Smart Home Panel 2
USD $8,199.00
Regular price USD $8,199.00
Sale price USD $8,199.00 Regular price $8,199.00
-$0
Quantity
USD $8,199
The most powerful whole-home backup solution
-LFP battery
4*400W Rigid Solar Panel
• Fast and Easy Installation
• Up to a 10-year warranty
The most powerful whole-home backup solution.
Month-long power security.
6-90kWh Capacity
5.6kW-16.8kW Solar Input
Flexible Solar Systems
Rigid Solar System
EcoFlow DELTA Pro Ultra works seamlessly with existing rooftop solar panels, replacing sensitive solar inverters prone to failure. Working in tandem with EcoFlow Smart Home Panel 2, maximize the value of your solar power and cut a chunk of change off your energy bill.
*This information is intended for users who have not installed a solar inverter.
Always in charge
With a Generator or EV pile
Peace Of Mind With An Advanced Design.
EcoFlow X-Cooling
Boost Performance with BMS
Our state-of-the-art LFP tech and advanced battery management system (BMS) regulates vital data, ensuring the safety, longevity, and high performance of EcoFlow DELTA Pro Ultra.With each battery offering a cycle life of 3500+, you'll get years of use before capacity drops to 80%. Even then, it keeps powering on.
290V high voltage tolerance
6144Wh, 102.4V⎓60A
30kWh (5 x DPU Battery)
AC Continuous Output
7200W
Expanable Capacity(System*)
90kWh (15 x DPU Battery)
AC Surge Output
10.8kW
Scalability(System*)
21.6kW
IP Rating
IP54
Battery Cycle Life
UPS
DC Output
12.6V⎓30A, 378W Max
AC Output Socket (Backup UPS)
2 x 120V, 20A Max per port
1 x 120V/240V, 30A Max
USB-A
AC Output Socket (Online UPS)
1 x 120V, 30A Max
USB-C
AC Input
Solar Charging Input
Total 5600W, 2 ports
Inverter Dimension
Inverter Net Weight
31.7 kg (70 lb)
Battery Dimension
Battery Net Weight
50.7 kg (111.8 lb)
5-year warranty
Connection
Bluetooth & Wi-Fi & 4G
Discharging temp
-20°C to 45°C | -4°F to 113°F
Charging temp
Storage temp
Hassle-Free bundle Installation Terms & Conditions
Installation Conditions
2. If a customer's house is too large, resulting in excessive wiring and undervoltage, there may be a risk that the NEC regulations will not be met, and the installation will be prevented.
3. In the event of unforeseen circumstances that may prevent installation, EcoFlow reserves the right to determine the final feasibility of installation.
Installation Service Package includes wiring the EcoFlow Smart Home Panel 2 to the existing load center. It does not include wiring the EcoFlow Power Station to solar panels or PV systems. If the customer requires the installation to include wiring to solar panels or PV systems, the electrician reserves the right to refuse to take order.
The installation service excludes:
a. Additional material and labor costs due to excessive distance or incompatibility between the existing circuit breaker and Smart Home Panel 2.
c. The electrician's on-site assessment fee, which can be waived if the circumstance has been assessed by the electrician to be suitable for installation and the customer does not request for refund of the installation service fee.
The above extra costs and fees shall be subject to the actual quote from the electrician. Customers are responsible for directly paying the electrician for any extra costs incurred. EcoFlow reserves the right to final interpretation of the installation service fee.
By agreeing to EcoFlow's installation services, you consent to the collection and processing of personal information necessary for completing the service. This may include, but is not limited to, your name, address, contact information, and any relevant details related to the installation. We will handle your personal information in compliance with applicable data protection laws and regulations and will only use it for the purpose of fulfilling the installation service. Please refrain from directly providing your personal information to the electrician during the installation process, otherwise you will be responsible for any loss or damage caused by the disclosure of such information.
3. Should a customer opt for our installation service and then decide to return the Smart Home Panel 2 due to dissatisfaction after installation, the paid installation fee cannot be refunded. Additionally, the customer will be responsible for any costs associated with the removal of Smart Home Panel 2.
4. The installation service does not include any cleaning or removal of debris generated during the installation process. Residents are responsible for managing and disposing of all trash and debris resulting from the installation.
5. Any holes or modifications made to the premises during the installation are considered normal and necessary for the proper completion of the service. The installer shall not be held liable for any unavoidable damages or alterations made to the premises during the installation process.
7. Any product issues or defects resulting from installation by an unauthorized installer shall be the sole responsibility of the resident. The resident shall bear full responsibility for any after-sales service or repairs needed due to such unauthorized installations.
Stay in the Loop & Save More!
Price Drop Alerts
Cost Savings
Whole-Home Backup
Intelligence Solutions
Thank you for subscribing!
