Aerodynamic Solar Solution That Fits Any RV Roof
With a 30-year lifespan, this durable, low-maintenance solar panel is ideal for RV use.
Size fits various RV types:
The narrow, rectangular design fully utilizes the roof space of almost any van, from Class B to Class A, from trailers to fifth wheels.
Ultra-thin design for low wind resistance:
At only 0.5 in (12 mm), this slimline panel significantly reduces wind resistance by more than 60% when you're on the road, effectively improving fuel efficiency and saving on fuel costs. Our RVMax solar panel is almost 1 inch (23 mm) slimmer than traditional models.
EcoFlow 130W RVMax Rigid Solar Panel features an innovative modular design, delivering up to 130W power, 50V, and 3A current output, and connects up to 10 panels within a safe range. Works seamlessly with various power stations.
Maximum Power, Extended Lifespan
With N-Type TOPCon technology, achieve up to 25% conversion efficiency.
Engineered to Withstand the Elements
Built for the road ahead, TOPCon solar cells with ultra-slim 2 mm tempered glass maximize light transmission while providing solid protection against debris, storms, or hail during your journey. RVMax's reinforced corners help prevent impact damage and hidden cracks common in standard panels. Complete with an IP68 rating and the waterproof LFB-40 connector, this panel delivers reliable power through rain, dust, and challenging weather conditions.
Plug and Play with Your Power System
Easily connect to third-party solar systems using the included photovoltaic connector (MC4 compatible)⁴. Safely charge your power systems and portable power stations with XT60 connectors, featuring waterproof, anti-leak technology that's touch-safe and reliable.
Adapts to Various RV Power Systems
Power Kits
EcoFlow DELTA & RIVER Series
Third-party portable power stations
Other RV power system
What's in the Box
Rated Power
130W (±3W)
Dimension(mm)
1345x524mm(12mm)
Net Weight(kg)
3.5kg
Waterproof & Dustproof Rating
Cell Type & Efficiency
topcon 25%
Open-Circuit Voltage
51V
Optimal Operating Voltage
43V
Short Circuit Current
3.2A
-0.3%/C
5 years
It is suitable for installation on the roofs of Class B Vans, Class C vehicles, and trailers.
You should choose the right controller or inverter based on your specific usage to ensure efficient storage and use of electricity.
This solar panel features a high-voltage design and uses an LFB-40 interface. It can be connected in series to save on wiring.
The LFB-40 interface is a common DC power output connector used for solar panels. It primarily facilitates power transmission between portable solar power generation equipment and devices like charging controllers, energy storage units, and power banks.
This interface supports a maximum current of 40A, meeting the standard 30A current capacity. It can reliably handle high currents, preventing overheating or damage. It can be connected in series, allowing up to 10 130W solar panels to be linked together. Additionally, it has a locking mechanism to ensure the solar panel remains secure and does not detach due to vibrations when installed on a vehicle.
Regularly clean the panels with clean water or a damp cloth to prevent dust from reducing their efficiency. Avoid using hard objects to scratch the surface to prevent damage. Annually check the wire connections to make sure they are secure, as poor connections can affect charging.
Solar panels require sunlight to generate electricity. They can still produce a small amount of power on cloudy days, but with reduced efficiency. At night or in extreme weather conditions, their power generation capacity will significantly decrease or stop, so using energy storage equipment is recommended.
Yes, but their efficiency will be lower. Winter has shorter daylight hours, and low temperatures can affect the performance of the batteries. It is advisable to regularly check if the solar panels are covered by snow during winter to maintain good power generation capacity.
Typically, they can endure temperatures ranging from -40°C to 85°C, though extended exposure to high heat might reduce their efficiency.
Solar panels are quite light, with each panel weighing around 5.6 kg, so they generally don't add much weight to the vehicle.
