EcoFlow DELTA mini + 110W Solar Panel
Our lightest DELTA It’s power you can pick up, take along, and stow away for wherever a wall outlet isn’t handy.
Power bigger electronics DELTA mini’s output of 1400W handles 90% of electronics. X-Boost that number to 1800W and suddenly your toaster oven, table saw, and hairdryer become battery-powered.
A dozen at once Power up to 12 devices with a generous array of wall-style outlets, USB outlets, and DC outlets.
Fully charged in 1.6 hours With X-Stream on, DELTA mini charges 3 to 4 times faster than other portable power stations. Faster charging means less downtime and more do-time.
*Note: This item is only available for sale in the contiguous United States.
Customer reviews
5 star
4 star
3 star
2 star
1 star
Bring along DELTA mini and keep your devices powered at all times. DELTA mini’s 882Wh capacity is perfect for power outages, outdoor adventures, and professional work.
Big capacity
Portable
Power Multiple Devices
Solar Power
Pint-sized Powerhouse
More possibilities open up when you bring along 1400W for up to 12 devices. Whether it’s professional gear or the comforts of home, it’s good to know you’re good to go.
Charge Faster
DELTA mini snags up to 300W from solar panels for a full recharge in 3 to 6 hours. It can also go from 0-100% in 96 minutes when charging from the wall.
Smarter with the App
The EcoFlow app shows how much solar you’re bringing in and how many watts your slow cooker and mini-fridge are pulling. Connect it to the internet and control it from anywhere.
Three easy ways to charge
Solar charging
Harness the power of the sun by linking up to two 160W solar panels, and be fully charged in as little as 4 to 8 hours.
Car charging
Heading on a road trip? Charge DELTA mini along the way from your car outlet.
Wall outlet
Plug into any standard AC wall outlet to fast charge from 0–80% in under 1 hour with X-Stream charging.
What’s in the box
1. EcoFlow DELTA mini, 2. DC 5521 to DC 5525 cable, 3. Solar charging cable, 4. AC charging cable, 5. Car charging cable, 6. User manual
Compare The Models
RIVER Pro
Capacity:720Wh
AC Output: 600W
Solar Input: 200W
$649
DELTA Mini
Capacity:882Wh
AC Output: 1400W
Solar Input: 300W
$999
DELTA
Capacity:1260Wh
AC Output: 1800W
Solar Input: 400W
$1399
23.6 lb (10.7 kg)
14.9 × 7.2 × 9.4 in (37.8 ×18.4 × 24 cm)
Charge Method
AC Wall Outlet, 12V Car Outlet, Solar Panel
Full Recharge Time
1.6 Hours (AC) 9½ Hours (12/24V Car Outlet) 3¾–7½ Hours (Using 2x 160W Solar Panels) 3–6 hours (Using 1x 400W Solar Panel)
882Wh
Cell Chemistry
NCM Li-ion
Shelf Life
1 year (after fully charged)
800 cycles to 80% capacity
Battery Management System
Testing and certification
UL, CE, FCC, RoHS, TELEC
AC Charge Input Power
X-Stream Fast Charge 900W max
Solar Charge Input
300W 11–75V DC 10A max
Car Charger
12V/24V DC 8A default
AC Output (×5)
Pure Sine Wave, 1400W total (surge 2100W), 120V~ (50Hz/60Hz)
USB-A Output (×2)
5V DC, 2.4A, 12W Max, per port
USB-A Fast Charge (×1)
5V, 2.4A / 9V, 2A / 12V, 1.5A, 18W Max
5/9/12/15/20V, 5A, 100W Max
Car Power Output
12.6V, 10A, 126W Max
