Home emergency power DELTA Max expands up to 6kWh with smart extra batteries, keeping your home powered on in any emergency.
Power multiple devices Looking for something to power heavy-duty devices like your fridge and dryer? With X-Boost, DELTA Max handles devices up to 3400W with ease.
Portable solar generator Stay powered on no matter what. DELTA Max connects with up to 2x 400W EcoFlow solar panels to deliver 800W Max solar charging speeds.
Customer reviews
5 star
4 star
3 star
2 star
1 star
Expandable Capacity
Dual Charging
Power Multiple Devices
800W max Solar Input
Expandable home backup power.
DELTA Max charges up safely and rapidly from 0-80% in just 65 minutes. And it gets even better. If you’re looking for an even faster way to charge up DELTA Max, you can combine AC with the smart generator to get up to 3400W, AC with solar to get up to 2600W, or the Smart Generator with solar to get up to 2600W.*
With EcoFlow’s X-Boost technology, DELTA Max can power heavy-duty devices up to 3400W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That’s the industry gold standard for a portable power station of this size and capacity.
Harness the power of the sun.
DELTA Max connects with up to 2x 400W EcoFlow solar panels to deliver 800W Max solar charging speeds. With a voltage range from 11-100V and the MC4 connector, you can also connect other solar panels to your DELTA Max. Even during cold or cloudy days, our smart maximum power point tracking (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day.
Emergency backup power.
Specs of DELTA Max
2016Wh
6 outlets, 2400W total (Surge 5000W)
DC5521 Output
Solar Charging Input
800W Max, 11-100V, 13A
NCM
Shelf Life
1 year (after a full charge)
Approx. 48lbs
Extra Battery
Support up to two DELTA Max Smart Extra Battery/Smart Generator
3400W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
AC Charging Input
1800W Max, 15A
Car Charging Input
Support 12V/24V battery, 8A
800 cycles to 80% capacity
Connection
Wi-Fi
Dimension
19.6*9.5*12 in
Specs of 160W Solar Panel
Unfolded Dimensions
61.8 × 26.8 × 1.0 in (158 × 51.4 × 2.4 cm)
Folded Dimensions
16.5 × 26.8 × 1.0 in (42 × 51.4 × 2.4 cm)
Weight
15.4 lb (Solar Panel 11 lb)
12 months
Rated Power
160W(±5W)
Efficiency
21%–22%
Connector Type
MC4
Open Circuit Voltage
21.4V (Vmp 18.2V)
Short Circuit Current
9.6A (Imp 8.8A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−4°F to 185°F
