DELTA Pro 3 Solar Generator (PV400W) | EcoFlow | (members only) DELTA Pro 3 + 1*400W + Transfer Switch (306A)
EcoFlow DELTA Pro 3 Portable Power Station + 400W Portable Solar Panel + Transfer Switch (306A) EcoFlow DELTA Pro 3 Portable Power Station + 400W Portable Solar Panel + Transfer Switch (306A)
USD $2,849.00
Regular price USD $2,849.00
Sale price USD $2,849.00 Regular price $5,297.00
-$2,448
Get up to $959.70 in rebates through the Residential Clean Energy Credit. Learn More >
Up to $959.70 in rebates
Amount 30% off
Claim By: December 31, 2032
Program: Residential
  • Rentals do not qualify.
  • Must be grid-tied.
 A battery generator that powers almost all of your essential home appliances.
Powerful and Versatile - 120V/240V, 4000W in a single unit to power almost all of your home appliances.
Expandable Capacity - 4–48kWh, tailored to your energy needs.
Quiet Operation - Operates as low as 30 dB (under 2000W) for minimal noise.
Easy to Use - Plug-and-play design for hassle-free setup.
Fast Charging - Charges to 80% in just 50 minutes.
Multiple Charging Methods - 7 unique and 18 combo charging methods for maximum flexibility.
Solar Input - 2600W solar input with 2 PV ports for both high volt and low volt options.
Conversion Efficiency - High conversion efficiency rating ensures faster solar charging.
AC Output - Huge AC output for all your power needs.
Energy Capture - 99% MPPT efficiency to maximize solar generation anytime.
Energy Management - Customized in-app energy management to prioritize solar or AC charging, view input/output power, battery levels, and more.
Recommend
EcoFlow DELTA Pro 3 Extra Battery-Recommend
USD $1,799 USD $2,599
EcoFlow Smart Home Panel 2-Recommend
USD $1,499 USD $1,899
EcoFlow Smart Generator 4000 (Dual Fuel)-Recommend
USD $1,159 USD $1,799
You Could Apply for 30% Tax Credit*, When You Install EcoFlow DELTA Pro 3 as a Home Power Solution
USD $2,849 $5,297 -$2,448
2600W Solar Input with Dual PV Ports
Enjoy versatile and powerful solar input with 2600W capacity through dual PV ports, offering both high-voltage and low-voltage options to maximize your energy intake.
High Conversion Efficiency
Benefit from fast solar charging thanks to the high conversion efficiency rating. This guarantees quicker energy replenishment, so you can keep your devices powered up without delay.
Maximize Solar Generation
Capture more energy with 99% MPPT efficiency, ensuring that your solar panels generate the maximum possible power at any time, optimizing your solar energy production.
Robust AC Output and Expandable Capacity
Power almost everything with a massive AC output, allowing you to run high-demand appliances with ease. Expand your power capacity up to 12kWh by adding extra batteries, thanks to the reliable LFP battery chemistry that provides long-lasting, durable energy storage.
Smart App Control
Gain complete control over your energy usage with the EcoFlow app. Customize your energy management by prioritizing solar or AC charging, and monitor input and output power, battery levels, and more. Stay connected and manage your power system seamlessly from anywhere.
Disclaimer
Effective date: Jan 1, 2023
